Warning Failed Message
rjm32792
Post by rjm32792 »
I have several machines folding and one keeps showing up as failed on my folding webpage. The problem machine has a Supermicro X10DRi-TR motherboard, 64GB RAM, 2 x Intel Xeon E5-2697v4 CPUs, 1200W power supply, and 3 x 1080 Ti cards. I'm running Ubuntu 24.04 with the latest FAH app. Ubuntu runs perfect on the board, but it bears noting that I couldn't get Windows 10 (ISO from Microsoft) or 11 (ISO from Microsoft modified with Rufus) to run stable after installation. They both get an error screen requiring a reboot after running for a while. I have three other machines running the same configuration with Windows 11 and FAH running perfectly. I think the motherboard is allergic to Windows and needs to be replaced. I don't know if the potential problem with the board is causing FAH to get the warning/failed message..
I looked for log files in /var/lib/fah-client and couldn't find one. Any ideas on where to find the log file?
Re: Warning Failed Message
Post by muziqaz »
Provide screenshot of the web page where it shows that it is failing. Also, webpage itself has log section, it shows everything what is happening at a given moment
FAH Omega tester
Did you try to run "sudo apt install ocl-icd-opencl-dev" and then restart the client ?
rjm32792
Post by rjm32792 »
Thanks for the suggestions. I found where the logfiles are, but after trying toTOW's suggestion, I've only received one warning and it seemed to go away on it's own. If I have anymore trouble, I'll post the logs.
