Client v8.4.9 : Can you delete old work units from history?
scorpuk
Post by scorpuk »
I have changed the GPU in one of my folding rigs, but it has retained all the old data for the previous GPU's and keeps them assigned to the new GPU.
I delinked the machine and re-linked it with a new name, but it still retains all the history with the new name.
I've deleted all the .txt files in /var/log/fah-client. It only lists files going back 3 days, but it still retains ALL history. (Running on Ubuntu)
So instead of lowest PPD being 10m its 481K and goes back 21 days. New card was put in 3 days ago.
Is my only option a complete uninstall of FAH? :-(
Re: Client v8.4.9 : Can you delete old work units from history?
Post by muziqaz »
Unlink that client, log out of the account from that machine, then from that machine stop your FAHClient, find client.db file on that machine, delete it. Start the FAHClient, log in, link it to the account.
There is a request submitted to add an option to delete manually the history entries.
FAH Omega tester
scorpuk
Post by scorpuk »
top banana
scorpuk
Post by scorpuk »
client.db is located /var/lib/fah-client
Although there are 2 files.
client.db
client.db-journal
Deleting the first file, client.db, didnt work. Still 21 days of history.
Deleting both fixes it. Darn databases and their backups. :-)
Again tnx.
