Project: 5102 (Run 0, Clone 42, Gen 8) - no points!
Behc
Post by Behc »
I have had no points awarded for the above WU.
[20:57:04] - Expanded 1159981 -> 6173133 (decompressed 532.1 percent)
[20:57:05]
[20:57:05] Project: 5102 (Run 0, Clone 42, Gen 8)
[20:57:05]
[20:57:05] Entering M.D.
[20:57:11] Calling FAH init
[20:57:11] Read topology
[20:57:11] iting local files
[20:57:11] Completed 1989127 out of 2000000 steps  (99 percent)
[20:57:11] Extra SSE boost OK.
[20:57:11]
[21:26:11] Timered checkpoint triggered.
[21:32:15] Writing local files
[21:32:15] Completed 2000000 out of 2000000 steps  (100 percent)
[21:32:15] Writing final coordinates.
[21:32:16] Past main M.D. loop
[21:32:16] Will end MPI now
[21:33:16]
[21:33:16] Finished Work Unit:
[21:33:16] - Reading up to 3076704 from "work/wudata_06.arc": Read 3076704
[21:33:16] - Reading up to 887864 from "work/wudata_06.xtc": Read 887864
[21:33:16] goefile size: 0
[21:33:16] logfile size: 115923
[21:33:16] Leaving Run
[21:33:20] - Writing 4117531 bytes of core data to disk...
[21:33:20]   ... Done.
[21:33:20] - Shutting down core
[21:33:20]
[21:33:20] Folding@home Core Shutdown: FINISHED_UNIT
[21:33:24] CoreStatus = 64 (100)
[21:33:24] Sending work to server
[21:33:24] + Attempting to send results
[21:33:24] - Reading file work/wuresults_06.dat from core
[21:33:24]   (Read 4117531 bytes from disk)
[21:33:24] Connecting to http://171.64.65.64:8080/
[21:36:38] Posted data.
[21:36:38] Initial: 0000; - Uploaded at ~20 kB/s
[21:36:38] - Averaged speed for that direction ~84 kB/s
[21:36:38] + Results successfully sent
[21:36:38] Thank you for your contribution to Folding@Home.
[21:36:38] + Number of Units Completed: 6
Member of TSC! Russia team (TeamNumber 47191)
Re: Project: 5102 (Run 0, Clone 42, Gen 8) - no points!
You only receive credit for completing the work unit one time. Do you have USE IE SETTINGS set to yes? Did you clone this computer? Are you running multiple SMP clients on the same computer? What might be causing duplicate uploads?
Hi Behc (team 47191),
Your WU (P5102 R0 C42 G8) was added to the stats database on 2008-07-24 13:01:56 for 3340 points of credit.
Your WU (P5102 R0 C42 G8) was added to the stats database on 2008-07-25 05:04:54 for 0 points of credit.
Your WU (P5102 R0 C42 G8) was added to the stats database on 2008-07-28 14:46:44 for 0 points of credit.
Behc
Post by Behc »
I use linux (Xubuntu 8.04.1) with 4*SMP clients, but machineid absolutely different. This is very strange.
Thanks for the answer.
Unless you have 12-16 CPU cores, 4 clients is a bit much. I don't think you get any more performance that way.
