can't download core
lamy
can't download core
Post by lamy »
HI
I keep getting this error after downloading the work unit:
01:37:02:I1:Opening Database
01:37:02:I1:F@H ID = 7ZDjPhIZuwYyZkhylJFXu1XjkD-YLc8dUPTzf__BJKQ
01:37:02:I3:Loading default resource group
01:37:02:I1:Listening for HTTP on 127.0.0.1:7396
01:37:02:I3:WU1:Loading work unit 1 with ID NZUIv8KTMS4rEzfS2jcPSmLFa_PxPMMHS_LIQMdmzCk
01:37:02:I3:Loaded 1 wus.
01:37:02:I3:gpus = {
01:37:02:I3: "gpu:38:00:00": {
01:37:02:I3: "vendor": 4318,
01:37:02:I3: "type": "nvidia",
01:37:02:I3: "description": "NVIDIA GeForce RTX 5070 Ti",
01:37:02:I3: "uuid": "402c92e9-15d7-6f27-9752-fa0e6532767d",
01:37:02:I3: "cuda": {"platform": 0, "device": 0, "compute": "12.0", "driver": "12.8"},
01:37:02:I3: "device": 11269,
01:37:02:I3: "supported": true
01:37:02:I3: }
01:37:02:I3:}
01:37:02:I1:Downloading https://cores2.foldingathome.org/openmm ... ar.bz2.crt
01:37:02:W :CON1:DNS lookup failed for cores2.foldingathome.org
01:37:02:E :Exception: No response
Regards
Lamy
arisu
Re: can't download core
Post by arisu »
Try changing your system DNS to Google's DNS (8.8.8.8 primary and 8.8.4.4 secondary). Some DNS providers seem to have a problem with FAH servers.
