How to Fix, GPUs went to Unsupported after reboot
quartz64
Post by quartz64 »
I have a test platform with 8 Nvidia H800 GPUs. Everything worked fine for two days (ArchLinux, fah-client 8.4.9, Driver Version: 580.76.05, CUDA Version: 13.0), but in the morning after rebooting, all GPUs are shown as unsupported. My GPU is present in a GPUS.txt file (0x10de:0x2322:2:9:GH100 [H800 PCIe]). What went wrong?
07:34:16:I1:*********************** Folding@home Client ***********************
07:34:16:I1: Version: 8.4.9
07:34:16:I1: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:34:16:I1: Org: foldingathome.org
07:34:16:I1: Copyright: 2023-2024, foldingathome.org
07:34:16:I1: Homepage: https://foldingathome.org/
07:34:16:I1: License: GPL-3.0-or-later
07:34:16:I1: URL: https://v8-4.foldingathome.org/
07:34:16:I1: Date: Aug 25 2025
07:34:16:I1: Time: 14:11:23
07:34:16:I1: Revision: 360fe71b1bd05bb89814bfb97b73a5bda84802d6
07:34:16:I1: Branch: makepkg
07:34:16:I1: Compiler: GNU 15.2.1 20250813
07:34:16:I1: Options: -Wsuggest-override -faligned-new -std=c++14 -fsigned-char
07:34:16:I1: -ffunction-sections -fdata-sections -O3 -funroll-loops -fno-pie
07:34:16:I1: Platform: linux 6.16.1-arch1-1
07:34:16:I1: Bits: 64
07:34:16:I1: Mode: Release
07:34:16:I1: Args: --config=/etc/fah-client/config.xml
07:34:16:I1: --log=/var/log/fah-client/log.txt
07:34:16:I1: --log-rotate-dir=/var/log/fah-client/
07:34:16:I1: Config: /etc/fah-client/config.xml
07:34:20:I3:gpus = {
07:34:20:I3: "gpu:206:00:00": {"vendor": 4318, "device": 8994, "type": "nvidia", "supported": false, "description": "GH100 [H800 PCIe]"},
07:34:20:I3: "gpu:209:00:00": {"vendor": 4318, "device": 8994, "type": "nvidia", "supported": false, "description": "GH100 [H800 PCIe]"},
07:34:20:I3: "gpu:213:00:00": {"vendor": 4318, "device": 8994, "type": "nvidia", "supported": false, "description": "GH100 [H800 PCIe]"},
07:34:20:I3: "gpu:214:00:00": {"vendor": 4318, "device": 8994, "type": "nvidia", "supported": false, "description": "GH100 [H800 PCIe]"},
07:34:20:I3: "gpu:79:00:00": {"vendor": 4318, "device": 8994, "type": "nvidia", "supported": false, "description": "GH100 [H800 PCIe]"},
07:34:20:I3: "gpu:82:00:00": {"vendor": 4318, "device": 8994, "type": "nvidia", "supported": false, "description": "GH100 [H800 PCIe]"},
07:34:20:I3: "gpu:86:00:00": {"vendor": 4318, "device": 8994, "type": "nvidia", "supported": false, "description": "GH100 [H800 PCIe]"},
07:34:20:I3: "gpu:87:00:00": {"vendor": 4318, "device": 8994, "type": "nvidia", "supported": false, "description": "GH100 [H800 PCIe]"}
07:34:20:I3:}
Reason: moved post appropriate forum
Re: How to Fix, GPUs went to Unsupported after reboot
Post by muziqaz »
sudo systemctl restart fah-client
This is needed after every reboot on linux
FAH Omega tester
quartz64
Post by quartz64 »
Probably, the problem was related to the driver version, after rebooting the new Nvidia driver (v. 580) loaded.
Solved the problem by switching to Ubuntu Server 24.04 (nvidia driver 570.158.01).
Post by muziqaz »
No, this is more of an issue with latest distros. 24.04 does not seem to have this issue
FAH Omega tester
thaddeusf
Hardware configuration: AMD Zen2 and Zen5
Intel 12th and 13th Gen
ARM Neoverse N
Intel ARC A770
Nvidia 1080 and 3080
Post by thaddeusf »
That is funny. Have same problem with NV5080. Rebooted, removed /var/lib/fah-client/gpus.json, stopped FAH, started FAH.
But problem resolved as soon as running: sudo systemctl restart fah-client
Maybe timing?
Post by calxalot »
Please try 8.5.3 beta. It has changes to GPU detection.
https://foldingathome.org/beta/
