Hello,
I have registered myself at F@H website with a wrong CURE wallet address. Is there a way to change it?
F@H details
Re: F@H details
Folding@home is not affiliated with CURE or any other cryptocurrency. FAH isn't against cryptos, but they are not run by or managed by FAH. Here is the official statement on cryptos: https://foldingathome.org/2019/01/14/fo ... urrencies/
You'll have to ask whoever is in charge of CURE what you have to do, but if it is as simple as changing your username, then open the web app, click the little gear icons for settings, make any changes you want to your username, then click save, and your username will update shortly:
(Images from the v8 client guide)
Re: F@H details
Yes, FAH has nothing to do with any wallets. There is no option within FAH to do any of the wallet stuff. So ask cure coiners for advice
