trleith
Posts: 21 Joined: Tue Mar 24, 2020 7:19 pm
Post
by trleith » Fri Apr 04, 2025 4:10 am
Hi. I got a new machine and am reinstalling fah-client_8.4.9
I can see it at
https://v8-4.foldingathome.org/machines
It knows the new hostname, shows one machine, but no CPUs and no GPUs
What should I look for?
It's running
trl@homeserver:~$ systemctl status fah-client.service
● fah-client.service - Folding@home Client
Loaded: loaded (/usr/lib/systemd/system/fah-client.service; enabled; preset: enabled)
Active: active (running) since Fri 2025-04-04 03:33:58 UTC; 28min ago
Main PID: 499770 (fah-client)
Tasks: 3 (limit: 115823)
Memory: 10.6M (peak: 11.3M)
CPU: 3.438s
CGroup: /system.slice/fah-client.service
└─499770 /usr/bin/fah-client --config=/etc/fah-client/config.xml --log=/var/log/fah-client/log.txt --log-rotate-dir=/var/log/fah-client/
Apr 04 03:33:58 homeserver systemd[1]: Started fah-client.service - Folding@home Client.
trl@homeserver:~$
This looks copasetic
trl@homeserver:~$ cat /var/log/fah-client/log.txt
*********************** Log Started 2025-04-04T03:33:58Z ***********************
03:33:58:I1:*********************** Folding@home Client ***********************
03:33:58:I1: Version: 8.4.9
03:33:58:I1: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
03:33:58:I1: Org: foldingathome.org
03:33:58:I1: Copyright: 2023-2024, foldingathome.org
03:33:58:I1: Homepage: https://foldingathome.org/
03:33:58:I1: License: GPL-3.0-or-later
03:33:58:I1: URL: https://v8-4.foldingathome.org/
03:33:58:I1: Date: Nov 20 2024
03:33:58:I1: Time: 14:47:19
03:33:58:I1: Revision: 360fe71b1bd05bb89814bfb97b73a5bda84802d6
03:33:58:I1: Branch: master
03:33:58:I1: Compiler: GNU 8.3.0
03:33:58:I1: Options: -Wsuggest-override -faligned-new -std=c++17 -fsigned-char
03:33:58:I1: -ffunction-sections -fdata-sections -O3 -funroll-loops -fno-pie
03:33:58:I1: Platform: linux 4.19.0-27-cloud-amd64
03:33:58:I1: Bits: 64
03:33:58:I1: Mode: Release
03:33:58:I1: Args: --config=/etc/fah-client/config.xml
03:33:58:I1: --log=/var/log/fah-client/log.txt
03:33:58:I1: --log-rotate-dir=/var/log/fah-client/
03:33:58:I1: Config: /etc/fah-client/config.xml
03:33:58:I1:****************************** CBang ******************************
03:33:58:I1: Version: 1.7.2
03:33:58:I1: Org: Cauldron Development
03:33:58:I1: Copyright: Cauldron Development, 2003-2024
03:33:58:I1: Homepage: https://cauldrondevelopment.com/
03:33:58:I1: License: LGPL-2.1-or-later
03:33:58:I1: Date: Nov 19 2024
03:33:58:I1: Time: 21:54:38
03:33:58:I1: Revision: 443c54e909eb8d8994405a18fb328b5b05a623a5
03:33:58:I1: -fPIC
03:33:58:I1:***************************** System ******************************
03:33:58:I1: CPU: Intel(R) Xeon(R) CPU E5-2440 v2 @ 1.90GHz
03:33:58:I1: CPU ID: GenuineIntel Family 6 Model 62 Stepping 4
03:33:58:I1: CPUs: 32
03:33:58:I1: Memory: 94.34GiB
03:33:58:I1:Free Memory: 1.14GiB
03:33:58:I1: OS Version: 6.8
03:33:58:I1:Has Battery: false
03:33:58:I1: On Battery: false
03:33:58:I1: Hostname: homeserver
03:33:58:I1: UTC Offset: 0
03:33:58:I1: PID: 499770
03:33:58:I1: CWD: /var/lib/fah-client
03:33:58:I1: Exec: /usr/bin/fah-client
03:33:58:I1:*******************************************************************
03:33:58:I2:<config/>
03:33:58:I1:Opening Database
03:33:58:I1:Generating RSA key......................................................................................................................................................................................................................................++++-................................++++-
03:34:00:I1:F@H ID = <censored>
03:34:00:I3:Loading default resource group
03:34:00:I1:Listening for HTTP on 127.0.0.1:7396
03:34:00:I3:Loaded 0 wus.
03:34:00:I1:OUT1:> GET https://api.foldingathome.org/gpus HTTP/1.1
03:34:02:I1:OUT1:< HTTP/1.1 200 HTTP_OK
03:34:02:I3:gpus = {
03:34:02:I3: "gpu:13:00:00": {
03:34:02:I3: "vendor": 4318,
03:34:02:I3: "type": "nvidia",
03:34:02:I3: "description": "NVIDIA GeForce GTX 1060 3GB",
03:34:02:I3: "uuid": "<censored>",
03:34:02:I3: "cuda": {"platform": 0, "device": 0, "compute": "6.1", "driver": "12.4"},
03:34:02:I3: "device": 7170,
03:34:02:I3: "supported": true
03:34:02:I3: }
03:34:02:I3:}
trl@homeserver:~$
This looks fine too
trl@homeserver:~$ nvidia-smi
Fri Apr 4 04:13:16 2025
| NVIDIA-SMI 550.120 Driver Version: 550.120 CUDA Version: 12.4 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| Fan Temp Perf Pwr:Usage/Cap | Memory-Usage | GPU-Util Compute M. |
| | | MIG M. |
| 0 NVIDIA GeForce GTX 1060 3GB Off | 00000000:0D:00.0 Off | N/A |
| 0% 32C P8 5W / 120W | 5MiB / 3072MiB | 0% Default |
| | | N/A |
| Processes: |
| GPU GI CI PID Type Process name GPU Memory |
| ID ID Usage |
| No running processes found |
trl@homeserver:~$
arisu
Posts: 596 Joined: Mon Feb 24, 2025 11:11 pm
Post
by arisu » Fri Apr 04, 2025 4:37 am
Click the settings icon. It gives you an option to select the GPU and to choose how many CPUs you want to use. Once you make your selections, press fold. It should start up.
Posts: 2493 Joined: Sun Dec 16, 2007 6:22 pm
Hardware configuration: 9950x, 9950x3d, 7950x3d, 5950x, 5800x3d 7900xtx, RX9070, Radeon 7, 5700xt, 6900xt, RX550, Intel B580
Post
by muziqaz » Fri Apr 04, 2025 4:41 am
It does not auto fold after installation
you need to manually start folding.
FAH Omega tester
trleith
Post
by trleith » Fri Apr 04, 2025 5:14 am
I tried clicking the settings icon. I get this
Post
by muziqaz » Fri Apr 04, 2025 6:27 am
Can you take a screenshot of your system info section withing the client web page?
FAH Omega tester
trleith
Post
by trleith » Sat Apr 05, 2025 1:43 am
Thanks for writing back.
I don't think there is one or maybe we're not talking about using "
https://v8-4.foldingathome.org/machines " but rather something like
http://192.168.0.6:10000 "
Is there something I can snag from a command line on the machine instead? A log file or something?
Post
by muziqaz » Sat Apr 05, 2025 5:27 am
In your main fah page, there is icon which has letter "i" in the circle. Click on that, take a screenshot.
You will never need to use any other URLs other than v8-4.foldingathome.org (maybe in the future it will change once client gets an update or something)
FAH Omega tester
trleith
Post
by trleith » Sun Apr 06, 2025 7:57 pm
Here it is. I don't see an "I". You can "Magnify Image"...
Posts: 1831 Joined: Sat Dec 08, 2007 1:33 am
Post
by calxalot » Sun Apr 06, 2025 8:30 pm
The i is in a disk, second from right.
It is disabled because the machine is disconnected.
Post
by calxalot » Sun Apr 06, 2025 8:32 pm
The client may not be running.
Or the client may have failed to connect to the api or node servers.
Post
by muziqaz » Sun Apr 06, 2025 9:25 pm
First create an account and log in. Then actually start the fahclient through the folding@home shortcut on the desktop or in start menu (web page is not the client)
muziqaz on Sun Apr 06, 2025 9:51 pm, edited 1 time in total.
FAH Omega tester
Post
by calxalot » Sun Apr 06, 2025 9:43 pm
They are logged in, because the account button has the person icon.
Post
by calxalot » Sun Apr 06, 2025 9:44 pm
The displayed machine is a disconnected machine linked to the account. There does not appear to be a local client running.
trleith
Post
by trleith » Mon Apr 07, 2025 2:17 am
No change in symptom so far as I can tell.
Reading comments.... Could I possibly have two accounts?
Warning: The unit file, source configuration file or drop-ins of fah-client.service changed on disk. Run 'syste>
Active: active (running) since Sat 2025-04-05 05:13:25 UTC; 1 day 20h ago
Main PID: 1728 (fah-client)
Tasks: 2 (limit: 115823)
Memory: 25.3M (peak: 26.8M)
CPU: 16.712s
└─1728 /usr/bin/fah-client --config=/etc/fah-client/config.xml --log=/var/log/fah-client/log.txt ->
Apr 05 05:13:25 homeserver systemd[1]: Started fah-client.service - Folding@home Client.
lines 1-12/12 (END)...skipping...
Warning: The unit file, source configuration file or drop-ins of fah-client.service changed on disk. Run 'systemctl daemon-reload' to reloa>
CPU: 16.712s
└─1728 /usr/bin/fah-client --config=/etc/fah-client/config.xml --log=/var/log/fah-client/log.txt --log-rotate-dir=/var/log/fah>
Apr 05 05:13:25 homeserver systemd[1]: Started fah-client.service - Folding@home Client.$
OK, let's try it
$trl@homeserver:~$ sudo systemctl daemon-reload
[sudo] password for trl:
trl@homeserver:~$ systemctl restart fah-client.service
==== AUTHENTICATING FOR org.freedesktop.systemd1.manage-units ====
Authentication is required to restart 'fah-client.service'.
Authenticating as: Thomas R.Leith (trl)
Password:
==== AUTHENTICATION COMPLETE ====
Active: active (running) since Mon 2025-04-07 01:47:22 UTC; 9s ago
Main PID: 111981 (fah-client)
Memory: 11.0M (peak: 11.6M)
CPU: 97ms
└─111981 /usr/bin/fah-client --config=/etc/fah-client/config.xml --log=/var/log/fah-client/log.txt --log-rotate-dir=/var/log/f>
Apr 07 01:47:22 homeserver systemd[1]: Started fah-client.service - Folding@home Client.
trl@homeserver:~$
## Log File
*********************** Log Started 2025-04-07T01:47:22Z ***********************
01:47:22:I1:*********************** Folding@home Client ***********************
01:47:22:I1: Version: 8.4.9
01:47:22:I1: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
01:47:22:I1: Org: foldingathome.org
01:47:22:I1: Copyright: 2023-2024, foldingathome.org
01:47:22:I1: Homepage: https://foldingathome.org/
01:47:22:I1: License: GPL-3.0-or-later
01:47:22:I1: URL: https://v8-4.foldingathome.org/
01:47:22:I1: Date: Nov 20 2024
01:47:22:I1: Time: 14:47:19
01:47:22:I1: Revision: 360fe71b1bd05bb89814bfb97b73a5bda84802d6
01:47:22:I1: Branch: master
01:47:22:I1: Compiler: GNU 8.3.0
01:47:22:I1: Options: -Wsuggest-override -faligned-new -std=c++17 -fsigned-char
01:47:22:I1: -ffunction-sections -fdata-sections -O3 -funroll-loops -fno-pie
01:47:22:I1: Platform: linux 4.19.0-27-cloud-amd64
01:47:22:I1: Bits: 64
01:47:22:I1: Mode: Release
01:47:22:I1: Args: --config=/etc/fah-client/config.xml
01:47:22:I1: --log=/var/log/fah-client/log.txt
01:47:22:I1: --log-rotate-dir=/var/log/fah-client/
01:47:22:I1: Config: /etc/fah-client/config.xml
01:47:22:I1:****************************** CBang ******************************
01:47:22:I1: Version: 1.7.2
01:47:22:I1: Org: Cauldron Development
01:47:22:I1: Copyright: Cauldron Development, 2003-2024
01:47:22:I1: Homepage: https://cauldrondevelopment.com/
01:47:22:I1: License: LGPL-2.1-or-later
01:47:22:I1: Date: Nov 19 2024
01:47:22:I1: Time: 21:54:38
01:47:22:I1: Revision: 443c54e909eb8d8994405a18fb328b5b05a623a5
01:47:22:I1: -fPIC
01:47:22:I1:***************************** System ******************************
01:47:22:I1: CPU: Intel(R) Xeon(R) CPU E5-2440 v2 @ 1.90GHz
01:47:22:I1: CPU ID: GenuineIntel Family 6 Model 62 Stepping 4
01:47:22:I1: CPUs: 32
01:47:22:I1: Memory: 94.34GiB
01:47:22:I1:Free Memory: 1.16GiB
01:47:22:I1: OS Version: 6.8
01:47:22:I1:Has Battery: false
01:47:22:I1: On Battery: false
01:47:22:I1: Hostname: homeserver
01:47:22:I1: UTC Offset: 0
01:47:22:I1: PID: 111981
01:47:22:I1: CWD: /var/lib/fah-client
01:47:22:I1: Exec: /usr/bin/fah-client
01:47:22:I1:*******************************************************************
01:47:22:I2:<config/>
01:47:22:I1:Opening Database
01:47:22:I1:F@H ID = --censored--
01:47:22:I3:Loading default resource group
01:47:22:I1:Listening for HTTP on 127.0.0.1:7396
01:47:22:I3:Loaded 0 wus.
01:47:22:I3:gpus = {
01:47:22:I3: "gpu:13:00:00": {
01:47:22:I3: "vendor": 4318,
01:47:22:I3: "type": "nvidia",
01:47:22:I3: "description": "NVIDIA GeForce GTX 1060 3GB",
01:47:22:I3: "uuid": "6e85d1db-b793-ad40-aeb2-fbec86dd3ff2",
01:47:22:I3: "opencl": {"platform": 0, "device": 0, "compute": "3.0", "driver": "560.35"},
01:47:22:I3: "cuda": {"platform": 0, "device": 0, "compute": "6.1", "driver": "12.6"},
01:47:22:I3: "device": 7170,
01:47:22:I3: "supported": true
01:47:22:I3: }
01:47:22:I3:}
trl@homeserver:~$
## Configuration
trl@homeserver:~$ cat /etc/fah-client/config.xml
<config/>
trl@homeserver:~$
Post
by calxalot » Mon Apr 07, 2025 4:09 am
F@H ID is not the account token
