GTX 1060 won't launch
dschief
Hardware configuration: Gigabyte Z790 UD AC , i7-14700K (x2) Win11
ASUS Z97_K , i5-4460 (x2) Win10 & UBUNTU 24.04
GPU's ASUS RTX1660 x2, RTX3050 x2
EVGA1060
Post by dschief »
fah client browser shows 3cpu's, GP106[ GeForce GTX1060 3GB]3935
but no gpu folding slot active, edit shows gtx1060 greyed out & mouseing to the enable check box shows Unsupported..
the GPu white list has two versions being supported GP104 & GP106 for the same 3GB 1060.
1060 is Pascal arch. and should just run, Have 2 other boxes running GTX 760's & they are running fine!
what am I missing. running Driver 475.14, CPU slot is running @ 42%
Re: GTX 1060 won't launch
Post by muziqaz »
Full system details would help us. Don't forget the most important thing:OS/distro.
FAH Omega tester
dschief
EVGA1060
Post by dschief »
Win7 Pro 64 bit
Post by muziqaz »
dschief wrote: Thu Apr 24, 2025 3:50 pm Win7 Pro 64 bit
Is win7 even supported anymore?
Anyways, I don't know what the policy for CUDA is on Win7. It is possible Nvidia does not support CUDA or anything compute on Win7 anymore. Though you might need to download CUDA ask or something. Or reinstall the driver, which should in theory bring everything you need for FAH
FAH Omega tester
dschief
EVGA1060
Post by dschief »
According to Nvidea website, the 470 series drivers support
OpenCL 3.0
OpenGL 4.6
Cuda 11.4
So in theory the GTX1060 should be running?
Post by muziqaz »
card should be running, OS, though. I am not sure
FAH Omega tester
dschief
EVGA1060
Post by dschief »
Status update: Uninstalled Fah, did fresh install. Using Nvidea 576.02 driver. Now Client sees the card,
and projects 1,370,405 PPD.
Note to self do fresh installs after any hardware swaps.
Consider thread closed
