web/control does not show any activity on system-d-less OS
nada391
Post by nada391 »
Hello ,
i have several computer running OS Linux without system-d.
when on those go to
https://v8-4.foldingathome.org/machines
there is shown the correct count of "machines"
however GPU and CPU is showing 0 and no folding activity, although it is folding as shown on other pc.
why is that so?
https://ibb.co/LDqbqVQz
Re: web/control does not show any activity on system-d-less OS
Post by calxalot »
You will need to build 8.4.9 yourself on a machine without systemd.
https://github.com/FoldingAtHome/fah-cl ... /README.md
The installer package won’t work either because it assumes systemd.
nada391
Post by nada391 »
thanks, issue is that i don't have the package installed ,
but am logged into the browser with correct credentials and just want to consult the progress.
do you say i need to install the fahclient in order to be able to correctly retrieve the webdata?
on another computer (with kubuntu, reliant on system-d) , which also has the fahclient not installed, i am correctly able to retrieve the progress-data via webbrowser.
Post by calxalot »
You don’t need to install. You just need to have the client running with your account-token in the config.xml in the current working directory of the client.
Post by calxalot »
I don’t think the downloaded client will run without the linked systemd libs.
Nicolas_orleans
Post by Nicolas_orleans »
You don't need systemd with the tarball
wget https://download.foldingathome.org/releases/public/fah-client/debian-10-64bit/release/fah-client_8.4.9-64bit-release.tar.bz2
tar xf fah-client_8.4.9-64bit-release.tar.bz2
cd fah-client_8.4.9-64bit-release
./fah-client --log=/var/log/fah-client/log.txt --log-rotate-dir=/var/log/fah-client/ --account-token=YOURACCOUNTTOKEN --machine-name="YOURRIGNAME" --user=YOURUSERNAME --team=YOURTEAMNUMBER --passkey=YOURPASSKEY
And it will run from the terminal, without being installed as a service... If I remember correctly you don't even need to be a sudoer with the tarball install.
AORUS Elite X AX B650E- Ryzen 9 9950X - Inno3D RTX 5080 - Ubuntu 25.04 - 6.14 kernel - 580.95
MSI MPG B550 - Ryzen 5 5600X - PNY RTX 4080 Super - Ubuntu 25.04 - 6.14 kernel - 580.95
Post by calxalot »
Have you tested the tarball without systemd?
My understanding is that the client is hard linked to one or two libs, such as libsystemd-login
Nicolas_orleans
It works on vast.ai that has no systemd available (to my knowledge). Let's see if it works for nada391...
nada391
Post by nada391 »
Nicolas_orleans wrote: Mon Jul 28, 2025 8:05 pm You don't need systemd with the tarball
hello ,
tried this, bit cumbersome, since am already aloggid in with the webbrowser, via email/password.
now it simply showed up another machine (the current laptop), but the other ones that are folding are not being shown with the current activity.
https://ibb.co/LXWt2frh
05:12:56:I1:****************************** CBang ******************************
05:12:56:I1:    Version: 1.7.2
05:12:56:I1:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
05:12:56:I1:        Org: Cauldron Development
05:12:56:I1:  Copyright: Cauldron Development, 2003-2024
05:12:56:I1:   Homepage: https://cauldrondevelopment.com/
05:12:56:I1:    License: LGPL-2.1-or-later
05:12:56:I1:       Date: Nov 19 2024
05:12:56:I1:       Time: 21:54:38
05:12:56:I1:   Revision: 443c54e909eb8d8994405a18fb328b5b05a623a5
05:12:56:I1:     Branch: master
05:12:56:I1:   Compiler: GNU 8.3.0
05:12:56:I1:    Options: -Wsuggest-override -faligned-new -std=c++17 -fsigned-char
05:12:56:I1:             -ffunction-sections -fdata-sections -O3 -funroll-loops -fno-pie
05:12:56:I1:             -fPIC
05:12:56:I1:   Platform: linux 4.19.0-27-cloud-amd64
05:12:56:I1:       Bits: 64
05:12:56:I1:       Mode: Release
05:12:56:I1:***************************** System ******************************
05:12:56:I1:        CPU: AMD PRO A12-8830B R7, 10 COMPUTE CORES 4C+6G
05:12:56:I1:     CPU ID: AuthenticAMD Family 21 Model 101 Stepping 1
05:12:56:I1:       CPUs: 4
05:12:56:I1:     Memory: 14.55GiB
05:12:56:I1:Free Memory: 7.56GiB
05:12:56:I1: OS Version: 6.1
05:12:56:I1:Has Battery: true
05:12:56:I1: On Battery: false
05:12:56:I1:   Hostname: devuan
05:12:56:I1: UTC Offset: 2
05:12:56:I1:        PID: 28345
05:12:56:I1:        CWD: /home/rich/fah-client_8.4.9-64bit-release
05:12:56:I1:       Exec: /home/rich/fah-client_8.4.9-64bit-release/fah-client
05:12:56:I1:*******************************************************************
05:12:56:I2:<config/>
05:12:56:I1:Opening Database
05:12:56:E :Exception: Machine ID not available
05:12:56:I1:Generating RSA key.............................++++-..........++++-
05:12:57:I1:F@H ID = iYLptPY36ZPoonwxjkWA03TBgvyPjA3ypXpyB5FassQ
05:12:57:I3:Loading default resource group
05:12:57:I1:Listening for HTTP on 127.0.0.1:7396
05:12:57:I3:Loaded 0 wus.
05:12:57:I1:OUT1:> PUT https://api.foldingathome.org/machine/iYLptPY36ZPoonwxjkWA03TBgvyPjA3ypXpyB5FassQ HTTP/1.1
05:12:57:I1:OUT2:> GET https://api.foldingathome.org/gpus HTTP/1.1
05:12:58:I1:OUT1:< HTTP/1.1 200 HTTP_OK
05:12:58:I1:Account linked
05:12:58:I1:OUT3:> GET https://api.foldingathome.org/machine/iYLptPY36ZPoonwxjkWA03TBgvyPjA3ypXpyB5FassQ HTTP/1.1
05:12:59:I1:OUT3:< HTTP/1.1 200 HTTP_OK
05:12:59:I1:OUT5:> GET wss://node1.foldingathome.org/ws/client HTTP/1.1
05:13:00:I1:OUT2:< HTTP/1.1 200 HTTP_OK
05:13:00:I3:gpus = {
05:13:00:I3:  "gpu:00:01:00": {"vendor": 4098, "device": 39028, "type": "amd", "supported": false, "description": "Carrizo [Radeon R5/R6/R7 Series]"}
05:13:00:I3:}
05:13:00:I1:OUT5:< HTTP/1.1 101 HTTP_SWITCHING_PROTOCOLS
05:13:00:I1:Logging into node account
05:13:01:I1:Account websocket closed: UNACCEPTABLE msg=
05:13:01:I1:OUT6:> GET https://api.foldingathome.org/machine/iYLptPY36ZPoonwxjkWA03TBgvyPjA3ypXpyB5FassQ HTTP/1.1
05:13:02:I1:OUT6:< HTTP/1.1 200 HTTP_OK
05:13:02:I1:OUT5:> GET wss://node1.foldingathome.org/ws/client HTTP/1.1
05:13:03:I1:OUT5:< HTTP/1.1 101 HTTP_SWITCHING_PROTOCOLS
05:13:03:I1:Logging into node account
05:13:03:I1:Account websocket closed: UNACCEPTABLE msg=
05:13:03:I1:OUT7:> GET https://api.foldingathome.org/machine/iYLptPY36ZPoonwxjkWA03TBgvyPjA3ypXpyB5FassQ HTTP/1.1
05:13:05:I1:OUT7:< HTTP/1.1 200 HTTP_OK
05:13:05:I1:OUT5:> GET wss://node1.foldingathome.org/ws/client HTTP/1.1
05:13:06:I1:OUT5:< HTTP/1.1 101 HTTP_SWITCHING_PROTOCOLS
05:13:06:I1:Logging into node account
05:13:06:I1:Account websocket closed: UNACCEPTABLE msg=
05:13:06:I1:OUT8:> GET https://api.foldingathome.org/machine/iYLptPY36ZPoonwxjkWA03TBgvyPjA3ypXpyB5FassQ HTTP/1.1
05:13:07:I1:OUT8:< HTTP/1.1 200 HTTP_OK
05:13:07:I1:OUT5:> GET wss://node1.foldingathome.org/ws/client HTTP/1.1
05:13:08:I1:OUT5:< HTTP/1.1 101 HTTP_SWITCHING_PROTOCOLS
05:13:08:I1:Logging into node account
05:13:09:I1:Account websocket closed: UNACCEPTABLE msg=
05:13:09:I1:OUT9:> GET https://api.foldingathome.org/machine/iYLptPY36ZPoonwxjkWA03TBgvyPjA3ypXpyB5FassQ HTTP/1.1
05:13:10:I1:OUT9:< HTTP/1.1 200 HTTP_OK
05:13:10:I1:OUT5:> GET wss://node1.foldingathome.org/ws/client HTTP/1.1
05:13:11:I1:OUT5:< HTTP/1.1 101 HTTP_SWITCHING_PROTOCOLS
05:13:11:I1:Logging into node account
05:13:11:I1:Account websocket closed: UNACCEPTABLE msg=
05:13:11:I1:OUT10:> GET https://api.foldingathome.org/machine/iYLptPY36ZPoonwxjkWA03TBgvyPjA3ypXpyB5FassQ HTTP/1.1
05:13:13:I1:OUT10:< HTTP/1.1 200 HTTP_OK
05:13:13:I1:OUT5:> GET wss://node1.foldingathome.org/ws/client HTTP/1.1
05:13:13:I1:OUT5:< HTTP/1.1 101 HTTP_SWITCHING_PROTOCOLS
05:13:13:I1:Logging into node account
05:13:14:I1:Account websocket closed: UNACCEPTABLE msg=
05:13:14:I1:OUT11:> GET https://api.foldingathome.org/machine/iYLptPY36ZPoonwxjkWA03TBgvyPjA3ypXpyB5FassQ HTTP/1.1
05:13:15:I1:OUT11:< HTTP/1.1 200 HTTP_OK
05:13:15:I1:OUT5:> GET wss://node1.foldingathome.org/ws/client HTTP/1.1
05:13:16:I1:OUT5:< HTTP/1.1 101 HTTP_SWITCHING_PROTOCOLS
05:13:16:I1:Logging into node account
05:13:16:I1:Account websocket closed: UNACCEPTABLE msg=
05:13:17:I1:OUT12:> GET https://api.foldingathome.org/machine/iYLptPY36ZPoonwxjkWA03TBgvyPjA3ypXpyB5FassQ HTTP/1.1
05:13:18:I1:OUT12:< HTTP/1.1 200 HTTP_OK
05:13:18:I1:OUT5:> GET wss://node1.foldingathome.org/ws/client HTTP/1.1
05:13:19:I1:OUT5:< HTTP/1.1 101 HTTP_SWITCHING_PROTOCOLS
05:13:19:I1:Logging into node account
05:13:19:I1:Account websocket closed: UNACCEPTABLE msg=
05:13:19:I1:OUT13:> GET https://api.foldingathome.org/machine/iYLptPY36ZPoonwxjkWA03TBgvyPjA3ypXpyB5FassQ HTTP/1.1
05:13:20:I1:OUT13:< HTTP/1.1 200 HTTP_OK
05:13:20:I1:OUT5:> GET wss://node1.foldingathome.org/ws/client HTTP/1.1
05:13:21:I1:OUT5:< HTTP/1.1 101 HTTP_SWITCHING_PROTOCOLS
05:13:21:I1:Logging into node account
05:13:22:I1:Account websocket closed: UNACCEPTABLE msg=
05:13:22:I1:OUT14:> GET https://api.foldingathome.org/machine/iYLptPY36ZPoonwxjkWA03TBgvyPjA3ypXpyB5FassQ HTTP/1.1
05:13:23:I1:OUT14:< HTTP/1.1 200 HTTP_OK
05:13:23:I1:OUT5:> GET wss://node1.foldingathome.org/ws/client HTTP/1.1
05:13:24:I1:OUT5:< HTTP/1.1 101 HTTP_SWITCHING_PROTOCOLS
05:13:24:I1:Logging into node account
05:13:24:I1:Account websocket closed: UNACCEPTABLE msg=
05:13:24:I1:OUT15:> GET https://api.foldingathome.org/machine/iYLptPY36ZPoonwxjkWA03TBgvyPjA3ypXpyB5FassQ HTTP/1.1
05:13:25:I1:OUT15:< HTTP/1.1 200 HTTP_OK
05:13:25:I1:OUT5:> GET wss://node1.foldingathome.org/ws/client HTTP/1.1
05:13:26:I1:OUT5:< HTTP/1.1 101 HTTP_SWITCHING_PROTOCOLS
05:13:26:I1:Logging into node account
05:13:27:I1:Account websocket closed: UNACCEPTABLE msg=
05:13:27:I1:OUT16:> GET https://api.foldingathome.org/machine/iYLptPY36ZPoonwxjkWA03TBgvyPjA3ypXpyB5FassQ HTTP/1.1
05:13:28:I1:OUT16:< HTTP/1.1 200 HTTP_OK
05:13:28:I1:OUT5:> GET wss://node1.foldingathome.org/ws/client HTTP/1.1
05:13:29:I1:OUT5:< HTTP/1.1 101 HTTP_SWITCHING_PROTOCOLS
05:13:29:I1:Logging into node account
05:13:29:I1:Account websocket closed: UNACCEPTABLE msg=
05:13:29:I1:OUT17:> GET https://api.foldingathome.org/machine/iYLptPY36ZPoonwxjkWA03TBgvyPjA3ypXpyB5FassQ HTTP/1.1
05:13:31:I1:OUT17:< HTTP/1.1 200 HTTP_OK
05:13:31:I1:OUT5:> GET wss://node1.foldingathome.org/ws/client HTTP/1.1
05:13:31:I1:OUT5:< HTTP/1.1 101 HTTP_SWITCHING_PROTOCOLS
05:13:31:I1:Logging into node account
05:13:32:I1:Account websocket closed: UNACCEPTABLE msg=
05:13:32:I1:OUT18:> GET https://api.foldingathome.org/machine/iYLptPY36ZPoonwxjkWA03TBgvyPjA3ypXpyB5FassQ HTTP/1.1
05:13:33:I1:OUT18:< HTTP/1.1 200 HTTP_OK
05:13:33:I1:OUT5:> GET wss://node1.foldingathome.org/ws/client HTTP/1.1
05:13:34:I1:OUT5:< HTTP/1.1 101 HTTP_SWITCHING_PROTOCOLS
05:13:34:I1:Logging into node account
05:13:34:I1:Account websocket closed: UNACCEPTABLE msg=
05:13:34:I1:OUT19:> GET https://api.foldingathome.org/machine/iYLptPY36ZPoonwxjkWA03TBgvyPjA3ypXpyB5FassQ HTTP/1.1
05:13:36:I1:OUT19:< HTTP/1.1 200 HTTP_OK
05:13:36:I1:OUT5:> GET wss://node1.foldingathome.org/ws/client HTTP/1.1
05:13:36:I1:OUT5:< HTTP/1.1 101 HTTP_SWITCHING_PROTOCOLS
05:13:36:I1:Logging into node account
05:13:37:I1:Account websocket closed: UNACCEPTABLE msg=
05:13:37:I1:OUT20:> GET https://api.foldingathome.org/machine/iYLptPY36ZPoonwxjkWA03TBgvyPjA3ypXpyB5FassQ HTTP/1.1
05:13:38:I1:OUT20:< HTTP/1.1 200 HTTP_OK
05:13:38:I1:OUT5:> GET wss://node1.foldingathome.org/ws/client HTTP/1.1
05:13:39:I1:OUT5:< HTTP/1.1 101 HTTP_SWITCHING_PROTOCOLS
05:13:39:I1:Logging into node account
05:13:39:I1:Account websocket closed: UNACCEPTABLE msg=
05:13:40:I1:OUT21:> GET https://api.foldingathome.org/machine/iYLptPY36ZPoonwxjkWA03TBgvyPjA3ypXpyB5FassQ HTTP/1.1
05:13:41:I1:OUT21:< HTTP/1.1 200 HTTP_OK
05:13:41:I1:OUT5:> GET wss://node1.foldingathome.org/ws/client HTTP/1.1
05:13:42:I1:OUT5:< HTTP/1.1 101 HTTP_SWITCHING_PROTOCOLS
05:13:42:I1:Logging into node account
05:13:42:I1:Account websocket closed: UNACCEPTABLE msg=
05:13:42:I1:OUT22:> GET https://api.foldingathome.org/machine/iYLptPY36ZPoonwxjkWA03TBgvyPjA3ypXpyB5FassQ HTTP/1.1
05:13:43:I1:OUT22:< HTTP/1.1 200 HTTP_OK
05:13:44:I1:OUT5:> GET wss://node1.foldingathome.org/ws/client HTTP/1.1
05:13:44:I1:OUT5:< HTTP/1.1 101 HTTP_SWITCHING_PROTOCOLS
05:13:44:I1:Logging into node account
05:13:45:I1:Account websocket closed: UNACCEPTABLE msg=
05:13:45:I1:OUT23:> GET https://api.foldingathome.org/machine/iYLptPY36ZPoonwxjkWA03TBgvyPjA3ypXpyB5FassQ HTTP/1.1
05:13:46:I1:OUT23:< HTTP/1.1 200 HTTP_OK
05:13:46:I1:OUT5:> GET wss://node1.foldingathome.org/ws/client HTTP/1.1
05:13:47:I1:OUT5:< HTTP/1.1 101 HTTP_SWITCHING_PROTOCOLS
05:13:47:I1:Logging into node account
05:13:47:I1:Account websocket closed: UNACCEPTABLE msg=
05:13:47:I1:OUT24:> GET https://api.foldingathome.org/machine/iYLptPY36ZPoonwxjkWA03TBgvyPjA3ypXpyB5FassQ HTTP/1.1
05:13:49:I1:OUT24:< HTTP/1.1 200 HTTP_OK
05:13:49:I1:OUT5:> GET wss://node1.foldingathome.org/ws/client HTTP/1.1
05:13:49:I1:OUT5:< HTTP/1.1 101 HTTP_SWITCHING_PROTOCOLS
05:13:49:I1:Logging into node account
05:13:50:I1:Account websocket closed: UNACCEPTABLE msg=
05:13:50:I1:OUT25:> GET https://api.foldingathome.org/machine/iYLptPY36ZPoonwxjkWA03TBgvyPjA3ypXpyB5FassQ HTTP/1.1
05:13:51:I1:OUT25:< HTTP/1.1 200 HTTP_OK
05:13:51:I1:OUT5:> GET wss://node1.foldingathome.org/ws/client HTTP/1.1
05:13:52:I1:OUT5:< HTTP/1.1 101 HTTP_SWITCHING_PROTOCOLS
05:13:52:I1:Logging into node account
05:13:53:I1:Account websocket closed: UNACCEPTABLE msg=
05:13:53:I1:OUT26:> GET https://api.foldingathome.org/machine/iYLptPY36ZPoonwxjkWA03TBgvyPjA3ypXpyB5FassQ HTTP/1.1
05:13:54:I1:OUT26:< HTTP/1.1 200 HTTP_OK
05:13:54:I1:OUT5:> GET wss://node1.foldingathome.org/ws/client HTTP/1.1
05:13:55:I1:OUT5:< HTTP/1.1 101 HTTP_SWITCHING_PROTOCOLS
05:13:55:I1:Logging into node account
05:13:55:I1:Account websocket closed: UNACCEPTABLE msg=
05:13:55:I1:OUT27:> GET https://api.foldingathome.org/machine/iYLptPY36ZPoonwxjkWA03TBgvyPjA3ypXpyB5FassQ HTTP/1.1
05:13:57:I1:OUT27:< HTTP/1.1 200 HTTP_OK
05:13:57:I1:OUT5:> GET wss://node1.foldingathome.org/ws/client HTTP/1.1
05:13:58:I1:OUT5:< HTTP/1.1 101 HTTP_SWITCHING_PROTOCOLS
05:13:58:I1:Logging into node account
05:13:58:I1:Account websocket closed: UNACCEPTABLE msg=
05:13:58:I1:OUT28:> GET https://api.foldingathome.org/machine/iYLptPY36ZPoonwxjkWA03TBgvyPjA3ypXpyB5FassQ HTTP/1.1
05:13:59:I1:OUT28:< HTTP/1.1 200 HTTP_OK
05:13:59:I1:OUT5:> GET wss://node1.foldingathome.org/ws/client HTTP/1.1
05:14:00:I1:OUT5:< HTTP/1.1 101 HTTP_SWITCHING_PROTOCOLS
05:14:00:I1:Logging into node account
05:14:01:I1:Account websocket closed: UNACCEPTABLE msg=
05:14:01:I1:OUT29:> GET https://api.foldingathome.org/machine/iYLptPY36ZPoonwxjkWA03TBgvyPjA3ypXpyB5FassQ HTTP/1.1
05:14:02:I1:OUT29:< HTTP/1.1 200 HTTP_OK
05:14:02:I1:OUT5:> GET wss://node1.foldingathome.org/ws/client HTTP/1.1
05:14:03:I1:OUT5:< HTTP/1.1 101 HTTP_SWITCHING_PROTOCOLS
05:14:03:I1:Logging into node account
05:14:03:I1:Account websocket closed: UNACCEPTABLE msg=
05:14:04:I1:OUT30:> GET https://api.foldingathome.org/machine/iYLptPY36ZPoonwxjkWA03TBgvyPjA3ypXpyB5FassQ HTTP/1.1
05:14:05:I1:OUT30:< HTTP/1.1 200 HTTP_OK
05:14:05:I1:OUT5:> GET wss://node1.foldingathome.org/ws/client HTTP/1.1
05:14:06:I1:OUT5:< HTTP/1.1 101 HTTP_SWITCHING_PROTOCOLS
05:14:06:I1:Logging into node account
05:14:06:I1:Account websocket closed: UNACCEPTABLE msg=
05:14:06:I1:OUT31:> GET https://api.foldingathome.org/machine/iYLptPY36ZPoonwxjkWA03TBgvyPjA3ypXpyB5FassQ HTTP/1.1
05:14:07:I1:OUT31:< HTTP/1.1 200 HTTP_OK
05:14:08:I1:OUT5:> GET wss://node1.foldingathome.org/ws/client HTTP/1.1
05:14:08:I1:OUT5:< HTTP/1.1 101 HTTP_SWITCHING_PROTOCOLS
05:14:08:I1:Logging into node account
05:14:09:I1:Account websocket closed: UNACCEPTABLE msg=
05:14:09:I1:OUT32:> GET https://api.foldingathome.org/machine/iYLptPY36ZPoonwxjkWA03TBgvyPjA3ypXpyB5FassQ HTTP/1.1
05:14:10:I1:OUT32:< HTTP/1.1 200 HTTP_OK
05:14:10:I1:OUT5:> GET wss://node1.foldingathome.org/ws/client HTTP/1.1
05:14:11:I1:OUT5:< HTTP/1.1 101 HTTP_SWITCHING_PROTOCOLS
05:14:11:I1:Logging into node account
05:14:11:I1:Account websocket closed: UNACCEPTABLE msg=
05:14:12:I1:OUT33:> GET https://api.foldingathome.org/machine/iYLptPY36ZPoonwxjkWA03TBgvyPjA3ypXpyB5FassQ HTTP/1.1
05:14:13:I1:OUT33:< HTTP/1.1 200 HTTP_OK
05:14:13:I1:OUT5:> GET wss://node1.foldingathome.org/ws/client HTTP/1.1
05:14:14:I1:OUT5:< HTTP/1.1 101 HTTP_SWITCHING_PROTOCOLS
05:14:14:I1:Logging into node account
05:14:14:I1:Account websocket closed: UNACCEPTABLE msg=
05:14:14:I1:OUT34:> GET https://api.foldingathome.org/machine/iYLptPY36ZPoonwxjkWA03TBgvyPjA3ypXpyB5FassQ HTTP/1.1
05:14:16:I1:OUT34:< HTTP/1.1 200 HTTP_OK
05:14:16:I1:OUT5:> GET wss://node1.foldingathome.org/ws/client HTTP/1.1
05:14:16:I1:OUT5:< HTTP/1.1 101 HTTP_SWITCHING_PROTOCOLS
05:14:16:I1:Logging into node account
05:14:17:I1:Account websocket closed: UNACCEPTABLE msg=
05:14:17:I1:OUT35:> GET https://api.foldingathome.org/machine/iYLptPY36ZPoonwxjkWA03TBgvyPjA3ypXpyB5FassQ HTTP/1.1
05:14:18:I1:OUT35:< HTTP/1.1 200 HTTP_OK
05:14:18:I1:OUT5:> GET wss://node1.foldingathome.org/ws/client HTTP/1.1
05:14:19:I1:OUT5:< HTTP/1.1 101 HTTP_SWITCHING_PROTOCOLS
05:14:19:I1:Logging into node account
05:14:20:I1:Account websocket closed: UNACCEPTABLE msg=
05:14:20:I1:OUT36:> GET https://api.foldingathome.org/machine/iYLptPY36ZPoonwxjkWA03TBgvyPjA3ypXpyB5FassQ HTTP/1.1
05:14:21:I1:OUT36:< HTTP/1.1 200 HTTP_OK
05:14:21:I1:OUT5:> GET wss://node1.foldingathome.org/ws/client HTTP/1.1
05:14:22:I1:OUT5:< HTTP/1.1 101 HTTP_SWITCHING_PROTOCOLS
05:14:22:I1:Logging into node account
05:14:22:I1:Account websocket closed: UNACCEPTABLE msg=
05:14:22:I1:OUT37:> GET https://api.foldingathome.org/machine/iYLptPY36ZPoonwxjkWA03TBgvyPjA3ypXpyB5FassQ HTTP/1.1
05:14:24:I1:OUT37:< HTTP/1.1 200 HTTP_OK
05:14:24:I1:OUT5:> GET wss://node1.foldingathome.org/ws/client HTTP/1.1
05:14:25:I1:OUT5:< HTTP/1.1 101 HTTP_SWITCHING_PROTOCOLS
05:14:25:I1:Logging into node account
05:14:25:I1:Account websocket closed: UNACCEPTABLE msg=
05:14:25:I1:OUT38:> GET https://api.foldingathome.org/machine/iYLptPY36ZPoonwxjkWA03TBgvyPjA3ypXpyB5FassQ HTTP/1.1
05:14:26:I1:OUT38:< HTTP/1.1 200 HTTP_OK
05:14:26:I1:OUT5:> GET wss://node1.foldingathome.org/ws/client HTTP/1.1
05:14:27:I1:OUT5:< HTTP/1.1 101 HTTP_SWITCHING_PROTOCOLS
05:14:27:I1:Logging into node account
05:14:28:I1:Account websocket closed: UNACCEPTABLE msg=
05:14:28:I1:OUT39:> GET https://api.foldingathome.org/machine/iYLptPY36ZPoonwxjkWA03TBgvyPjA3ypXpyB5FassQ HTTP/1.1
05:14:29:I1:OUT39:< HTTP/1.1 200 HTTP_OK
05:14:29:I1:OUT5:> GET wss://node1.foldingathome.org/ws/client HTTP/1.1
05:14:30:I1:OUT5:< HTTP/1.1 101 HTTP_SWITCHING_PROTOCOLS
05:14:30:I1:Logging into node account
05:14:30:I1:Account websocket closed: UNACCEPTABLE msg=
05:14:30:I1:OUT40:> GET https://api.foldingathome.org/machine/iYLptPY36ZPoonwxjkWA03TBgvyPjA3ypXpyB5FassQ HTTP/1.1
05:14:32:I1:OUT40:< HTTP/1.1 200 HTTP_OK
05:14:32:I1:OUT5:> GET wss://node1.foldingathome.org/ws/client HTTP/1.1
05:14:32:I1:OUT5:< HTTP/1.1 101 HTTP_SWITCHING_PROTOCOLS
05:14:32:I1:Logging into node account
05:14:33:I1:Account websocket closed: UNACCEPTABLE msg=
05:14:33:I1:OUT41:> GET https://api.foldingathome.org/machine/iYLptPY36ZPoonwxjkWA03TBgvyPjA3ypXpyB5FassQ HTTP/1.1
05:14:34:I1:OUT41:< HTTP/1.1 200 HTTP_OK
05:14:34:I1:OUT5:> GET wss://node1.foldingathome.org/ws/client HTTP/1.1
05:14:35:I1:OUT5:< HTTP/1.1 101 HTTP_SWITCHING_PROTOCOLS
05:14:35:I1:Logging into node account
05:14:36:I1:Account websocket closed: UNACCEPTABLE msg=
05:14:36:I1:OUT42:> GET https://api.foldingathome.org/machine/iYLptPY36ZPoonwxjkWA03TBgvyPjA3ypXpyB5FassQ HTTP/1.1
05:14:37:I1:OUT42:< HTTP/1.1 200 HTTP_OK
05:14:37:I1:OUT5:> GET wss://node1.foldingathome.org/ws/client HTTP/1.1
05:14:38:I1:OUT5:< HTTP/1.1 101 HTTP_SWITCHING_PROTOCOLS
05:14:38:I1:Logging into node account
05:14:38:I1:Account websocket closed: UNACCEPTABLE msg=
05:14:38:I1:OUT43:> GET https://api.foldingathome.org/machine/iYLptPY36ZPoonwxjkWA03TBgvyPjA3ypXpyB5FassQ HTTP/1.1
05:14:40:I1:OUT43:< HTTP/1.1 200 HTTP_OK
05:14:40:I1:OUT5:> GET wss://node1.foldingathome.org/ws/client HTTP/1.1
05:14:40:I1:OUT5:< HTTP/1.1 101 HTTP_SWITCHING_PROTOCOLS
05:14:40:I1:Logging into node account
05:14:41:I1:Account websocket closed: UNACCEPTABLE msg=
^C05:14:41:I1:Clean exit
nada391
Post by nada391 »
the webview could not read the data from the other computer that are folding although i am logged in with correct credentials, which consider bit strange, but maybe we can solve this riddl.e
Nicolas_orleans
The log shows that the client is using the tarball folder, as intended, and the screenshot shows that you have a machine ready to fold. Please press fold so we know if it is working without systemd (your initial question)
Then, if you cannot see your other rigs, it could mean something is wrong with your credentials or token, but it's another issue
nada391
Post by nada391 »
yeh, the whole point of the exercise , is that i'd like to check on progress of the fah-folding
without the need to install fahclient on every computer in order to so;
since i am logged in correctly, don't see how i could easily mess up the credentials;
but as far i know, have not changed the passkey or token even inadvertently lately.
Either the non-system-d is mssing some features that prevents the retrieval of the data, or there is some flaw;
to my knowledge, on System-D Linux am able to retrieve the data correctly without needing to install the client;
Post by calxalot »
Web Control can run anywhere without a local client running. It can only see clients that are running and linked to your web control account.
nada391
Post by nada391 »
calxalot wrote: Tue Jul 29, 2025 11:36 pm Web Control can run anywhere without a local client running. It can only see clients that are running and linked to your web control account.
thanks,
there seems to be atleast one excaption to this rule
with OS Devuan Linux it would not function<
you can test easily with a live image should you want to verify
https://www.devuan.org/get-devuan
Post by calxalot »
No thanks. I don't seek to become a Linux expert.
Only thing I can think of is firewall or router issues.
Check logs of clients you cannot see. They may be unable to connect to some fah servers.
