please add RTX 5060 Ti
mharsch
Post by mharsch »
from GPU-Z
Name: NVIDIA GeForce RTX 5060 Ti
Device ID: 10DE 2D04 - 1462 5351
Log:
*********************** Log Started 2025-04-27T16:32:21Z ***********************
16:32:21:I1:*********************** Folding@home Client ***********************
16:32:21:I1:    Version: 8.4.9
16:32:21:I1:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
16:32:21:I1:        Org: foldingathome.org
16:32:21:I1:  Copyright: 2023-2024, foldingathome.org
16:32:21:I1:   Homepage: https://foldingathome.org/
16:32:21:I1:    License: GPL-3.0-or-later
16:32:21:I1:        URL: https://v8-4.foldingathome.org/
16:32:21:I1:       Date: Nov 20 2024
16:32:21:I1:       Time: 14:47:46
16:32:21:I1:   Revision: 360fe71b1bd05bb89814bfb97b73a5bda84802d6
16:32:21:I1:     Branch: master
16:32:21:I1:   Compiler: Visual C++
16:32:21:I1:    Options: $( /TP $) /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2
16:32:21:I1:             /Zc:throwingNew /MT
16:32:21:I1:   Platform: win32 10
16:32:21:I1:       Bits: 64
16:32:21:I1:       Mode: Release
16:32:21:I1:       Args: --open-web-control
16:32:21:I1:****************************** CBang ******************************
16:32:21:I1:    Version: 1.7.2
16:32:21:I1:        Org: Cauldron Development
16:32:21:I1:  Copyright: Cauldron Development, 2003-2024
16:32:21:I1:   Homepage: https://cauldrondevelopment.com/
16:32:21:I1:    License: LGPL-2.1-or-later
16:32:21:I1:       Time: 09:04:40
16:32:21:I1:   Revision: 443c54e909eb8d8994405a18fb328b5b05a623a5
16:32:21:I1:***************************** System ******************************
16:32:21:I1:        CPU: AMD Ryzen 5 9600X 6-Core Processor
16:32:21:I1:     CPU ID: AuthenticAMD Family 26 Model 68 Stepping 0
16:32:21:I1:       CPUs: 12
16:32:21:I1:     Memory: 31.16GiB
16:32:21:I1:Free Memory: 24.40GiB
16:32:21:I1: OS Version: 6.2
16:32:21:I1:Has Battery: false
16:32:21:I1: On Battery: false
16:32:21:I1:   Hostname: DESKTOP-9523AV3
16:32:21:I1: UTC Offset: -6
16:32:21:I1:        PID: 1396
16:32:21:I1:        CWD: C:\ProgramData\FAHClient
16:32:21:I1:       Exec: C:\Program Files\FAHClient\FAHClient.exe
16:32:21:I1:*******************************************************************
16:32:21:I2:<config/>
16:32:21:I1:Opening Database
16:32:21:I1:F@H ID = 51rbpG3zT1UVH0LBXFhsVOn0pZosJmMGXmOpyStV-70
16:32:21:I3:Loading default resource group
16:32:21:I1:Listening for HTTP on 127.0.0.1:7396
16:32:21:I3:WU1:Loading work unit 1 with ID IXvGOb8Wq_zw9ZMHVD8TLYFTe5lo84hQ4DR0tTDAxEY
16:32:21:I3:WU3:Loading work unit 3 with ID peYiWpeIWAD1BXU9-R3YaVUJ_Rj1UHrdyuZt8f6ZQuk
16:32:21:I3:Loaded 2 wus.
16:32:21:I1:Started Windows systray control
16:32:21:I1:OUT1:> GET https://api.foldingathome.org/machine/51rbpG3zT1UVH0LBXFhsVOn0pZosJmMGXmOpyStV-70 HTTP/1.1
16:32:21:I1:OUT2:> GET https://api.foldingathome.org/gpus HTTP/1.1
16:32:21:I1:OUT1:< HTTP/1.1 200 HTTP_OK
16:32:21:I1:OUT4:> GET wss://node1.foldingathome.org/ws/client HTTP/1.1
16:32:21:I1:OUT2:< HTTP/1.1 200 HTTP_OK
16:32:21:I3:gpus = {
16:32:21:I3:  "gpu:01:00:00": {
16:32:21:I3:    "vendor": 4318,
16:32:21:I3:    "type": "nvidia",
16:32:21:I3:    "description": "NVIDIA GeForce RTX 5060 Ti",
16:32:21:I3:    "uuid": "dfd1eccd-4ae7-206e-8680-20a4609244c4",
16:32:21:I3:    "opencl": {"platform": 0, "device": 0, "compute": "3.0", "driver": "576.2"},
16:32:21:I3:    "cuda": {"platform": 0, "device": 0, "compute": "12.0", "driver": "12.9"},
16:32:21:I3:    "device": 11524,
16:32:21:I3:    "supported": false
16:32:21:I3:  },
16:32:21:I3:  "gpu:11:00:00": {
16:32:21:I3:    "vendor": 4098,
16:32:21:I3:    "type": "amd",
16:32:21:I3:    "description": "gfx1036",
16:32:21:I3:    "opencl": {"platform": 1, "device": 0, "compute": "2.0", "driver": "3617.0"},
16:32:21:I3:    "device": 5056,
16:32:21:I3:    "supported": true
16:32:21:I3:  }
16:32:21:I3:}
16:32:21:I1:OUT4:< HTTP/1.1 101 HTTP_SWITCHING_PROTOCOLS
16:32:21:I1:Logging into node account
16:32:29:I1:Clean exit
Reason: changed Quote tags to Code
Re: please add RTX 5060 Ti
Post by muziqaz »
In half an hour, delete your gpus.json file inside of fahclient folder, and restart the pc. Hopefully server updates itself and gives you updated GPUs file
FAH Omega tester
mharsch
Post by mharsch »
Thanks, it's working now.
