Missing Installation Guides
Dynamite_Bison
- Hardware configuration: Processor: AMD Ryzen 5 7520U
RAM: 16GB
System: x64
Version: Windows 11 v24H2
New to F@H, interested in joining the project. Unfortunately, the "v7 installation guide" link in the v8.4 user guide leads to a broken page. No page errors, but the area where the guides should be is blank. Specifically, the page loads as normal with the menu bar, the sidebar, and the "Installation Guides" header, but the space beneath the header is completely blank. Any advice?
Re: Missing Installation Guides
Welcome to the forum
There may be a broken link somewhere, could you tell hoe you got to that download page? Oh, and the url of the broken page itself. I won't be able to fix it, but someone will.
When you go to https://foldingathome.org/, then select Download from the top menu items, there's a link to the guide, https://foldingathome.org/start-folding/
V8 is the latest fahclient, so v7 has been put to the side and is being phased out.
V8 has an installation guide.
The v8 guide has a link to v7 installation, which leads to a faq page with no content.
https://foldingathome.org/faqs/installation-guides/
It should probably point to https://foldingathome.org/guides/
Or https://foldingathome.org/guides/v7-client-guides/
You can click on a guide on left sidebar of the blank faq.
This is the blank page - https://foldingathome.org/faqs/installation-guides/
The linking page is from https://foldingathome.org/guides/v8-4-client-guide/ - the section pointing to the v7 config guide is where the break occurs:
Installation
The v8 client can run on Windows, macOS, Linux and ARM Linux. The install procedure for v8 is essentially the same as for the v7 client, with the exception that on Linux you now only need to install the fah-client package. V8 specific install instructions have yet to be written. For now, please consult to the v7 install guides.
Installation
