8.4.9 Fails to Find GPUs.txt
Catalina588
Post by Catalina588 »
Newly installed upgrade to 8.4.8 from 8.3.6 fails to find GPUs.txt. Windows 10 with latest patches. Forgive the plain text log but I am on an iPad.
Summary
14:26:42:I1: Exec: C:\Program Files\FAHClient\FAHClient.exe
14:26:42:I1:*******************************************************************
14:26:42:I2:<config/>
14:26:42:I1:Opening Database
14:26:42:I1:Generating RSA key...............++++-..................................................................................................++++-
14:26:42:I1:F@H ID = nHSmWlMBI7UopTTesMH-9gGUdBVFRP3_4wEfstUh-Ls
14:26:42:I3:Loading default resource group
14:26:42:I1:Listening for HTTP on 127.0.0.1:7396
14:26:42:I3:Loaded 0 wus.
14:26:42:I1:Started Windows systray control
14:26:42:I1:OUT1:> GET https://api.foldingathome.org/gpus HTTP/1.1
14:26:42:W :Failed to update GPUs
14:26:47:I1:OUT3:> GET https://api.foldingathome.org/gpus HTTP/1.1
Complete Log
14:26:42:I1: Version: 8.4.9
14:26:42:I1: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:26:42:I1: Org: foldingathome.org
14:26:42:I1: Copyright: 2023-2024, foldingathome.org
14:26:42:I1: Homepage: https://foldingathome.org/
14:26:42:I1: License: GPL-3.0-or-later
14:26:42:I1: URL: https://v8-4.foldingathome.org/
14:26:42:I1: Date: Nov 20 2024
14:26:42:I1: Time: 14:47:46
14:26:42:I1: Revision: 360fe71b1bd05bb89814bfb97b73a5bda84802d6
14:26:42:I1: Branch: master
14:26:42:I1: Compiler: Visual C++
14:26:42:I1: Options: $( /TP $) /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2
14:26:42:I1: /Zc:throwingNew /MT
14:26:42:I1: Platform: win32 10
14:26:42:I1: Bits: 64
14:26:42:I1: Mode: Release
14:26:42:I1: Args: --open-web-control
14:26:42:I1:****************************** CBang ******************************
14:26:42:I1: Version: 1.7.2
14:26:42:I1: Org: Cauldron Development
14:26:42:I1: Copyright: Cauldron Development, 2003-2024
14:26:42:I1: Homepage: https://cauldrondevelopment.com/
14:26:42:I1: License: LGPL-2.1-or-later
14:26:42:I1: Time: 09:04:40
14:26:42:I1: Revision: 443c54e909eb8d8994405a18fb328b5b05a623a5
14:26:42:I1:***************************** System ******************************
14:26:42:I1: CPU: Intel(R) Core(TM) i5-9400F CPU @ 2.90GHz
14:26:42:I1: CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
14:26:42:I1: CPUs: 6
14:26:42:I1: Memory: 31.92GiB
14:26:42:I1:Free Memory: 28.88GiB
14:26:42:I1: OS Version: 6.2
14:26:42:I1:Has Battery: false
14:26:42:I1: On Battery: false
14:26:42:I1: Hostname: white
14:26:42:I1: UTC Offset: -4
14:26:42:I1: PID: 12508
14:26:42:I1: CWD: C:\ProgramData\FAHClient
14:26:47:W :Failed to update GPUs
14:26:57:I1:OUT4:> GET https://api.foldingathome.org/gpus HTTP/1.1
14:26:57:W :Failed to update GPUs
14:27:17:I1:OUT5:> GET https://api.foldingathome.org/gpus HTTP/1.1
14:27:17:W :Failed to update GPUs
14:27:57:I1:OUT6:> GET https://api.foldingathome.org/gpus HTTP/1.1
14:27:57:W :Failed to update GPUs
14:29:17:I1:OUT7:> GET https://api.foldingathome.org/gpus HTTP/1.1
14:29:17:W :Failed to update GPUs
14:31:57:I1:OUT8:> GET https://api.foldingathome.org/gpus HTTP/1.1
14:31:57:W :Failed to update GPUs
14:37:17:I1:OUT9:> GET https://api.foldingathome.org/gpus HTTP/1.1
14:37:17:W :Failed to update GPUs
Re: 8.4.9 Fails to Find GPUs.txt
Post by muziqaz »
Uninstall the client. And install from fresh
FAH Omega tester
Catalina588
CLOSE
Bizarre state where some IP domains were visible and most were not, so a DNS issue. Troubleshootig and resetting adapters, firewalls, etc fixed the problem. Blame a Microsoft Windows update. Sigh.
