Core 0x26 Points not Registering Correctly
favrepeoria
Post by favrepeoria »
I have been recently getting many core 0x26 under projects 17655 and 17653. I have also seen a significant drop in my PPD per extreme overclocking. Suspiciously my PPD has dropped to what my CPU only PPD would be over the last couple days. The GPU has only had 3 units that have not been 0x26. Is there an issue with not getting credit for the 0x26 units? Or maybe is EOC not counting the 0x26 units on their page?
Re: Core 0x26 Points not Registering Correctly
Post by muziqaz »
Yes :) people are looking into it :)
FAH Omega tester
favrepeoria
Okay. Not crazy at least. I suppose the work is still getting completed just not credited. The points are secondary.
Probably means the WS is not uploading the log files with the credits to the stats server for some reason. Once that is sorted out, the points should show up.
Post by muziqaz »
Those projects were never added to the database.
It will be fixed
FAH Omega tester
mattifolder
Post by mattifolder »
I think the problem affects also projects 17652, I miss some points in the last days. Can you confirm that ?
arisu
Post by arisu »
It looks like it does affect 17652 as well. I finished R445 C0 G39 eight hours ago and nothing is showing up on the API. Stats seem to have broken some time after April 22nd because that is when the G33 was credited and that is the last one credited from the R445 C0 series.
Issue should be fixed now. :)
arisu
Post by arisu »
Yep it is fixed. Just got the points from a 17265 unit.
