Ubuntu 24.04 can't find FAH to install
dschief
Hardware configuration: Gigabyte Z790 UD AC , i7-14700K (x2) Win11
ASUS Z97_K , i5-4460 (x2) Win10 & UBUNTU 24.04
GPU's ASUS RTX1660 x2, RTX3050 x2
EVGA1060
Post by dschief »
Added a second GPU to my linux box, started client, it showed both cards & let me enable. Upon start
CPU & first GPU off and running. Second card stuck in endless loop of red bar trying to start.
tried the uninstall & re-install option thats when ubuntu took a dump in various different messages it says
it can't find fah. I ran apt update to see if it would help { i'ts obvious I don't know what I'm doing}
cd into folder,fah is sitting right there: this is what I got
 Fetched 3,366 kB in 2s (1,940 kB/s)
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
6 packages can be upgraded. Run 'apt list --upgradable' to see them.
jim@FRODO:~/Downloads$ dir
fah-client_8.4.9_amd64.deb  fah_Key.txt
jim@FRODO:~/Downloads$ sudo apt install fah-client_8.4.9_amd64.deb
E: Unable to locate package fah-client_8.4.9_amd64.deb
any insights from the linux guru's would be appreciated
bollix47
Re: Ubuntu 24.04 can't find FAH to install
Post by bollix47 »
Using files navigate to Downloads and right click on the .deb file you want to install .... select open with and use the software package installer which is usually at the top of possibilities.
dschief
EVGA1060
Post by dschief »
well that didn't work either got
im@FRODO:~/Downloads$ sudo apt install ./fah-clent_8.4.9_amd64.deb
E: Unsupported file ./fah-clent_8.4.9_amd64.deb given on commandline
worth a try at least
bollix47
Post by bollix47 »
Do an ls -l in your Downloads folder so see the .deb's permissions and size.
Here's mine for comparison:
-rw-rw-r-- 1 bollix bollix 3013324 Jan 15 06:34 fah-client_8.4.9_amd64.deb
arisu
Post by arisu »
$ sudo dpkg -i fah-client_8.4.9_amd64.deb
If that doesn't work, then the download was incomplete and you should delete the file and download it again. You can run this to do that:
$ rm fah-client_8.4.9_amd64.deb
$ wget https://download.foldingathome.org/releases/public/fah-client/debian-10-64bit/release/fah-client_8.4.9_amd64.deb
dschief wrote: Tue May 06, 2025 5:50 pm Second card stuck in endless loop of red bar trying to start.
How old is that card? If your log files show a lot of HTTP error messages that say "No appropriate assignment" then it is not a bug and it just means that your card is old and there are no work units currently available that are small enough for it. Re-installing won't change anything if that is why it is stuck in a loop.
The UI is really bad and should explain what is happening rather than just looping endlessly. :)
dschief
EVGA1060
Post by dschief »
Thanks for the responses. CPU Client is currently running, has completed one wu for credit
& is running a new one! will leave it alone for now.
I agree it's time to put the GTX760's out to pasture. I pulled the trigger on a GTX1660 Super SC
from Amazon should be here by friday.
For Arisu ?
is the $wget https://download.foldingathome.org**** etc
Preferable to doing a direct down load, then cd-ing to the dowloads folder
and running Apt-get install
I read some where { i know that can be dangerous } that APT handles dependencies better
than dpkg
arisu
Post by arisu »
There's no preference between wget or using the browser, it's just personal preferences.
Apt doesn't handle dependencies better, but it will download them for you if they aren't already installed. But dpkg will just refuse to install a package if there are unmet dependencies. Under the hood, apt actually uses dpkg to install the .deb files it downloads.
Badsinger
Post by Badsinger »
Hi Folks;
This isn't directly related to not finding the client, but it might be the next problem after you install the 1660s. I'd glance at the first 3 posts in
viewtopic.php?t=42790. The topic is in this subforum about 1/2 the page down.
Both Mint 22 and the Kbuntu disto are based on 24.04. At least it's an easy fix if it glitches.
