DNS lookup failed, and HTTP service unavailable.
Peter
Post by Peter »
Since a few days I keep getting errors after completing a GPU-WU on my laptop (Win11).
I'm not getting a new WU assigned.
'Been GPU crunching for nearly a year on this device, and never had a problem before.
Last night after uploading, I got the first message. The programm kept retrying to get a new GPU WU.
Went on for hours so I powered down.
Today at start of F&H the same error occurred. But after an hour I suddenly got a new WU, so I dismissed
all as a temporary glitch.
Just now the same keeps appearing.
It says DNS lookup failed, and HTTP service unavailable. And it keeps re-itterating the same info.
Is this something serverside related? Why is this suddenly happening?
Nothing changed on my side on the laptop.... Am open to suggestions, as in: please help :D
/edit:
After I typed this posting, the programm finally started with a GPU-WU.
But am still posting this, because imho this shouldn't have happened. And maybe it happens again :roll:
Logfile info (a part of it):
15:16:19:I1:WU307:Downloading WU
15:16:19:I1:Loaded cores/openmm-core-24/windows-10-64bit/release/fahcore-24-windows-10-64bit-release-8.1.4/FahCore_24.exe
15:16:19:I1:OUT2:> POST https://huangfolding1.chem.wisc.edu/api/assign HTTP/1.1
15:16:19:I1:OUT2:< HTTP/1.1 503 HTTP_SERVICE_UNAVAILABLE
15:16:19:E :OUT2:HTTP_SERVICE_UNAVAILABLE: {"error":{"message":"Please wait","code":503}}
15:16:19:I1:WU307:Retry #1 in 2 secs
15:16:22:I1:WU307:Requesting WU assignment for user DE_KOMETEN team 92
15:16:22:I1:OUT3:> POST https://assign1.foldingathome.org/api/assign HTTP/1.1
15:16:22:I1:OUT3:< HTTP/1.1 503 HTTP_SERVICE_UNAVAILABLE
15:16:22:E :OUT3:HTTP_SERVICE_UNAVAILABLE: {"error":"No appropriate assignment"}
15:16:22:I1:WU307:Retry #2 in 4 secs
15:16:26:I1:WU307:Requesting WU assignment for user DE_KOMETEN team 92
15:16:41:W :CON4:DNS lookup failed for assign2.foldingathome.org
15:16:41:E :OUT4:Failed response: CONNECT
15:16:41:I1:WU307:Retry #3 in 8 secs
15:16:49:I1:WU307:Requesting WU assignment for user DE_KOMETEN team 92
15:16:49:I1:OUT5:> POST https://assign3.foldingathome.org/api/assign HTTP/1.1
15:16:49:I1:OUT5:< HTTP/1.1 503 HTTP_SERVICE_UNAVAILABLE
15:16:49:E :OUT5:HTTP_SERVICE_UNAVAILABLE: {"error":"No appropriate assignment"}
15:16:49:I1:WU307:Retry #4 in 16 secs
15:17:05:I1:WU307:Requesting WU assignment for user DE_KOMETEN team 92
15:17:06:I1:OUT6:> POST https://assign4.foldingathome.org/api/assign HTTP/1.1
15:17:06:I1:OUT6:< HTTP/1.1 503 HTTP_SERVICE_UNAVAILABLE
15:17:06:E :OUT6:HTTP_SERVICE_UNAVAILABLE: {"error":"No appropriate assignment"}
15:17:06:I1:WU307:Retry #5 in 32 secs
15:17:38:I1:WU307:Requesting WU assignment for user DE_KOMETEN team 92
15:17:53:W :CON7:DNS lookup failed for assign5.foldingathome.org
15:17:53:E :OUT7:Failed response: CONNECT
15:17:53:I1:WU307:Retry #6 in 1 min 4 secs
15:18:57:I1:WU307:Requesting WU assignment for user DE_KOMETEN team 92
15:18:57:I1:OUT8:> POST https://assign6.foldingathome.org/api/assign HTTP/1.1
15:18:58:I1:OUT8:< HTTP/1.1 503 HTTP_SERVICE_UNAVAILABLE
15:18:58:E :OUT8:HTTP_SERVICE_UNAVAILABLE: {"error":"No appropriate assignment"}
15:18:58:I1:WU307:Retry #7 in 2 mins 8 secs
15:21:06:I1:WU307:Requesting WU assignment for user DE_KOMETEN team 92
15:21:06:I1:OUT9:> POST https://assign1.foldingathome.org/api/assign HTTP/1.1
15:21:06:I1:OUT9:< HTTP/1.1 503 HTTP_SERVICE_UNAVAILABLE
15:21:06:E :OUT9:HTTP_SERVICE_UNAVAILABLE: {"error":"No appropriate assignment"}
15:21:06:I1:WU307:Retry #8 in 4 mins 16 secs
Re: DNS lookup failed, and HTTP service unavailable.
Post by muziqaz »
There is a shortage of the WUs right now
FAH Omega tester
Mactin
Post by Mactin »
I've been getting similar messages for work for my GPU client. My 3 CPU clients are all OK.
18:59:35:I1:WU502:Folding@home Core Shutdown: FINISHED_UNIT
18:59:38:I1:WU502:Core returned FINISHED_UNIT (100)
18:59:41:I1:Default:Added new work unit: cpus:0 gpus:gpu:01:00:00
18:59:41:I1:WU502:Uploading WU results
18:59:43:I1:WU504:Requesting WU assignment for user Martin_r7-8700f+RTX5060Ti team 96377
18:59:43:I1:WU503:WARNING:Console control signal 1 on PID 11780
18:59:43:I1:WU503:Exiting, please wait. . .
18:59:43:I1:OUT228:> POST https://assign2.foldingathome.org/api/assign HTTP/1.1
18:59:43:I1:OUT227:> POST https://ds01.scs.illinois.edu/api/results HTTP/1.1
18:59:44:I1:OUT228:< HTTP/1.1 503 HTTP_SERVICE_UNAVAILABLE
18:59:44:E :OUT228:HTTP_SERVICE_UNAVAILABLE: {"error":"No appropriate assignment"}
18:59:44:I1:WU504:Retry #1 in 2 secs
18:59:44:I1:WU503:Core returned INTERRUPTED (102)
18:59:44:I3:Running FahCore: C:\ProgramData\FAHClient\cores/fahcore-a8-win-64bit-avx2_256-0.0.12/FahCore_a8.exe -dir 8YuG1LoNPvYb66dexV3aSpbvvNY8JKyIsJzDI9lHdvE -suffix 01 -version 8.4.9 -lifeline 21296 -np 15
18:59:44:I3:WU503:Started FahCore on PID 11212
18:59:44:I1:WU503:*********************** Log Started 2025-08-11T18:59:44Z ***********************
18:59:44:I1:WU503:************************** Gromacs Folding@home Core ***************************
18:59:44:I1:WU503:       Core: Gromacs
18:59:44:I1:WU503:       Type: 0xa8
18:59:44:I1:WU503:    Version: 0.0.12
18:59:44:I1:WU503:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:59:44:I1:WU503:  Copyright: 2020 foldingathome.org
18:59:44:I1:WU503:   Homepage: https://foldingathome.org/
18:59:44:I1:WU503:       Date: Jan 16 2021
18:59:44:I1:WU503:       Time: 12:29:40
18:59:44:I1:WU503:   Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
18:59:44:I1:WU503:     Branch: master
18:59:44:I1:WU503:   Compiler: Visual C++ 2019 16.7
18:59:44:I1:WU503:    Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
18:59:44:I1:WU503:   Platform: win32 10
18:59:44:I1:WU503:       Bits: 64
18:59:44:I1:WU503:       Mode: Release
18:59:44:I1:WU503:       SIMD: avx2_256
18:59:44:I1:WU503:     OpenMP: ON
18:59:44:I1:WU503:       CUDA: OFF
18:59:44:I1:WU503:       Args: -dir 8YuG1LoNPvYb66dexV3aSpbvvNY8JKyIsJzDI9lHdvE -suffix 01
18:59:44:I1:WU503:             -version 8.4.9 -lifeline 21296 -np 15
18:59:44:I1:WU503:************************************ libFAH ************************************
18:59:44:I1:WU503:       Time: 11:24:13
18:59:44:I1:WU503:************************************ CBang *************************************
18:59:44:I1:WU503:       Time: 11:23:53
18:59:44:I1:WU503:************************************ System ************************************
18:59:44:I1:WU503:        CPU: AMD Ryzen 7 8700F 8-Core Processor
18:59:44:I1:WU503:     CPU ID: AuthenticAMD Family 25 Model 117 Stepping 2
18:59:44:I1:WU503:       CPUs: 16
18:59:44:I1:WU503:     Memory: 15.60GiB
18:59:44:I1:WU503:Free Memory: 8.41GiB
18:59:44:I1:WU503:    Threads: WINDOWS_THREADS
18:59:44:I1:WU503: OS Version: 6.2
18:59:44:I1:WU503:Has Battery: false
18:59:44:I1:WU503: On Battery: false
18:59:44:I1:WU503: UTC Offset: -4
18:59:44:I1:WU503:        PID: 11212
18:59:44:I1:WU503:        CWD: C:\ProgramData\FAHClient\work
18:59:44:I1:WU503:********************************************************************************
18:59:44:I1:WU503:Project: 12486 (Run 1, Clone 22, Gen 158)
18:59:44:I1:WU503:Unit: 0x00000000000000000000000000000000
18:59:44:I1:WU503:Digital signatures verified
18:59:44:I1:WU503:Calling: mdrun -c frame158.gro -s frame158.tpr -x frame158.xtc -cpi state.cpt -cpt 5 -nt 15 -ntmpi 1
18:59:44:I1:WU503:Steps: first=79000000 total=79500000
18:59:46:I1:WU504:Requesting WU assignment for user Martin_r7-8700f+RTX5060Ti team 96377
18:59:46:I1:WU503:Completed 272502 out of 500000 steps (54%)
18:59:53:I1:OUT229:> POST https://assign3.foldingathome.org/api/assign HTTP/1.1
18:59:54:I1:OUT229:< HTTP/1.1 503 HTTP_SERVICE_UNAVAILABLE
18:59:54:E :OUT229:HTTP_SERVICE_UNAVAILABLE: {"error":"No appropriate assignment"}
18:59:54:I1:WU504:Retry #2 in 4 secs
18:59:58:I1:WU504:Requesting WU assignment for user Martin_r7-8700f+RTX5060Ti team 96377
18:59:58:I1:OUT230:> POST https://assign4.foldingathome.org/api/assign HTTP/1.1
18:59:59:I1:OUT230:< HTTP/1.1 503 HTTP_SERVICE_UNAVAILABLE
18:59:59:E :OUT230:HTTP_SERVICE_UNAVAILABLE: {"error":"No appropriate assignment"}
18:59:59:I1:WU504:Retry #3 in 8 secs
19:00:07:I1:WU504:Requesting WU assignment for user Martin_r7-8700f+RTX5060Ti team 96377
19:00:07:I1:OUT231:> POST https://assign5.foldingathome.org/api/assign HTTP/1.1
19:00:07:I1:OUT231:< HTTP/1.1 503 HTTP_SERVICE_UNAVAILABLE
19:00:07:E :OUT231:HTTP_SERVICE_UNAVAILABLE: {"error":"No appropriate assignment"}
19:00:07:I1:WU504:Retry #4 in 16 secs
19:00:20:I1:OUT227:< HTTP/1.1 200 HTTP_OK
19:00:20:I1:WU502:Credited
19:00:23:I1:WU504:Requesting WU assignment for user Martin_r7-8700f+RTX5060Ti team 96377
19:00:23:I1:OUT232:> POST https://assign6.foldingathome.org/api/assign HTTP/1.1
19:00:23:I1:OUT232:< HTTP/1.1 503 HTTP_SERVICE_UNAVAILABLE
19:00:23:E :OUT232:HTTP_SERVICE_UNAVAILABLE: {"error":"No appropriate assignment"}
19:00:23:I1:WU504:Retry #5 in 32 secs
19:00:55:I1:WU504:Requesting WU assignment for user Martin_r7-8700f+RTX5060Ti team 96377
19:00:55:I1:OUT233:> POST https://assign1.foldingathome.org/api/assign HTTP/1.1
19:00:56:I1:OUT233:< HTTP/1.1 503 HTTP_SERVICE_UNAVAILABLE
19:00:56:E :OUT233:HTTP_SERVICE_UNAVAILABLE: {"error":"No appropriate assignment"}
19:00:56:I1:WU504:Retry #6 in 1 min 4 secs
19:00:58:I1:WU503:Completed 275000 out of 500000 steps (55%)
19:02:00:I1:WU504:Requesting WU assignment for user Martin_r7-8700f+RTX5060Ti team 96377
19:02:00:I1:OUT234:> POST https://assign2.foldingathome.org/api/assign HTTP/1.1
19:02:00:I1:OUT234:< HTTP/1.1 503 HTTP_SERVICE_UNAVAILABLE
19:02:00:E :OUT234:HTTP_SERVICE_UNAVAILABLE: {"error":"No appropriate assignment"}
19:02:00:I1:WU504:Retry #7 in 2 mins 8 secs
19:03:20:I1:WU503:Completed 280000 out of 500000 steps (56%)
19:04:08:I1:WU504:Requesting WU assignment for user Martin_r7-8700f+RTX5060Ti team 96377
19:04:08:I1:OUT235:> POST https://assign3.foldingathome.org/api/assign HTTP/1.1
19:04:08:I1:OUT235:< HTTP/1.1 503 HTTP_SERVICE_UNAVAILABLE
19:04:08:E :OUT235:HTTP_SERVICE_UNAVAILABLE: {"error":"No appropriate assignment"}
19:04:08:I1:WU504:Retry #8 in 4 mins 16 secs
19:05:42:I1:WU503:Completed 285000 out of 500000 steps (57%)
19:08:03:I1:WU503:Completed 290000 out of 500000 steps (58%)
19:08:24:I1:WU504:Requesting WU assignment for user Martin_r7-8700f+RTX5060Ti team 96377
19:08:24:I1:OUT236:> POST https://assign4.foldingathome.org/api/assign HTTP/1.1
19:08:25:I1:OUT236:< HTTP/1.1 503 HTTP_SERVICE_UNAVAILABLE
19:08:25:E :OUT236:HTTP_SERVICE_UNAVAILABLE: {"error":"No appropriate assignment"}
19:08:25:I1:WU504:Retry #9 in 8 mins 32 secs
19:10:24:I1:WU503:Completed 295000 out of 500000 steps (59%)
19:12:45:I1:WU503:Completed 300000 out of 500000 steps (60%)
19:15:06:I1:WU503:Completed 305000 out of 500000 steps (61%)
19:16:57:I1:WU504:Requesting WU assignment for user Martin_r7-8700f+RTX5060Ti team 96377
19:16:57:I1:OUT237:> POST https://assign5.foldingathome.org/api/assign HTTP/1.1
19:16:57:I1:OUT237:< HTTP/1.1 503 HTTP_SERVICE_UNAVAILABLE
19:16:57:E :OUT237:HTTP_SERVICE_UNAVAILABLE: {"error":"No appropriate assignment"}
19:16:57:I1:WU504:Retry #10 in 8 mins 32 secs
19:17:27:I1:WU503:Completed 310000 out of 500000 steps (62%)
19:19:49:I1:WU503:Completed 315000 out of 500000 steps (63%)
19:22:09:I1:WU503:Completed 320000 out of 500000 steps (64%)
19:24:30:I1:WU503:Completed 325000 out of 500000 steps (65%)
19:25:29:I1:WU504:Requesting WU assignment for user Martin_r7-8700f+RTX5060Ti team 96377
19:25:29:I1:OUT238:> POST https://assign6.foldingathome.org/api/assign HTTP/1.1
19:25:29:I1:OUT238:< HTTP/1.1 503 HTTP_SERVICE_UNAVAILABLE
19:25:29:E :OUT238:HTTP_SERVICE_UNAVAILABLE: {"error":"No appropriate assignment"}
19:25:29:I1:WU504:Retry #11 in 8 mins 32 secs
I have noticed this has hapened 3 or 4 times in the past 24-36 hours.
Post by muziqaz »
FAH Omega tester
Mactin
Post by Mactin »
musiqaz, your link points here !!!!
Post by muziqaz »
Mactin wrote: Mon Aug 11, 2025 8:25 pm musiqaz, your link points here !!!!
I know, because the answer to your query is above your post :P
FAH Omega tester
arisu
Post by arisu »
"No Appropriate Assignment" means that there is no work available for your particular system configuration. This can be caused by a work unit shortage for your particular hardware.
Mactin
Post by Mactin »
muziqaz wrote: Mon Aug 11, 2025 8:30 pm I know, because the answer to your query is above your post :P
I don't get it !
Post by muziqaz »
Mactin wrote: Mon Aug 11, 2025 9:09 pm
I don't get it !
What's not to get? I wrote that there is shortage of WUs right now.
Next post was your stating that you have similar problem. I thought you didn't read the comments before you, so I linked to my post, which explains what is the issue
FAH Omega tester
Mactin
Post by Mactin »
musiqaz,
I simply supported Peter, in stating that I had the same problem.
If one person or many have the same problem, it's a different situation.
Instaead of replying sarcastically with a no link link, saying nothing or simply ackoliging me would have been better.
Or, your original response to Peter could have providing a better explanation that would not have led me to support the original post.
The log files provide just enough information sometimes to generate more interrogations. This combined with empirical experience to question the validity of a "shortshr of WUs" as a valid answer. The 3 times I noticed the problem, I rebooted my computer and immediately got a WU, leading me to question the validity of the "shortage" answer.
I'l stop now, ,I don't want to start ranting.
I am trying to provide constructive criticism
arisu
Post by arisu »
There are some existing bugs in the v8 client where changes to configuration won't actually apply until the client is restarted, so sometimes you can get stuck in an assign wait loop until you restart the client.
Peter
Post by Peter »
Thanks all for your replies.
I see I'm not the only one having these logs. That's reassuring for me.
I'll also try the restarting tip and see if that works with me in case it happens again.
I really want to contribute to Folding (and before that to medical research from World Community Grid), because
I've lost many friends and family to cancer (and partly Alzheimer). So whenever the programm isn't running I'm frantically trying to remedy that :D
Post by muziqaz »
It should go back to normal soon enough ;)
FAH Omega tester
