DGX Spark
scorpuk
DGX Spark
Post by scorpuk »
Any info on whether this will fold or not and if so how well?
Cheers.
Re: DGX Spark
Post by muziqaz »
This is for AI crap. There is no interest to even think about it folding. Those 20 arm cores would do some folding for sure, but I can find 3000 ways to fold better and faster.
nVidia lost the plot to the point where they don't bother showing FP32 performance on their 5090 anymore, let alone this one.
FAH Omega tester
arisu
Re: DGX Spark
Post by arisu »
It would fold pretty well, but it wouldn't fold anywhere close to as well as it might seem based on its price. I can't find their FP32 numbers but I'm guessing it'll be somewhere between the 5080 and the 5090.
That machine is made for low-precision floating point arithmetic for the purpose of "AI" crap, so it has a lot of Tensor cores (fast, low-precision) and relatively few CUDA cores (slower, higher-precision). Molecular simulations can't make use of FP4, so that massive 1 PFLOP of FP4 performance might as well be 0 FLOPS. Simulations can't even make use of FP16 (although I think OpenMM uses FP16 in one place, but it's not a place where performance matters), and even FP32 takes effort to use correctly, with FP64 being used when needed.
That thing runs a customized version of Ubuntu, so I'm guessing it would technically be able to fold. No clue if the GPU is on the whitelist.
Re: DGX Spark
Post by muziqaz »
Does it even come close to 4090/5090 in CUDA core count?
That GPU will not going to be on the whitelist, but if one is adventurous enough to buy one and use it for other thing rather than AI, more than welcome to drop the PCI ID here ;)
FAH Omega tester
PaulTV
Re: DGX Spark
Post by PaulTV »
The CPU is ARM based, and afaik the ARM client does not support GPU folding anyway
Ryzen 9800X3D / RTX 4090
Ryzen 5800X / RTX 5070 Ti
Ryzen 5600 / RTX 3070 Ti
All running Fedora 43 with folding client v8.5.6
Re: DGX Spark
Post by muziqaz »
Windows on ARM or Linux on ARM exist :)
FAH Omega tester
Re: DGX Spark
Post by calxalot »
No ARM GPU cores have been built for any platform.
Re: DGX Spark
Post by muziqaz »
calxalot wrote: Fri Mar 21, 2025 9:49 pm No ARM GPU cores have been built for any platform.
Nvidia GPU cores are not ARM, are they?
FAH Omega tester
Re: DGX Spark
Post by calxalot »
Irrelevant. The fahcore that talks to the GPU runs on the cpu, as you know.
foxpy
Re: DGX Spark
Post by foxpy »
I suppose the correct question would be "Are fah cores 0x22, 0x23 or 0x24 compiled for arm64?"
Re: DGX Spark
Post by muziqaz »
foxpy wrote: Sat Mar 22, 2025 2:52 pm I suppose the correct question would be "Are fah cores 0x22, 0x23 or 0x24 compiled for arm64?"
As calxalot said, they are not
FAH Omega tester
