PCIe bandwidth requirements (RTX 50xx edition)
I am preparing to build a new system with four RTX 5080 GPUs (with the plan to upgrade to eight when the 5080 prices drop in a year or two). That's too much heat to put in one box without some seriously loud cooling so it will all be open air. I'm considering a single board computer and using ribbon risers (and NOT those awful 1x USB risers used for mining) to make space for the GPUs.
What are the PCIe bandwidth requirements for folding on something like a 5080? 8x and PCIe 4.0 (or perhaps 4x on PCIe 5.0)?
As ribbon length goes up, signal quality decreases. Does this increase latency in a way that impacts folding (like if it means more retransmissions that leave CUDA cores idle waiting for work) or is it an all-or-nothing thing where eventually the ribbon is too long and reliability plummets?
Re: PCIe bandwidth requirements (RTX 50xx edition)
X4 is the minimum
X1 definitely does not work
Retvari Zoltan
A motherboard and CPU that can drive 8 cards at least with x4 bandwith is quite expensive. Risers further increase the costs. Personally I prefer cheaper motherboards / CPUs (i3) (for builds dedicated to GPU crunching) and single GPUs. Crunching on CPUs and (Nvidia) GPUs simultaneously can significantly reduce the GPU crunching speed, the same is true to some extent for multiple GPUs in the same system. You should consider this, or something in between. For example dual (water cooled) GPU systems (without risers, and expensive motherboards).
The minimum for what PCIe gen? x4 on PCIe 5.0 has about the same bandwidth as x8 on PCIe 4.0.
When you say minimum is there any performance loss for using x4? I don't want to find out that "minimum" just means that it can barely finish a WU before it expires. But I also don't want to spend a lot of money on a high-end motherboard with extra PCIe lanes if the bus doesn't get even close to saturated.
Pcie3. Since I really don't think one would still run pcie2 mobos in this day and age
I think the testing that showed an x4 lane connection was enough on PCIe 3 dates back to the era of the 3090 cards, and even then showed some loss of processing speed compared to x8 or wider connections. I don't recall any newer testing mentioned here, possibly on the discord but I don't follow that.
Then to be safe, a 5.0@x4 or 4.0@x8 would be a good bet for a 5080. Then I could use M.2 to PCIe adapters and risers since M.2 is x4 which should be enough if it's PCIe 5.0, right?
I might just build two machines, both with four 5080s, instead of trying to squeeze out bandwidth from a consumer motherboard.
Are you really asking about the just released GPU testing on decades old standards and speeds?
With every new generation user is on their own to find out what is and what is not working for them.
We can only provide what is definitely not working.
Well that's why this thread is the RTX 50xx edition!
Wouldn't it be enough for someone with a 5080 to see what their PCIe bandwidth usage is like? If they're using under 64 GT/s then even x2 is fine if it's PCIe 5.0 (which is the newest that is in common usage). I don't want to make a very expensive mistake.
Since 4.0 is more common today especially with cheaper motherboards, I am curious if a single x16 could be used for four 5080s with something like:
If 64 GT/s is enough (5.0@x2, 4.0@x4, 3.0@x8 etc) then that would work well. But without knowing the actual bandwidth requirements in GT/s, I can only guess. I just assumed someone might know what the requirements are based on the bandwidth usage on their system (doesn't nvidia-smi tell it?).
First you need to find someone who can afford or even find to buy one, let alone fold on it and afford the electricity bill.
As I said you are on your own in this with brand new hardware.
Buy one 5080, and test it, then buy the rest of the hardware
I think some people on discord have it.
You should ask there about folding bandwidth used.
What software can report how much PCIe bandwidth is used by a GPU? Genuinely curious here!
Windows task manager will do it for storage drives, but not GPUs...
On Linux for Nvidia GPUs there's nvidia-smi. On Windows with an Intel processor, I guess this thing might work? https://github.com/intel/pcm
Here is some data on PCIe bandwidth utilization for a 4090 Mobile (8x PCIe 4.0 connection). Not quite a 5080, but in the same league compared to anything from the PCIe 3.0 era.
This is 40 seconds of folding at one sample per second. The fields rxpci and txpci are PCIe throughput in MB/s. It shows about 9 MB/s received constantly with occasional bursts into multiple GB/s, and data sent at about 1 MB/s, punctuated by bursts of hundreds of MB/s. So even though throughput at any given time is very low and often well under 1% of even an 8x PCIe 4.0 link, it has to handle very fast bursts of data in both directions.
The other fields are not as important. mclk and pclk are memory and processor clock rates, sm is the percentage of the time that at least one CUDA core was being used, mem is the percentage of the time VRAM is being read or written to (a bit higher for me than usual because I reduce the memory clock from 9000 to 6000 which lets the CUDA cores boost higher while staying within the 150W TDP, though only some projects benefit from that). The rest (enc, dec, jpg, and ofa) are for other fixed-function accelerators in the GPU that FAH doesn't use.
Other projects on other cores can have very different PCIe utilization behavior. Here is a project running on a GTX 970M (Maxwell), showing a near constant 2-3 GB/s received and about 300 MB/s sent:
$ nvidia-smi dmon -i 0 -s tcu -c 40
# gpu rxpci txpci mclk pclk sm mem enc dec jpg ofa
# Idx MB/s MB/s MHz MHz % % % % % %
0 7 656 6000 2145 95 17 0 0 0 0
0 9 1 6000 1995 98 16 0 0 0 0
0 9 1 6000 1950 98 17 0 0 0 0
0 9 1 6000 1980 96 16 0 0 0 0
0 10 2 6000 1995 85 14 0 0 0 0
0 7 1 6000 2205 98 16 0 0 0 0
0 8 1 6000 2235 97 16 0 0 0 0
0 10 1 6000 1995 94 16 0 0 0 0
0 9 1 6000 1995 98 17 0 0 0 0
0 9 1310 6000 2025 98 17 0 0 0 0
0 682 1 6000 2040 81 14 0 0 0 0
0 9 1 6000 1980 98 17 0 0 0 0
0 2 0 6000 2310 98 17 0 0 0 0
0 9 1 6000 2010 98 17 0 0 0 0
0 9 1 6000 1980 86 14 0 0 0 0
0 5 656 6000 1950 96 16 0 0 0 0
0 9 656 6000 1980 98 17 0 0 0 0
0 9 1 6000 2025 98 17 0 0 0 0
0 8 1739 6000 2085 98 17 0 0 0 0
0 6 939 6000 2205 96 16 0 0 0 0
0 7 1076 6000 2025 96 16 0 0 0 0
0 680 656 6000 2310 82 13 0 0 0 0
0 9 1 6000 1905 98 17 0 0 0 0
0 9 1 6000 2025 97 16 0 0 0 0
0 6 1 6000 2070 93 15 0 0 0 0
0 8 1 6000 1980 96 16 0 0 0 0
0 9 1 6000 2010 98 16 0 0 0 0
0 9 1 6000 1995 93 14 0 0 0 0
0 0 42 6000 2010 97 15 0 0 0 0
0 8 1310 6000 2100 96 15 0 0 0 0
0 9 1 6000 1965 98 16 0 0 0 0
0 1182 22 6000 2310 83 13 0 0 0 0
0 5 656 6000 2010 98 16 0 0 0 0
0 7 1 6000 1980 98 16 0 0 0 0
0 10 1 6000 1995 81 13 0 0 0 0
0 7 656 6000 1950 97 16 0 0 0 0
0 2477 250 2505 772 94 47 0 0 - -
0 2498 307 2505 772 99 47 0 0 - -
0 527 389 2505 772 100 54 0 0 - -
0 2512 310 2505 772 94 44 0 0 - -
0 2379 290 2505 772 99 49 0 0 - -
0 3306 237 2505 772 99 46 0 0 - -
0 2783 293 2505 772 100 51 0 0 - -
0 2757 224 2505 772 98 47 0 0 - -
0 2647 230 2505 772 99 48 0 0 - -
0 2705 259 2505 772 100 52 0 0 - -
0 1915 215 2505 772 100 53 0 0 - -
0 2527 298 2505 772 98 48 0 0 - -
0 2527 229 2505 772 79 37 0 0 - -
0 2722 276 2505 772 100 52 0 0 - -
0 2381 249 2505 772 100 53 0 0 - -
0 2738 272 2505 772 84 45 0 0 - -
0 2676 302 2505 772 94 45 0 0 - -
0 2445 254 2505 772 94 44 0 0 - -
0 2398 233 2505 772 84 45 0 0 - -
0 357 254 2505 772 95 47 0 0 - -
0 2465 300 2505 772 99 49 0 0 - -
0 3118 253 2505 772 97 49 0 0 - -
0 2813 242 2505 772 100 53 0 0 - -
0 640 285 2505 772 100 54 0 0 - -
0 2927 245 2505 772 98 47 0 0 - -
0 2406 297 2505 772 98 47 0 0 - -
0 2794 199 2505 772 100 53 0 0 - -
0 1846 0 2505 772 100 53 0 0 - -
0 2870 234 2505 772 99 49 0 0 - -
0 3391 221 2505 772 100 54 0 0 - -
0 642 273 2505 772 100 52 0 0 - -
0 2530 240 2505 772 100 53 0 0 - -
0 2958 221 2505 772 98 49 0 0 - -
0 2922 257 2505 772 100 54 0 0 - -
0 1643 443 2505 772 100 52 0 0 - -
0 2648 223 2505 772 100 53 0 0 - -
0 2656 256 2505 772 99 48 0 0 - -
0 3362 218 2505 772 99 52 0 0 - -
0 3256 237 2505 772 100 53 0 0 - -
0 2724 230 2505 772 98 50 0 0 - -
