Can unused folding slots be removed?
Schrödinger's cat
Hardware configuration: NVIDIA RTX 4080 Super
20 x Raspberry Pi 5 Model B 2GB RAM
Post by Schrödinger's cat »
Is it possible to remove unused folding slots via config.xml?
Re: Can unused folding slots be removed?
Post by muziqaz »
yes
FAH Omega tester
Schrödinger's cat
If removed via Advanced Control > Configure, won't they be added back when the Folding@home client is restarted?
Post by muziqaz »
Schrödinger's cat wrote: Sat Sep 06, 2025 6:12 pm If removed via Advanced Control > Configure, won't they be added back when the Folding@home client is restarted?
No, that would defeat the purpose of the Advanced Controls, would it? However, if I remember correctly, v7 would automatically still re-add a GPU slot, in which case you just pause it and leave it be.
FAH Omega tester
If you have an unused GPU folding slot that you delete using the v7 Configure, by default it will be added back. To keep this from happening, once you have the GPUs you want configured, then set GPUs to false. The ones already configured with slots will remain, the client will not rescan to add GPUs after a restart. I don't recall if that is a checkoff box available in the advanced or expert tabs, it can be also added as an option through config.xml. I don't have anymore v7 clients around, so can't check the syntax. But it has been posted here a number of times in the past.
Schrödinger's cat
Joe_H wrote: Sat Sep 06, 2025 6:43 pm If you have an unused GPU folding slot that you delete using the v7 Configure, by default it will be added back. To keep this from happening, once you have the GPUs you want configured, then set GPUs to false. The ones already configured with slots will remain, the client will not rescan to add GPUs after a restart. I don't recall if that is a checkoff box available in the advanced or expert tabs, it can be also added as an option through config.xml. I don't have anymore v7 clients around, so can't check the syntax. But it has been posted here a number of times in the past.
Thanks JoeH, that's just what I'm after. In Advanced Control, it's just a matter of adding
gpu false
to the Extra client options on the Expert tab.
