Cannot get folding@home to run
foldingissues
Post by foldingissues »
Machines CPUs GPUs PPD Actions
1 0 0 0
Fold All
Pause All
UnlinkedNo work
Now why
Re: Cannot get folding@home to run
Post by muziqaz »
Interesting way of asking for help :D
4 75 0 4,902,941
Everything works fine here
On a serious note, please provide full system information, like OS, CPU, GPU, Browser. Then take a screenshot of the system info section in fahclient.
We have many powers, guessing from thin air is not one of them
FAH Omega tester
foldingissues
Browser: Firefox
@HOME
Machine Log
LAPTOP-UK2TEBHR
Close
Search
Errors
Warnings
0%
19:01:57:I1: Version: 8.4.9
19:01:57:I1: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:01:57:I1: Org: foldingathome.org
19:01:57:I1: Copyright: 2023-2024, foldingathome.org
19:01:57:I1: Homepage: https://foldingathome.org/
19:01:57:I1: License: GPL-3.0-or-later
19:01:57:I1: URL: https://v8-4.foldingathome.org/
19:01:57:I1: Date: Nov 20 2024
19:01:57:I1: Time: 14:47:46
19:01:57:I1: Revision: 360fe71b1bd05bb89814bfb97b73a5bda84802d6
19:01:57:I1: Branch: master
19:01:57:I1: Compiler: Visual C++
19:01:57:I1: Options: $( /TP $) /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2
19:01:57:I1: /Zc:throwingNew /MT
19:01:57:I1: Platform: win32 10
19:01:57:I1: Bits: 64
19:01:57:I1: Mode: Release
19:01:57:I1: Args: --open-web-control
19:01:57:I1:****************************** CBang ******************************
19:01:57:I1: Version: 1.7.2
19:01:57:I1: Org: Cauldron Development
19:01:57:I1: Copyright: Cauldron Development, 2003-2024
19:01:57:I1: Homepage: https://cauldrondevelopment.com/
19:01:57:I1: License: LGPL-2.1-or-later
19:01:57:I1: Time: 09:04:40
19:01:57:I1: Revision: 443c54e909eb8d8994405a18fb328b5b05a623a5
19:01:57:I1:***************************** System ******************************
19:01:57:I1: CPU: Intel(R) Core(TM) i3-N305
19:01:57:I1: CPU ID: GenuineIntel Family 6 Model 190 Stepping 0
19:01:57:I1: CPUs: 8
19:01:57:I1: Memory: 7.70GiB
19:01:57:I1:Free Memory: 606.01MiB
19:01:57:I1: OS Version: 6.2
19:01:57:I1:Has Battery: true
19:01:57:I1: On Battery: false
19:01:57:I1: Hostname: LAPTOP-UK2TEBHR
19:01:57:I1: UTC Offset: -4
19:01:57:I1: PID: 13276
19:01:57:I1: CWD: C:\ProgramData\FAHClient
19:01:57:I1: Exec: C:\Program Files\FAHClient\FAHClient.exe
19:01:57:I1:*******************************************************************
19:01:57:I2:<config/>
19:01:57:I1:Opening Database
19:01:57:I1:F@H ID = AAZXqdk4fNJ_zXxn9mtOvNsdMsNPfpxPg5GWHbV58aw
19:01:57:I3:Loading default resource group
19:01:57:I1:Listening for HTTP on 127.0.0.1:7396
19:01:57:I3:Loaded 0 wus.
19:01:59:E :Exception: Failed to parse URI '172.2241.19:14323' at char 0: Expected alpha at start of scheme
19:01:59:I1:Started Windows systray control
19:01:59:E :Exception: Failed to parse URI '172.2241.19:14323'' at char 0: Expected alpha at start of scheme
19:05:26:I1:REQ5:< GET /ping?_=1747163126337&callback=jQuery1900828210054686498_1747163126336 HTTP/1.1
19:07:30:I1:Machine state fold
19:07:39:I1:Machine state fold
19:14:38:I1:Machine state fold
CPU
Description
Cores
8
Type
amd64
Thanks
Post by muziqaz »
Click on the cog looking icon, set the slider to maximum, save, click fold all
FAH Omega tester
foldingissues
Nothing
foldingissues
If you want we can do teamview. This is as dead as can be
Post by muziqaz »
What are you running on your network? Anything exotic?
Screenshots would still help.
System restart wouldn't hurt either
FAH Omega tester
arisu
Post by arisu »
Did you put anything custom in the config? Because "172.2241.19:14323" is not a valid IP.
foldingissues
i just concealed actual ip, but can it have to do with proxy
Post by muziqaz »
foldingissues wrote: Tue May 13, 2025 10:46 pm i just concealed actual ip, but can it have to do with proxy
Why not start with that info???
FAH Omega tester
Post by calxalot »
Does v8.4.9 support proxies on windows?
foldingissues
Thats what I'm wondering. i prefer not to release my IP on a public forum for security, however, does this support proxy?
Post by calxalot »
Change log for 8.4.0 says
Added system HTTP proxy support. No config necessary.
Post by calxalot »
I think ip starting 172 is a private local address anyway.
arisu
Post by arisu »
foldingissues wrote: Tue May 13, 2025 10:59 pm Thats what I'm wondering. i prefer not to release my IP on a public forum for security, however, does this support proxy?
The reason your client is not working is that you have incorrectly configured the proxy. If you are using an HTTP proxy, it must start with http://. That is why the error says "expected alpha", meaning it expected a letter but instead it got a number.
Wherever you configured the proxy, make sure it is an HTTP proxy (not a SOCKS proxy) and put http:// in front of it. Then it will work as long as your proxy works.
