Some machines had issues and others did not.
On the machines with disabled GPUs, I simply reinstalled FAH v7.6.21, rebooted, restarted FAHClient, and re-enabled systemd FAHClient and all was well again.
All I could find in the log file was the following:
15:39:28:Trying to access database...
15:39:28:Successfully acquired database lock
15:39:28:FS00:Initialized folding slot 00: cpu:6
ESC[93m15:39:28:WARNING:FS03:Disabling beta GPU slot 03: gpu:2:0. Beta GPUs can be tested for no points by se
tting ``gpu-beta=true`` in the configuration.ESC[0m
ESC[93m15:39:28:WARNING:FS04:Disabling beta GPU slot 04: gpu:3:0. Beta GPUs can be tested for no points by se
15:39:28:WU02:FS00:Starting
15:39:28:WU02:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/lin/64bit-avx-256/a8-0.0.12/Core_a8.fah/FahCore_a8 -dir 02 -suffix 01 -version 706 -lifeline 916 -checkpoint 15 -np 6
15:39:28:WU02:FS00:Started FahCore on PID 926
15:39:28:WU02:FS00:Core PID:930
15:39:28:WU02:FS00:FahCore 0xa8 started
15:39:29:WU02:FS00:0xa8:*********************** Log Started 2025-04-03T15:39:29Z ***********************So, keeping things simple, as reinstalled the FAH v7.6.21 client and that corrected my issue. I did not look through any OS log files to locate the cause of my issue as it (my issue) may have been hardware related.
Now, I wait to the next OS update to see if it (disabling GPUs) happens again and on what hardware.
