Just installed a GTX 1650..... low PPD?
Demmers
Post by Demmers »
A friend gave me his old gaming machine, complete with an old AMD GPU whose model i've yet to determine, plus a GTX 1650.
I just installed the 1650 into my own machine, which is already folding with a Ryzen 3400G, both CPU and iGPU, no graphics card. I paused everything before the installation of the card and drivers, then proceeded to continue folding. I am puzzled by the current status. The 1650 is currently at 147,000 PPD... the base credit for the WU is 190,000! I see in https://folding.lar.systems/gpu_ppd/brands/nvidia/ that this card should be scoring much higher https://imgur.com/a/u47bHVa Am I missing something here? Am I right in seeing that CUDA isn't being used? The CPU was originally folding at 6 CPU's (4 cores, 8 threads) but i've just knocked that down to 4.
20:20:42:I1:WU295:Requesting WU assignment for user Demmers team 76140
20:20:43:I1:WU295:Received WU assignment cW41yHA6E52nOJAXvZ3g4L8vyl4ahSOGx0gQyETul4A
20:20:43:I1:WU295:Downloading WU
20:20:46:I1:WU295:Received WU P18238 R13 C4 G87
20:21:20:I3:WU295:Started FahCore on PID 11260
20:21:21:I1:WU295:*********************** Log Started 2025-04-02T20:21:21Z ***********************
20:21:21:I1:WU295:*************************** Core24 Folding@home Core ***************************
20:21:21:I1:WU295: Core: Core24
20:21:21:I1:WU295: Type: 0x24
20:21:21:I1:WU295: Version: 8.1.4
20:21:21:I1:WU295: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:21:21:I1:WU295: Copyright: 2022 foldingathome.org
20:21:21:I1:WU295: Homepage: https://foldingathome.org/
20:21:21:I1:WU295: Date: Jul 25 2024
20:21:21:I1:WU295: Time: 05:42:49
20:21:21:I1:WU295: Revision: cf9f0139862b8945a2091772770e4631aac37792
20:21:21:I1:WU295: Branch: HEAD
20:21:21:I1:WU295: Compiler: Visual C++
20:21:21:I1:WU295: Options: $( /TP $) /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2
20:21:21:I1:WU295: /Zc:throwingNew /MT -DOPENMM_VERSION="\"8.1.1\"" /Ox /std:c++14
20:21:21:I1:WU295: Platform: win32 10
20:21:21:I1:WU295: Bits: 64
20:21:21:I1:WU295: Mode: Release
20:21:21:I1:WU295:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
20:21:21:I1:WU295: <peastman@stanford.edu>
20:21:21:I1:WU295: Args: -dir cW41yHA6E52nOJAXvZ3g4L8vyl4ahSOGx0gQyETul4A -suffix 01
20:21:21:I1:WU295: -version 8.4.9 -lifeline 12188 -gpu-uuid
20:21:21:I1:WU295: 3227a2bb-d3bf-fde7-a41d-f837cf617a9f -gpu-platform cuda -gpu-vendor
20:21:21:I1:WU295: nvidia -opencl-platform 1 -opencl-device 0 -cuda-platform 0
20:21:21:I1:WU295: -cuda-device 0 -gpu 0
20:21:21:I1:WU295:************************************ libFAH ************************************
20:21:21:I1:WU295: Time: 05:23:50
20:21:21:I1:WU295: Revision: c7d2824a47eb025fa8cda8968c7a5e971585d90c
20:21:21:I1:WU295: Options: $( /TP $) /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
20:21:21:I1:WU295:************************************ CBang *************************************
20:21:21:I1:WU295: Version: 1.7.2
20:21:21:I1:WU295: Org: Cauldron Development LLC
20:21:21:I1:WU295: Copyright: Cauldron Development LLC, 2003-2024
20:21:21:I1:WU295: Homepage: https://cauldrondevelopment.com/
20:21:21:I1:WU295: License: LGPL-2.1-or-later
20:21:21:I1:WU295: Time: 05:22:43
20:21:21:I1:WU295: Revision: f1cd4c791e8c40a35dcfeab3ab85d910949cc0cb
20:21:21:I1:WU295:************************************ System ************************************
20:21:21:I1:WU295: CPU: AMD Ryzen 5 3400G with Radeon Vega Graphics
20:21:21:I1:WU295: CPU ID: AuthenticAMD Family 23 Model 24 Stepping 1
20:21:21:I1:WU295: CPUs: 8
20:21:21:I1:WU295: Memory: 13.92GiB
20:21:21:I1:WU295:Free Memory: 9.38GiB
20:21:21:I1:WU295: OS Version: 10.0
20:21:21:I1:WU295:Has Battery: false
20:21:21:I1:WU295: On Battery: false
20:21:21:I1:WU295: Hostname: PC
20:21:21:I1:WU295: UTC Offset: 1
20:21:21:I1:WU295: PID: 11260
20:21:21:I1:WU295: CWD: C:\ProgramData\FAHClient\work
20:21:21:I1:WU295: Exec: C:\ProgramData\FAHClient\cores\openmm-core-24\windows-10-64bit\release\fahcore-24-windows-10-64bit-release-8.1.4\FahCore_24.exe
20:21:21:I1:WU295:************************************ OpenMM ************************************
20:21:21:I1:WU295: Version: 8.1.1
20:21:21:I1:WU295:********************************************************************************
20:21:21:I1:WU295:Project: 18238 (Run 13, Clone 4, Gen 87)
20:21:21:I1:WU295:Reading tar file core.xml
20:21:21:I1:WU295:Reading tar file integrator.xml
20:21:21:I1:WU295:Reading tar file state.xml.bz2
20:21:21:I1:WU295:Reading tar file system.xml.bz2
20:21:21:I1:WU295:Digital signatures verified
20:21:21:I1:WU295:Folding@home GPU Core24 Folding@home Core
20:21:21:I1:WU295:Version 8.1.4
20:21:21:I1:WU295: Checkpoint write interval: 50000 steps (2%) [50 total]
20:21:21:I1:WU295: JSON viewer frame write interval: 25000 steps (1%) [100 total]
20:21:21:I1:WU295: XTC frame write interval: 10000 steps (0.4%) [250 total]
20:21:21:I1:WU295: TRR frame write interval: disabled
20:21:21:I1:WU295: Global context and integrator variables write interval: disabled
20:21:21:I1:WU295:There are 4 platforms available.
20:21:21:I1:WU295:Platform 0: Reference
20:21:21:I1:WU295:Platform 1: CPU
20:21:21:I1:WU295:Platform 2: OpenCL
20:21:21:I1:WU295: opencl-device 0 specified
20:21:21:I1:WU295:Platform 3: CUDA
20:21:21:I1:WU295: cuda-device 0 specified
20:21:44:I1:WU295:Attempting to create CUDA context:
20:21:44:I1:WU295: Configuring platform CUDA
20:22:01:I1:WU295: Using CUDA on CUDA Platform and gpu 0
20:22:01:I1:WU295: GPU info: Platform: CUDA
20:22:01:I1:WU295: GPU info: PlatformIndex: 0
20:22:01:I1:WU295: GPU info: Device: NVIDIA GeForce GTX 1650
20:22:01:I1:WU295: GPU info: DeviceIndex: 0
20:22:01:I1:WU295: GPU info: Vendor: 0x10de
20:22:01:I1:WU295: GPU info: PCI: 01:00:00
20:22:01:I1:WU295: GPU info: Compute: 7.5
20:22:01:I1:WU295: GPU info: Driver: 12.8
20:22:01:I1:WU295: GPU info: GPU: true
20:22:01:I1:WU295:Completed 0 out of 2500000 steps (0%)
20:22:03:I1:WU295:Checkpoint completed at step 0
20:48:12:I1:WU295:Completed 25000 out of 2500000 steps (1%)
21:14:29:I1:WU295:Completed 50000 out of 2500000 steps (2%)
21:14:31:I1:WU295:Checkpoint completed at step 50000
21:40:58:I1:WU295:Completed 75000 out of 2500000 steps (3%)
22:07:14:I1:WU295:Completed 100000 out of 2500000 steps (4%)
22:07:16:I1:WU295:Checkpoint completed at step 100000
22:33:35:I1:WU295:Completed 125000 out of 2500000 steps (5%)
https://imgur.com/a/1WVYDws
arisu
Re: Just installed a GTX 1650..... low PPD?
Post by arisu »
It is using CUDA, that's not the problem.
Pause folding on both the CPU cores and iGPU and see if the PPD on the GPU increases. Nvidia GPUs are notorious for their sensitivity to unrelated workloads.
jonault
Post by jonault »
I'll second arisu's recommendation to pause CPU folding to see if that improves things; personally I only set aside 1 CPU core for each GPU. I'm not sure how many points exactly to expect from a 1650; my 1660 super is currently running around 1.4-1.5 million PPD; I would certainly expect a 1650 to do better than just 10% of that.
Demmers
Post by Demmers »
You both nailed it, thanks! :)
https://imgur.com/a/04Pznit
