Why doesn't Windows client log upload and download progress?
Schrödinger's cat
Hardware configuration: NVIDIA RTX 4080 Super
20 x Raspberry Pi 5 Model B 2GB RAM
Post by Schrödinger's cat »
Why do my RPi's log the download and upload progress, but my Windows PC (GPU only) doesn't?
Re: Why doesn't Windows client log upload and download progress?
There's probably no work available for RPis ... they can barely make the deadlines and FAH don't assign to clients with less than 3 CPU threads.
Unless it's a RPi 5 which is the only one that could make the deadlines, don't bother with it ...
Post by calxalot »
For 8.4.9 and earlier, only Linux will log up/download progress.
https://github.com/FoldingAtHome/fah-cl ... issues/130
Schrödinger's cat
calxalot wrote: Mon Aug 04, 2025 4:01 pm For 8.4.9 and earlier, only Linux will log up/download progress.
Thanks calxalot.
toTOW wrote: Mon Aug 04, 2025 2:24 pm There's probably no work available for RPis ... they can barely make the deadlines and FAH don't assign to clients with less than 3 CPU threads.
toTow, I'd suggest you check the Hardware configuration before commenting next time.
Schrödinger's cat wrote: Mon Aug 04, 2025 4:48 pm toTOW, I'd suggest you check the Hardware configuration before commenting next time.
Wow, some is using this field ! :roll:
The other part of my comment still applies.
Schrödinger's cat
I've just discovered that version 7.6.21 logs the upload and download progress (in Windows)!
