Hi Folks;
All three of these WU's are running with a new core (to me at least) 0x27. I' ve had all 3 WU's at least once now, and they all finish and upload, but none are reporting points. Something to check into perhaps. Thanks.
WU's 17656 17657 17658 and core 0x27
Re: WU's 17656 17657 17658 and core 0x27
I just got one of these and I was just about to post this myself.
In addition to the problem you mentioned, these WUs are marked as non-beta despite being brand new, and they have no description set, no manager or institution set, and no project series set. I'm guessing they were accidentally released to the public when they were supposed to be doing internal testing, because this project hasn't even been announced in the beta subforum, and the first 0x27 project was released to beta testers just a few days ago.
BobWilliams757
Ryzen 2400G APU
32 GB DDR4-3200
MSI GTX 1660 Super Gaming X
Pe the discord channel it was announced that p17656 to p17660 were intentionally moved to public to test core 27.
I think the issue with points has already been reported here on the forum or possibly on discord, but either way any further issue should be reported.
Fold them if you get them!
I'm folding 17657 and not 17656 or 17660 so I guess that one is public too.
Still no information from the API about the project, which should probably be fixed. Along with the points issue you mentioned.
However it is folding well getting 88k PPD (which is typical for this GPU) and will make the timeout.
Weekend, guys, weekend
Researchers know about information not showing up. Point stuff has been sorted, however, there is a chance that points from WUs before the fix will not be reimbursed.
