0x27 Project 12705
Demmers
0x27 Project 12705
Post by Demmers »
Just got a 0x27 project for the first time. I just searched for 0x27 in this forum, and all there is mentioning it is the project i'm currently doing, 12705, but it's beta.... i'm not set to do beta projects?
Either way, my ETA is 4hrs and Timeout is 23hrs so no problem there. For what it's worth the RCG is 1,52,1.
Re: 0x27 Project 12705
Post by muziqaz »
Yes, it is not supposed to be out in full fah.
Thanks for the report
FAH Omega tester
Demmers
Post by Demmers »
muziqaz wrote: Sat Apr 26, 2025 3:11 pm Yes, it is not supposed to be out in full fah.
I can only assume you're working on this right now, as before you replied, I noticed in https://apps.foldingathome.org/serverstats that 0x27 had 0 Beta Jobs. Just went back to it after seeing your reply.... now currently stands at 116 Public, and 276 Beta!
Post by muziqaz »
This should be swapped by now. Let me know if you still receive this project.
Thanks
FAH Omega tester
Demmers
Post by Demmers »
muziqaz wrote: Sat Apr 26, 2025 3:47 pm This should be swapped by now. Let me know if you still receive this project.
Thanks
Will do!
foxpy
Post by foxpy »
Since we are already here, should core 26 jobs be public, too? They were recently phased away but now I am receiving them again.
Post by muziqaz »
core26 will die out on its own. There is no problem for it being public.
FAH Omega tester
arisu
Post by arisu »
Thanks
Also receiving 17675 (0x27) in non-beta.
Post by muziqaz »
arisu wrote: Sun Apr 27, 2025 3:37 am
Thanks
You mean 17657.
17600 series core27 is in the wild intentionally.
FAH Omega tester
