(howto)(mac os) uninstall v7?
nada391
Post by nada391 »
Hello ,
installed v7 on the MacPro but would like to uninstall since it is too loud for the room
(40 centigrade ambient temperature making it hot)
now the guide does not finish the tutorial
For Mac OSX, there is a third-party removal tool, located at the bottom of the this page. Stanford University does not provide any warranty for this tool. If you need further information, please visit the Folding Forum.
could you please tell me where to find it to proper uninstall, thanks.
nada391
Re: (howto)(mac os) uninstall v7?
Post by nada391 »
nevermind, found one, but is this the proper one?
it states macosx 10.6.4 and am using 10.14,
https://download.foldingathome.org/rele ... t/release/
That tutorial page lost an edit in a server move. The uninstaller was included in the client install package later on, go to the Folding@home folder in Applications. The OS version listed on that page was a minimum, nothing changed later on to need modification of the uninstaller script.
Post by calxalot »
The os version you see on the download directory is actually the name of the build worker, which has nothing to do with requirements or even the version of os used to build the software.
Post by calxalot »
Post by calxalot »
Like Joe said, first look in /Applications/Folding@home
Post by calxalot »
There have been occasional changes. Uninstaller 0.1.0 is not the right one.
arisu
Post by arisu »
If noise is the only issue, you can reduce noise by reducing the number of threads. That can significantly reduce both heat and noise.
Post by calxalot »
40 degrees C ambient is pretty high.
