Power optimization and number of cores
There's a nonlinear increase of power consumption with an increase in CPU frequency. Power will increase at a rate proportional to frequency cubed or more. For reducing the maximum amount of energy used by a single CPU instruction, it's always better to increase the number of CPU cores and decrease their frequency to stay within the package's power limits. In other words one core at 4 GHz and two cores at 2 GHz will perform the same number of computations in the same period of time, but the former will use significantly more power to do so.
But as we all know, GROMACS does not scale infinitely with the number of cores as load balancing and reconciling forces between slices adds more and more overhead. Also, more cores means smaller per-core caches and more cache misses. I don't know how relevant a hot cache is to FAH.
What is the sweet spot? Assuming no budgetary concerns, what is the approximate ideal number of cores for a HEDT/server processor if folding is the only activity it will be doing? Is there any data on this? I'm not sure how much I should trust lar.systems, and the GROMACS user forum is not at particularly representative of the kind of simulations that FAH performs.
Re: Power optimization and number of cores
No data, we just fold.
16 threads/8cores is a sweet spot. Past that performance increase is minimal, yet with bonus point formula it still shows point increase.
Gromacs craps out at random projects running on 64+threads.
It almost always craps out completely with anything above 96 threads.
CPUs scale better with new generations of products, which have improved FP pipelines. That stuff scales infinitely. Like, Zen5 has FPU which needs to be tweaked by compilers to be utilised properly in Desktops, yet FAH picked it up and said: No worries there, we will utilise this to the end of time
AMD 3d cache is loved by Gromacs. However AMD 9000 series came with tweaked FPU and cache subsystems and that thing blows 3dcache out of the water (or should I say matches and surpasses older 3d cache products).
Still, if there is a chance to buy 3d cache product Vs normal one for FAH, go with 3d cache.
And Linux as OS, since Windows scheduler is pants for FAH.
My 9950x3d on Windows is equal in output to my 9950x in Linux. This shouldn't be the case.
FAH and I suppose Gromacs hate Intel big.shittle architecture. You basically must fold only on P cores, otherwise FAH will pick up the slowest cores and drop P core performance to match them
It looks like the 9000 series is Ryzen. I'm looking at Threadripper or EPYC for the PCIe lanes. But I suppose any Zen5 has the architecture changes you speak of.
Then I suppose I was right in getting a Threadripper 7960X with 24c/48t. GROMACS won't shit itself and it should still have superior energy efficiency compared to a system with the same TPD but only 16 threads running at a higher frequency. If 48t is too much, I could always disable SMT.
The Intel big.LITTLE really is horrible, although GROMACS could just detect P-cores and only fold on them if it was programmed to. The GROMACS load balancer is not equipped to handle such drastic differences in performance, so it results in the E-cores all running at top speed while P-cores get only brief bursts of use, spending their time idle waiting on the E-cores otherwise.
I've found that the best way to make use of that architecture is to run one WU on the P-cores and one on the E-cores, assuming the system has sufficient cooling capacity to maintain boost rates on all cores, otherwise the heat from the E-cores causes the P-cores to throttle. But if cooling is sufficient, the E-cores can be used as well on a separate WU.
But I don't like Intel anyway. I prefer AMD.
In my experience, running a second WU on E-cores with a 6P+8E configuration limited to 80W reduces P-cores frequency by only 300-400 MHz. It is indeed more efficient to utilize more processors, just as you said :^)arisu wrote: ↑Mon May 05, 2025 9:58 am I've found that the best way to make use of that architecture is to run one WU on the P-cores and one on the E-cores, assuming the system has sufficient cooling capacity to maintain boost rates on all cores, otherwise the heat from the E-cores causes the P-cores to throttle. But if cooling is sufficient, the E-cores can be used as well on a separate WU.
BobWilliams757
Ryzen 2400G APU
16 GB DDR4-3200
MSI GTX 1660 Super Gaming X
You might find a below link interesting. This blog is done by folder Paragon.arisu wrote: ↑Mon May 05, 2025 9:58 am It looks like the 9000 series is Ryzen. I'm looking at Threadripper or EPYC for the PCIe lanes. But I suppose any Zen5 has the architecture changes you speak of.
https://greenfoldingathome.com/2 ... ation/
Fold them if you get them!
That's a great blog! I've read his post about the 3090 but I forgot about his site. Thank you!
What about folding different WUs on each CCD? The 7960X has 4 CCDs each with 6 cores (12 threads) for a total of 24 cores (48 threads). Would there be an advantage to folding 4 WUs, each with 12 threads and pinning each WU to one CCD, or would it be better to have a single 48 thread WU spread across the CCDs, despite them having NUMA-like properties?
Well, it is not quite like NUMA. Yes, synchronization across CCDs can be expensive, but memory access speed should be uniform, if I understand it correctly?
Optimal would be 2x 24threads. Not because of CCDs, but because core_a8 does not scale well past 30 threads.
FAH doesn't really suffer too much from cross CCD sync
Thank you! Will probably do 1x 24 and 1x 22, to leave room for a few GPU threads (I've got them to play nicely on just one physical core).
How valuable is 3D V-Cache vs higher clock rates then? I'm looking for an EPYC but there are a whole lot of options. I'm considering either a 9375F (4.4 GHz all core boost, 32 MB per CCD = 256 MB L3 total, 6400 MT/s memory) or a 9384X (3.5 GHz all core boost, 96 MB per CCD = 768 MB L3 total, 4800 MT/s memory). They're both 32 core, 64 thread. The first one is a newer generation (Zen 5), clocks higher, and has higher memory speed, but has much less L3. The second one is only Zen 4 and clocks lower with a lower memory speed, but has an insane amount of cache. I'll only run a single socket. They're both pretty expensive so I'd rather not just guess.
As muzikaz says, FAH loves 3D V-Cache, but only the 9004 series supports V-cache. The 9005 series, which is newer, does not yet.
Zen5 without the cache is handily beating zen4 with the cache. Probably due to much better cache subsystem.
3d cache is not doing much for Zen5 on windows in FAH, possibly due to windows scheduler.
Mind you my 9950x is on Linux latest mainline kernel, while my 9950x3d is on windows 11. They are both averaging the same PPD
