No WUs available for this configuration
hymie
Post by hymie »
Greetings.
My FAH client is not getting any assignments. The error message is "No WUs available for this configuration"
I had a similar problem a year ago, and I was told it was an issue with "vav19" , which apparently doesn't exist any more, so I'm not sure where / how to ask for help or troubleshoot.
Is my machine just too old to be useful (to FAH) any more?
Here is the log from my most recent attempt.
% FAHClient
13:31:48:Read GPUs.txt
13:31:48:Removing old file 'logs/log-20210408-134651.txt'
13:31:48:******************************* libFAH ********************************
13:31:48:       Date: Oct 20 2020
13:31:48:       Time: 20:36:41
13:31:48:   Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
13:31:48:     Branch: master
13:31:48:   Compiler: GNU 4.9.4
13:31:48:    Options: -std=c++11 -fsigned-char -ffunction-sections -fdata-sections -O3
13:31:48:             -funroll-loops
13:31:48:   Platform: linux2 5.8.0-1-amd64
13:31:48:       Bits: 64
13:31:48:       Mode: Release
13:31:48:****************************** FAHClient ******************************
13:31:48:    Version: 7.6.21
13:31:48:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
13:31:48:  Copyright: 2020 foldingathome.org
13:31:48:   Homepage: https://foldingathome.org/
13:31:48:       Time: 20:38:59
13:31:48:   Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
13:31:48:       Bits: 64
13:31:48:     Config: /home/hymie/FoldingAtHome/config.xml
13:31:48:******************************** CBang ********************************
13:31:48:       Time: 18:38:01
13:31:48:   Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
13:31:48:             -funroll-loops -fPIC
13:31:48:       Bits: 64
13:31:48:******************************* System ********************************
13:31:48:        CPU: Intel(R) Core(TM) i5-1035G1 CPU @ 1.00GHz
13:31:48:     CPU ID: GenuineIntel Family 6 Model 126 Stepping 5
13:31:48:       CPUs: 8
13:31:48:     Memory: 7.46GiB
13:31:48:Free Memory: 962.88MiB
13:31:48:    Threads: POSIX_THREADS
13:31:48: OS Version: 5.11
13:31:48:Has Battery: true
13:31:48: On Battery: false
13:31:48: UTC Offset: -4
13:31:48:        PID: 1084
13:31:48:        CWD: /home/hymie/FoldingAtHome
13:31:48:         OS: Linux 5.11.6 x86_64
13:31:48:    OS Arch: AMD64
13:31:48:       GPUs: 0
13:31:48:       CUDA: Not detected: Failed to open dynamic library 'libcuda.so':
13:31:48:             libcuda.so: cannot open shared object file: No such file or
13:31:48:             directory
13:31:48:***********************************************************************
13:31:48:<config>
13:31:48:  <!-- HTTP Server -->
13:31:48:  <allow v='127.0.0.1 192.168.42.0/24'/>
13:31:48:
13:31:48:  <!-- Network -->
13:31:48:  <proxy v=':8080'/>
13:31:48:
13:31:48:  <!-- Remote Command Server -->
13:31:48:  <command-allow-no-pass v='127.0.0.1 192.168.42.0/24'/>
13:31:48:  <password v='*****'/>
13:31:48:
13:31:48:  <!-- User Information -->
13:31:48:  <passkey v='*****'/>
13:31:48:  <user v='hymie!'/>
13:31:48:
13:31:48:  <!-- Folding Slots -->
13:31:48:  <slot id='0' type='CPU'>
13:31:48:    <cpus v='2'/>
13:31:48:  </slot>
13:31:48:</config>
13:31:48:Trying to access database...
13:31:48:Successfully acquired database lock
13:31:48:FS00:Initialized folding slot 00: cpu:2
13:31:48:WU00:FS00:Connecting to assign1.foldingathome.org:80
13:31:49:WARNING:WU00:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
13:31:49:WU00:FS00:Connecting to assign2.foldingathome.org:80
13:31:50:WARNING:WU00:FS00:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
13:31:50:WU00:FS00:Connecting to assign3.foldingathome.org:80
13:31:51:WARNING:WU00:FS00:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
13:31:51:WU00:FS00:Connecting to assign4.foldingathome.org:80
13:31:51:WARNING:WU00:FS00:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
13:31:51:ERROR:WU00:FS00:Exception: Could not get an assignment
Re: No WUs available for this configuration
Post by muziqaz »
FAH requires minimum 3 CPU threads to be able to receive any work.
You are using 2 only for some reason. Your CPU seems to have 8 threads
FAH Omega tester
hymie
Post by hymie »
Thank you very much.
For some reason, I had
    <cpus v='8'/>
  </slot>
in my config.xml . Once I changed it to 8, it looks like I downloaded a work unit.
