My client cannot detect the GPU after reboot, and I need to manually restart the client
fangfufu
Hardware configuration: GTX 1080
Post by fangfufu »
I have fah-client 8.4.9 installed on Debian Bookworms. I can confirm that fah-client had been added to the "render" group. I noticed that after rebooting my machine, fah-client doesn't automatically restart folding on my GPU. I have to restart fah-client service manually, then it would notice that the GPUs are there and restart folding. Is there a fix for this?
Folding with a GTX 1080
I first started folding back in the Google Toolbar with Google Compute days!
Re: My client cannot detect the GPU after reboot, and I need to manually restart the client
Post by muziqaz »
No fix. This has been observed already. Newer distro versions changed something in their service loading sequences that fah-client loads before any libraries are loaded or something. This is not an issue with older distros.
Developer is on a sabbatical, so not sure when we get to add a workaround for this. Until then, manually restarting fah-client after system reboot is the only solution. People with more knowledge can create a script which executes upon system restart to automatically restart fah-client. Or simply delay fah-client start for like 10-20s after system booted
FAH Omega tester
fangfufu
Post by fangfufu »
Well, I do wonder if it would help if I put the nvidia modules in /etc/modules. But I can't be bothered to test. I am okay to restart the service after reboot - I don't restart my computer all that often.
Post by muziqaz »
This is not nVidia exclusive. This is OS issue
FAH Omega tester
Marcos FRM
Post by Marcos FRM »
I had some ideas to try debugging this issue:
https://github.com/FoldingAtHome/fah-cl ... 2627040201 (last paragraph)
https://github.com/FoldingAtHome/fah-cl ... 2807120590
If you can test them, you're welcome to.
You could try to delay service start to the end of the OS startup ... the only hard part will to find which service dependencies will allow this ...
wesgeorge
Post by wesgeorge »
/lib/systemd/system/fah-client.service currently lists
After=network.target nss-lookup.target
WantedBy=multi-user.target
I was looking at logs to try to figure out the race condition, saw this:
-- Boot f99ecd5cd53542eabfb6e776bad81f18 --
May 05 09:01:17 deathstar systemd[1]: Started fah-client.service - Folding@home Client.
May 05 09:01:21 deathstar systemd[1]: Reached target graphical.target - Graphical Interface.
wes@deathstar:~$ sudo systemctl status graphical.target
● graphical.target - Graphical Interface
     Loaded: loaded (/lib/systemd/system/graphical.target; static)
     Active: active since Mon 2025-05-05 09:01:21 EDT; 35min ago
I thought perhaps I could add graphical.target to the After list, since this seems like a reliable indicator that the GPU drivers are fully loaded, but that just caused:
May 05 09:47:06 deathstar systemd[1]: multi-user.target: Job fah-client.service/start deleted to break ordering cycle starting with multi-user.target/start
May 05 09:47:06 deathstar systemd[1]: Queued start job for default target graphical.target.
and
wes@deathstar:~$ sudo systemctl status fah-client
○ fah-client.service - Folding@home Client
     Loaded: loaded (/lib/systemd/system/fah-client.service; enabled; preset: enabled)
     Active: inactive (dead)
But I'm not familiar enough with systemd dependencies to know if I've done that correctly.
Marcos FRM
The difference is that if we order after graphical.target, the practical effect is ordering the service after display-manager.service, implemented by GDM, SDDM, etc. Display managers usually do at least one additional thing: wait for the CanGraphical property of systemd-logind to become true. Consequently, I believe it's better to replicate this in the client code, as I suggested in the second link above. Ordering after graphical.target would be pointless in text-only installations because there's no display manager.
