Core returned BAD_WORK_UNIT (114)
marmika1994
Post by marmika1994 »
Hi,
my problem:
(MoBo: Asus Rog Strix B550-A
CPU: AMD 5700G
GPU: Nvidia RTX2070, driver ver.: 550.163.01 VBIOS ver.: 90.06.0B.40.CD
RAM: 2x8 GB
F&H 8.4.9 beta
OS Linux Debian 13.1)
Message from log text:
04:06:28:I1:WU356:Completed 200000 out of 2000000 steps (10%)
04:06:28:I1:WU356:An exception occurred at step 200000: Discrepancy:
Velocities are blowing up! 23355 2 -17.5119
04:06:28:I1:WU356:Max number of attempts to resume from last checkpoint (4)
reached. Aborting.
04:06:28:I1:WU356:ERROR:114: Max number of attempts to resume from last
checkpoint reached.
04:06:28:I1:WU356:Saving result file ../logfile_01.txt
04:06:28:I1:WU356:Saving result file science.log
04:06:28:I1:WU356:Saving result file state.xml
04:06:29:I1:WU356:Folding@home Core Shutdown: BAD_WORK_UNIT
04:06:29:E :WU356:Core returned BAD_WORK_UNIT (114)
04:06:30:I1:Default:Added new work unit: cpus:0 gpus:gpu:01:00:00
04:06:30:I1:WU356:Uploading WU results
04:06:30:I1:WU357:Requesting WU assignment for user Ti team 1065589
An error occurred on other machines when running wu.
Project 15404 RCG 0,746,37
Logged Credits
Code User Team Credit Assigned Credited
Failed rekceir 1066966 0 2025-09-16 00:33:16 2025-09-16 03:33:32
Failed illest 40051 0 2025-09-16 03:25:59 2025-09-16 03:43:29
Failed Ti 1065589 0 2025-09-17 03:40:58 2025-09-17 04:13:20
Failed roflwaffle 223518 0 2025-09-17 04:07:32 2025-09-17 05:13:26
Failed GooseWurkz 1066966 0 2025-09-17 05:04:42 2025-09-17 05:43:15
How can this mistake be avoided?
thx
Re: Core returned BAD_WORK_UNIT (114)
It appears this particular WU has failed for 5 different folders, it should be automatically set to not be reassigned. This does happen with some trajectories, they reach a point at which they fail to be able to continue. Nothing you should need to do, just check to see if a pattern of failures shows up.
