New install of FAH client on Ubuntu -- idle ??
CinciRyan
Post by CinciRyan »
Hello! I'm a newb at installing FAH outside of Home Assistant, but decided to stand up another machine in a Proxmox LXC.
I finally got it running, with the help of a script that I found that fixes the dependencies.
The client starts, but it's not doing anything .. just sitting there.
I've looked at my DNS servers, and it hasn't even tried to talk.
I've stopped and started the client a number of times, but nothing.
I've had tail -f running against the log, but this is as far as it ever gets.
OS is Ubuntu 25.04
root@folding-at-home:/etc/fah-client# cat /var/log/fah-client/log.txt
*********************** Log Started 2025-06-30T20:43:50Z ***********************
20:43:50:I1:*********************** Folding@home Client ***********************
20:43:50:I1: Version: 8.4.9
20:43:50:I1: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:43:50:I1: Org: foldingathome.org
20:43:50:I1: Copyright: 2023-2024, foldingathome.org
20:43:50:I1: Homepage: https://foldingathome.org/
20:43:50:I1: License: GPL-3.0-or-later
20:43:50:I1: URL: https://v8-4.foldingathome.org/
20:43:50:I1: Date: Nov 20 2024
20:43:50:I1: Time: 14:47:19
20:43:50:I1: Revision: 360fe71b1bd05bb89814bfb97b73a5bda84802d6
20:43:50:I1: Branch: master
20:43:50:I1: Compiler: GNU 8.3.0
20:43:50:I1: Options: -Wsuggest-override -faligned-new -std=c++17 -fsigned-char
20:43:50:I1: -ffunction-sections -fdata-sections -O3 -funroll-loops -fno-pie
20:43:50:I1: Platform: linux 4.19.0-27-cloud-amd64
20:43:50:I1: Bits: 64
20:43:50:I1: Mode: Release
20:43:50:I1: Args: --config=/etc/fah-client/config.xml
20:43:50:I1: --log=/var/log/fah-client/log.txt
20:43:50:I1: --log-rotate-dir=/var/log/fah-client/
20:43:50:I1: Config: /etc/fah-client/config.xml
20:43:50:I1:****************************** CBang ******************************
20:43:50:I1: Version: 1.7.2
20:43:50:I1: Org: Cauldron Development
20:43:50:I1: Copyright: Cauldron Development, 2003-2024
20:43:50:I1: Homepage: https://cauldrondevelopment.com/
20:43:50:I1: License: LGPL-2.1-or-later
20:43:50:I1: Date: Nov 19 2024
20:43:50:I1: Time: 21:54:38
20:43:50:I1: Revision: 443c54e909eb8d8994405a18fb328b5b05a623a5
20:43:50:I1: -fPIC
20:43:50:I1:***************************** System ******************************
20:43:50:I1: CPU: Intel(R) Core(TM) i5-8500 CPU @ 3.00GHz
20:43:50:I1: CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
20:43:50:I1: CPUs: 2
20:43:50:I1: Memory: 86.21GiB
20:43:50:I1:Free Memory: 80.18GiB
20:43:50:I1: OS Version: 6.8
20:43:50:I1:Has Battery: false
20:43:50:I1: On Battery: false
20:43:50:I1: Hostname: folding-at-home
20:43:50:I1: UTC Offset: 0
20:43:50:I1: PID: 9060
20:43:50:I1: CWD: /var/lib/fah-client
20:43:50:I1: Exec: /usr/bin/fah-client
20:43:50:I1:*******************************************************************
20:43:50:I2:<config>
20:43:50:I2: <!-- HTTP Server -->
20:43:50:I2: <http-addresses v='192.168.168.35:7396'/>
20:43:50:I2:
20:43:50:I2: <!-- Resource Settings -->
20:43:50:I2: <cpus v='0'/>
20:43:50:I2:
20:43:50:I2: <!-- Server -->
20:43:50:I2: <allow v='0.0.0.0/0'/>
20:43:50:I2:
20:43:50:I2: <!-- User Information -->
20:43:50:I2: <team v='247478'/>
20:43:50:I2: <user v='CinciRyan'/>
20:43:50:I2:</config>
20:43:50:I1:Opening Database
20:43:50:I1:F@H ID = *** REMOVED FOR PRIVACY ***
20:43:50:I3:Loading default resource group
20:43:50:I1:Listening for HTTP on 192.168.168.35:7396
20:43:50:I3:Loaded 0 wus.
20:43:50:I3:gpus = {
20:43:50:I3: "gpu:00:02:00": {"vendor": 32902, "device": 16018, "type": "intel", "supported": false, "description": "CFL GT2 [UHD Graphics 630]"}
20:43:50:I3:}
I'm expecting it's something wrong in my config file, but the service starts and runs, so I don't know what I have wrong. I have taken pieces parts from different posts that I've seen, so perhaps something is formatted wrong.
<config>
<checkpoint v='10'/>
<cpu-usage v='100'/>
<!-- Client Control
Don't fold anonymously, provide user info. -->
<fold-anon v='false'/>
<gpu v='true'/> <!-- If true, attempt to autoconfigure GPUs -->
<!-- Slot Control
Options: light, medium or full
Watch out for high load -->
<power v='full'/>
<client-type v='advanced'/>
<cpus v='0'/>
<extra-core-args v=' -service '/>
<!-- COMMENTED OUT THE PASSKEY -->
<!-- <passkey v=' *** REMOVED FOR PRIVACY ***'/> -->
<team v='247478'/>
<!-- Folding Slots -->
<!-- Use all the CPUs
<!-- COMMENTED THESE OUT
<slot id='0' type='CPU'/>
<slot id='1' type='GPU'/>
<!-- Grant Remote Web Access
access web UI at 192.168.1.63:7396 -->
<allow>0.0.0.0/0</allow>
<web-allow>0.0.0.0/0</web-allow>
</config>
Thanks for taking a look and helping out.
Regards,
Ryan
Re: New install of FAH client on Ubuntu -- idle ??
Post by calxalot »
v8 does not start folding automatically on first run.
Assuming this is a headless install, you should make a web control account and add account-token to config.xml
Post by calxalot »
Note that accounts are optional.
You can also use
fahctl fold
Hardware configuration: 9950x, 7950x3D, 5950x, 5800x3D
7900xtx, RX9070, Radeon 7, 5700xt, 6900xt, RX 550 640SP
Post by muziqaz »
FAHclient does not see any GPUs in the system and CPUs are set to 0 by config.xml
FAH Omega tester
Post by calxalot »
Your http-addresses needs to include 127.0.0.1:7396 for the client to be accessible to localhost.
Post by calxalot »
Any options exposed in web control, such as cpus, is stored in client.db after first-run.
You really only need account-token in config.xml for a headless client.
Post by calxalot »
You are currently not likely to get any work assigned with only 2 cpu cores.
Post by calxalot »
Last I saw, the Home Assistant foldinghathome module only works with v7.
Post by muziqaz »
calxalot wrote: Tue Jul 01, 2025 5:45 am You are currently not likely to get any work assigned with only 2 cpu cores.
config.xml shows it has been configured for zero CPUs
FAH Omega tester
Post by calxalot »
Out of a max 2, which might be due to the container
