Uploading WU Results Does Not Progress
Hum@n
Post by Hum@n »
Yesterday a WU completed, and uploading began. However, there has been no progress on the upload. Other WUs have completed and uploaded since then. There appears no obvious way to re-start the upload. Is there something that the end-user is supposed to do in this situation?
A search for "uploading" in this forum showed results that concerned DNS issues. That said, other WUs complete and upload without a problem. Another user completed the same WU and received credit, so the server itself can/could/did receive results (at least from that user).
Below are the entries from the log for that particular unit, starting with the completion of the steps:
20:11:49:I1:WU75:Completed 2475000 out of 2500000 steps (99%)
20:12:48:I1:WU75:Completed 2500000 out of 2500000 steps (100%)
20:12:48:I1:WU75:Saving result file ../logfile_01.txt
20:12:48:I1:WU75:Saving result file dhdl.xvg
20:12:48:I1:WU75:Saving result file frame569.gro
20:12:48:I1:WU75:Saving result file frame569.xtc
20:12:48:I1:WU75:Saving result file md.log
20:12:48:I1:WU75:Saving result file science.log
20:12:48:I1:WU75:Saving result file state.cpt
20:12:48:I1:WU75:Folding@home Core Shutdown: FINISHED_UNIT
20:12:49:I1:WU75:Core returned FINISHED_UNIT (100)
20:12:49:I1:WU75:Uploading WU results
Re: Uploading WU Results Does Not Progress
Hum@n wrote: Wed Jul 16, 2025 1:19 pmThere appears no obvious way to re-start the upload. Is there something that the end-user is supposed to do in this situation?
Restart the client or reboot the system.
On Windows, you could use TCP View tool to identify the stuck TCP connection and to kill it.
Hum@n
Post by Hum@n »
Thank you toTOW.
I shut down and restarted MacOS, and relaunched Folding@Home. The final two entries for in the log for WU75 now shows:
19:00:18:I1:WU75:Uploading WU results
19:00:23:I1:WU75:Credited
The work history shows that the work unit status is Failed. Since the log shows "Credited" and the history shows "Failed", there is perhaps nothing more to be done.
Thanks again for the advice to restart the client or reboot the system.
arisu
Post by arisu »
The reason the WU upload results doesn't progress is a known bug: https://github.com/FoldingAtHome/fah-cl ... issues/355
The reason the WU is marked in history as failed is another known bug: https://github.com/FoldingAtHome/fah-cl ... issues/352
In spite of the history marking it as failed, it was successfully credited and you got the points for it.
