More than one WU running at the same time -- is this normal?
Threemoons
So I seem to have two work units running at once. Can't delete one. Is this normal behavior? Yes, I read the FAQ but I'm still a bit rusty. Screenshot below. Thanks so much!!
Re: More than one WU running at the same time -- is this normal?
Yes, one is running on CPU, another on GPU
Threemoons
Thanks so much! Now I see how I can see which job is running on what. Very much appreciated!
There is also a slider where you can reduce the number of CPU threads used for CPU projects if you wish. That is left up to you.
Threemoons
