Fails to find work unit over and over and over again
Woodward
Post by Woodward »
On my M2 Mac, I had about one good month of folding, and then it just started to do this every single time I try to use the application.
Log from the console:
15:21:28:I1:WU82:Retry #3 in 8 secs
15:21:36:I1:WU82:Requesting WU assignment for user WoodwardIII homelab team 1066329
15:21:36:I1:OUT8:> POST https://assign4.foldingathome.org/api/assign HTTP/1.1
15:21:36:I1:OUT8:< HTTP/1.1 503 HTTP_SERVICE_UNAVAILABLE
15:21:36:E :OUT8:HTTP_SERVICE_UNAVAILABLE: {"error":"No appropriate assignment"}
I've already tried reinstalling the application as well as messing around with tons of different network settings, and I can't seem to get anything to work.
Thoughts?
700+ units folded
Woodward
Re: Fails to find work unit over and over and over again
Post by Woodward »
Note: I'm posting this here because I don't understand how to navigate these forums. This is probably not a category.
700+ units folded
Post by muziqaz »
Yes, there is shortage of WUs.
FAH Omega tester
There is a shortage of GPU WUs, but that shouldn't affect your M2 Mac. What is your CPU thread setting on that Mac? Recently most projects were set to require a minimum of 3 CPU threads, if you have yours set to 2 you wouldn't get work.
arisu
Post by arisu »
There seems to be an issue with CPU WU allocation. Several people have reported this. I've brought it up internally and it will be investigated.
Woodward
Post by Woodward »
Plot thickens, works fine with 4 CPU cores enabled, but not 3. (I want 3 because given the thermal constraints of the device, it's actually faster)
700+ units folded
Woodward
Post by Woodward »
I've been manually bumping it up to 4 to get something assigned and then back down to three again. It's kind of stupid, given my RPIs can get units with 4 cores, but it literally takes 5x as long to run a unit on them (over my Mac with 3), even with the extra core.
700+ units folded
daiko
Mac Mini M4 Pro
M2 Macbook Air
Folding since 2005
Post by daiko »
Woodward wrote: Wed Aug 13, 2025 5:34 pm I've been manually bumping it up to 4 to get something assigned and then back down to three again. It's kind of stupid, given my RPIs can get units with 4 cores, but it literally takes 5x as long to run a unit on them (over my Mac with 3), even with the extra core.
I have found the same limitation—it seems 4 cores is the minimum now to get a WU from the assignment server. I have an old 5K iMac that also performs better on 3 cores, so I have taken the same approach of backing it back down to 3 after acquisition. Unfortunately, using 4 cores for acquisition often nets a WU from the Disordered Proteins projects (18803 or 18806), which perform pretty miserably on a few of my machines. :roll:
Post by muziqaz »
Minimum is still 3. You guys need to understand that we do not go out and release projects specifically for super low end. You cannot expect researchers target that market, when their job and research papers are on the line. When we are testing these projects we see how they run with mid range and high end set up. We can never predict how various people will be running folding. Some might pause once in a while, others pause overnight, others fold a bit, then do other things, then fold a bit again. If we freely allow super low end CPUs (core count) to get every project, we will end up with loads of WUs timed out.
FAH Omega tester
arisu
Post by arisu »
daiko wrote: Thu Aug 14, 2025 5:21 pm
Most likely it's just coincidence and not a real limitation. I'm getting CPU WU shortages with 8 cores from time to time as well.
daiko
Mac Mini M4 Pro
M2 Macbook Air
Folding since 2005
Post by daiko »
muziqaz wrote: Thu Aug 14, 2025 6:39 pm Minimum is still 3.
Are you sure about that? I have several machines (a few of which are very capable CPU machines), none of which will receive a WU if the cpu count is set to 3. It may just be that the available pool of WUs does not have a sufficient number of small atom count projects, but I haven’t seen a WU served that requires less than 4 cores for days, personally.
Post by muziqaz »
daiko wrote: Thu Aug 14, 2025 7:46 pm
Yes, I'm trying to drop it down to 2 threads now
FAH Omega tester
