unstable client under ubuntu
dschief
Hardware configuration: Gigabyte Z790 UD AC , i7-14700K (x2) Win11
ASUS Z97_K , i5-4460 (x2) Win10 & UBUNTU 24.04
GPU's ASUS RTX1660 x2, RTX3050 x2
EVGA1060
Post by dschief »
working on First install of client under linux in 15+ years, client will launch, correctly id cpu & GTX760. WU's are
quickly found & downloaded both slots run for 5 to 10 seconds then both fault out. cycle repeats several times
until both slots freeze.
  • 14:52:03:I1:WU23: Hostname: FRODO
    14:52:03:I1:WU23: UTC Offset: -7
    14:52:03:I1:WU23: PID: 31394
    14:52:03:I1:WU23: CWD: /var/lib/fah-client/work
    14:52:03:I1:WU23: Exec: /var/lib/fah-client/cores/openmm-core-26/centos-7.9.2009-64bit/release/fahcore-26-centos-7.9.2009-64bit-release-8.2.0/FahCore_26
    14:52:03:I1:WU23:************************************ OpenMM ************************************
    14:52:03:I1:WU23: Version: 8.2.0
    14:52:03:I1:WU23:********************************************************************************
    14:52:03:I1:WU23:Project: 18243 (Run 146, Clone 0, Gen 60)
    14:52:03:I1:WU23:Digital signatures verified
    14:52:03:I1:WU23:Folding@home GPU Core26 Folding@home Core
    14:52:03:I1:WU23:Version 8.2
    14:52:03:I1:WU23: Checkpoint write interval: 50000 steps (2%) [50 total]
    14:52:03:I1:WU23: JSON viewer frame write interval: 25000 steps (1%) [100 total]
    14:52:03:I1:WU23: XTC frame write interval: 10000 steps (0.4%) [250 total]
    14:52:03:I1:WU23: TRR frame write interval: disabled
    14:52:03:I1:WU23: Global context and integrator variables write interval: disabled
    14:52:03:I1:WU23:There are 4 platforms available.
    14:52:03:I1:WU23:Platform 0: Reference
    14:52:03:I1:WU23:Platform 1: CPU
    14:52:03:I1:WU23:Platform 2: OpenCL
    14:52:03:I1:WU23:Platform 3: CUDA
    14:52:03:I1:WU23: cuda-device 0 specified
    14:52:03:I1:WU2:Completed 1382 out of 125000 steps (1%)
    14:52:05:I1:Machine state pause
    14:52:06:I1:WU2:Caught signal SIGINT(2) on PID 31388
    14:52:06:I1:WU2:Exiting, please wait. . .
    14:52:06:I1:WU23:Caught signal SIGINT(2)
    14:52:06:I1:WU23:Exiting, please wait. . .
    14:52:06:I1:WU23:ERROR:102: Core startup was interrupted by client.
    14:52:06:I1:WU23:Folding@home Core Shutdown: INTERRUPTED
    14:52:06:I1:WU23:Core returned INTERRUPTED (102)
    14:52:09:I1:WU2:Folding@home Core Shutdown: INTERRUPTED
    14:52:10:I1:WU2:Core returned INTERRUPTED (102)
arisu
Re: unstable client under ubuntu
Post by arisu »
Do you have any more logs? All I see here is a work unit starting and then being paused. Everything in the log looks normal for a core being started and then manually paused.
wdanwatts
Post by wdanwatts »
I had intermittent problems starting in February of this year, but by 16 April, I no longer could get my MSI 192 GB 32 thread machine to run its two MSI GeForce RTX 4060 Ti X 8GB Graphics Cards. I was running Fedora, but tried Mint and Ubuntu also but they all would freeze. I put Windows 11 on it yesterday, and have been running nonstop for ~18 hours. Is there some deep Linux driver problem?
arisu
Post by arisu »
wdanwatts wrote: Wed May 14, 2025 1:45 am I had intermittent problems starting in February of this year, but by 16 April, I no longer could get my MSI 192 GB 32 thread machine to run its two MSI GeForce RTX 4060 Ti X 8GB Graphics Cards. I was running Fedora, but tried Mint and Ubuntu also but they all would freeze. I put Windows 11 on it yesterday, and have been running nonstop for ~18 hours. Is there some deep Linux driver problem?
You'd have to show logs. And do you mean your entire system would freeze? What Nvidia driver are you using?
Post by muziqaz »
Ask Nvidia about the drivers. They seem to have botched several latest iterations of their Linux (and windows drivers)
FAH Omega tester
wdanwatts
Post by wdanwatts »
Yes, the whole system would freeze. Unfortunately, I lost all info when installing Windows (this machine was dedicated to F@H so I didn't keep anything else on it). Windows, so far, has worked.
