Running 7.6.21 on GPU only by adding in Folding Slots ID:
1 GPU
I have now upgraded to a better multi core cpu and would like to add the ability to fold on 3 of the four cores (leaving 1 for the gpu!
How do I do this?
How to add CPU
Re: How to add CPU
Use Configure in FAHControl, select Slots, Add a CPU slot, you can set the number of CPU threads there to 3.
It has been a while since I ran 7.6.21, and I only did on a Mac. I do recall mention by some running on Windows that depending on the scheme used the radio buttons for CPU vs GPU on the left could be hard to see.
Re: How to add CPU
Right click on systray icon, click on Advanced Control>Configure>Slots
Click on Add+, then click on CPU, enter number of threads you want the slot to use. Click Ok>Save, and Start folding
silverpulser
Re: How to add CPU
That worked thanks. Up and running cpu work units now
