(RX550)(Ubuntu) how opencl in 2025
nada391
Post by nada391 »
Hello ,
i have one rx 550 and one small gpu wx 2100 which is professional grade,
which could be used for this project,
however, for linux it is difficult to install latest driver.
for wx 2100, the latest amdgpu on homepage is for ubuntu 22.04.3
and rx 550 gives for newer ubuntu 22.04.5
have installed on ubuntu radeon pro graphics driver for 22.04. which initially seems to funciton just fine,
but probably server applied some update and resulted clinfo in "segmentatin fault".
what is correct way to apply drivers in linux for those card;
now upgraded to 24.04, here is situation
Hostname
ubuntuserver
OS
linux
Client Version
8.4.9
OS Version
6.8
Build Mode
Release
Revision
360fe71b1bd05bb89814bfb97b73a5bda84802d6
Has Battery
false
On Battery
false
CPU
Description
Intel(R) Xeon(R) CPU E3-1220 v5 @ 3.00GHz
Cores
4
Type
amd64
gpu:03:00:00
Description
Lexa XT [Radeon Pro WX2100]
Vendor
amd
Supported
false
UUID
PCI Device ID
0x6995
PCI Vendor ID
0x1002
OpenCL
unsupported
CUDA
unsupported
[/size]
clinfo
Number of platforms                               2
  Platform Name                                   Clover
  Platform Vendor                                 Mesa
  Platform Version                                OpenCL 1.1 Mesa 24.2.8-1ubuntu1~24.04.1
  Platform Extensions                             cl_khr_icd
  Platform Extensions function suffix             MESA
  Platform Name                                   rusticl
  Platform Vendor                                 Mesa/X.org
  Platform Version                                OpenCL 3.0
  Platform Extensions                             cl_khr_byte_addressable_store cl_khr_create_command_queue cl_khr_expect_assume cl_khr_extended_versioning cl_khr_icd cl_khr_il_program cl_khr_spirv_no_integer_wrap_decoration cl_khr_suggested_local_work_size
  Platform Extensions with Version                cl_khr_byte_addressable_store                                    0x400000 (1.0.0)
                                                  cl_khr_create_command_queue                                      0x400000 (1.0.0)
                                                  cl_khr_expect_assume                                             0x400000 (1.0.0)
                                                  cl_khr_extended_versioning                                       0x400000 (1.0.0)
                                                  cl_khr_icd                                                       0x400000 (1.0.0)
                                                  cl_khr_il_program                                                0x400000 (1.0.0)
                                                  cl_khr_spirv_no_integer_wrap_decoration                          0x400000 (1.0.0)
                                                  cl_khr_suggested_local_work_size                                 0x400000 (1.0.0)
  Platform Numeric Version                        0xc00000 (3.0.0)
  Platform Host timer resolution                  1ns
  Device Name                                     AMD Radeon Pro WX 2100 (radeonsi, polaris12, LLVM 19.1.1, DRM 3.57, 6.8.0-55-generic)
  Device Vendor                                   AMD
  Device Version                                  OpenCL 1.1 Mesa 24.2.8-1ubuntu1~24.04.1
  Device Numeric Version                          0x401000 (1.1.0)
  Driver Version                                  24.2.8-1ubuntu1~24.04.1
  Device OpenCL C Version                         OpenCL C 1.1
  Device OpenCL C Numeric Version                 0x401000 (1.1.0)
  Max compute units                               8
  Max clock frequency                             1219MHz
  Max work item sizes                             256x256x256
  Preferred work group size multiple (kernel)     64
    char                                                16 / 16
    short                                                8 / 8
    int                                                  4 / 4
    long                                                 2 / 2
    half                                                 0 / 0        (n/a)
    float                                                4 / 4
    double                                               2 / 2        (cl_khr_fp64)
  Half-precision Floating-point support           (n/a)
    Denormals                                     No
    Round to zero                                 No
    Round to infinity                             No
    IEEE754-2008 fused multiply-add               No
    Correctly-rounded divide and sqrt operations  No
  Global memory size                              2147483648 (2GiB)
  Max memory allocation                           536870912 (512MiB)
  Alignment of base address                       32768 bits (4096 bytes)
  Global Memory cache type                        None
  Image support                                   No
  Local memory size                               65536 (64KiB)
  Max number of constant args                     16
  Max constant buffer size                        67108864 (64MiB)
  Queue properties
  Profiling timer resolution                      0ns
  Execution capabilities
    ILs with version                              (n/a)
  Built-in kernels with version                   (n/a)
  Device Extensions                               cl_khr_byte_addressable_store cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_int64_base_atomics cl_khr_int64_extended_atomics cl_khr_fp64 cl_khr_extended_versioning
  Device Extensions with Version                  cl_khr_byte_addressable_store                                    0x400000 (1.0.0)
                                                  cl_khr_global_int32_base_atomics                                 0x400000 (1.0.0)
                                                  cl_khr_global_int32_extended_atomics                             0x400000 (1.0.0)
                                                  cl_khr_local_int32_base_atomics                                  0x400000 (1.0.0)
                                                  cl_khr_local_int32_extended_atomics                              0x400000 (1.0.0)
                                                  cl_khr_int64_base_atomics                                        0x400000 (1.0.0)
                                                  cl_khr_int64_extended_atomics                                    0x400000 (1.0.0)
                                                  cl_khr_fp64                                                      0x400000 (1.0.0)
Number of devices                                 0
NULL platform behavior
  clGetPlatformInfo(NULL, CL_PLATFORM_NAME, ...)  Clover
  clGetDeviceIDs(NULL, CL_DEVICE_TYPE_ALL, ...)   Success [MESA]
  clCreateContext(NULL, ...) [default]            Success [MESA]
  clCreateContext(NULL, ...) [other]              <error: no devices in non-default plaforms>
  clCreateContextFromType(NULL, CL_DEVICE_TYPE_DEFAULT)  Success (1)
  clCreateContextFromType(NULL, CL_DEVICE_TYPE_GPU)  Success (1)
  clCreateContextFromType(NULL, CL_DEVICE_TYPE_CUSTOM)  No devices found in platform
  clCreateContextFromType(NULL, CL_DEVICE_TYPE_ALL)  Success (1)
ICD loader properties
  ICD loader Name                                 OpenCL ICD Loader
  ICD loader Vendor                               OCL Icd free software
  ICD loader Version                              2.3.2
  ICD loader Profile                              OpenCL 3.0
[/size]
thank you!
Re: (RX550)(Ubuntu) how opencl in 2025
Post by muziqaz »
Uninstall Mesa, and use Ultimate guide to fold on Linux in this forum. Replace 6.2.4 rocm with 5.4 instead
Ultimately, don't bother with that hardware, it will not get much work anyways, if any
FAH Omega tester
nada391
Post by nada391 »
have installed driver from latest package for 22.04.3
https://repo.radeon.com/amdgpu-install/ ... -1_all.deb
there
"amdgpu-install --usecase=workstation -y --vulkan=pro --opencl=legacy --no-32 --accept-eula"
now what is miissing is
"rocm-opencl-sdk" to get "accepted" by fah-client;
is this recipe for disaster, have both amdgpu-install and rocm-opencl-sdk , or is this acceptable?
should amdgpu-install not even be used? but for desktop use and vulkan , it seem proper.
thank and happy day.
Post by muziqaz »
FAH Omega tester
nada391
Post by nada391 »
thanks, it function with newer APU (picass=)
hopefully also with GCN4.0,
another computer has internal Raphael and RDNA3.0 GPU;
there is bit of conflicting info in fah-webclient.
Description
gfx1102
Vendor
amd
Supported
true
UUID
PCI Device ID
0x7480
PCI Vendor ID
0x1002
OpenCL
supported
Compute
2.0
Driver
3625.0
CUDA
unsupported
gpu:19:00:00
Description
gfx1036
Vendor
amd
Supported
false
UUID
PCI Device ID
0x13c0
PCI Vendor ID
0x1002
OpenCL
supported
Compute
2.0
Driver
3625.0
CUDA
unsupported
is gfx1036 supported=false because the GPU is inserted or is something wrong with the settings?
thanks!
Post by muziqaz »
It is because it is not whitelisted
Give it couple of days and it should sort itself out
What specific CPU is it on?
FAH Omega tester
nada391
Post by nada391 »
hello, it§s on 9700x, glad to have received it.
best of wishes!
