FAH is not finding DNS?
TheDevil
Post by TheDevil »
07:41:36:I1:*********************** Folding@home Client ***********************
07:41:36:I1: Version: 8.4.9
07:41:36:I1: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:41:36:I1: Org: foldingathome.org
07:41:36:I1: Copyright: 2023-2024, foldingathome.org
07:41:36:I1: Homepage: https://foldingathome.org/
07:41:36:I1: License: GPL-3.0-or-later
07:41:36:I1: URL: https://v8-4.foldingathome.org/
07:41:36:I1: Date: Nov 20 2024
07:41:36:I1: Time: 14:47:46
07:41:36:I1: Revision: 360fe71b1bd05bb89814bfb97b73a5bda84802d6
07:41:36:I1: Branch: master
07:41:36:I1: Compiler: Visual C++
07:41:36:I1: Options: $( /TP $) /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2
07:41:36:I1: /Zc:throwingNew /MT
07:41:36:I1: Platform: win32 10
07:41:36:I1: Bits: 64
07:41:36:I1: Mode: Release
07:41:36:I1: Args: --open-web-control
07:41:36:I1: Config: s:\ProgramData\FAHClient\config.xml
07:41:36:I1:****************************** CBang ******************************
07:41:36:I1: Version: 1.7.2
07:41:36:I1: Org: Cauldron Development
07:41:36:I1: Copyright: Cauldron Development, 2003-2024
07:41:36:I1: Homepage: https://cauldrondevelopment.com/
07:41:36:I1: License: LGPL-2.1-or-later
07:41:36:I1: Time: 09:04:40
07:41:36:I1: Revision: 443c54e909eb8d8994405a18fb328b5b05a623a5
07:41:36:I1:***************************** System ******************************
07:41:36:I1: CPU: Intel(R) Xeon(R) CPU E5-2650L v4 @ 1.70GHz
07:41:36:I1: CPU ID: GenuineIntel Family 6 Model 79 Stepping 1
07:41:36:I1: CPUs: 56
07:41:36:I1: Memory: 127.87GiB
07:41:36:I1:Free Memory: 118.16GiB
07:41:36:I1: OS Version: 6.2
07:41:36:I1:Has Battery: false
07:41:36:I1: On Battery: false
07:41:36:I1: Hostname: ******
07:41:36:I1: UTC Offset: -4
07:41:36:I1: PID: 21036
07:41:36:I1: CWD: s:\ProgramData\FAHClient
07:41:36:I1: Exec: C:\Program Files\FAHClient\FAHClient.exe
07:41:36:I1:*******************************************************************
07:41:36:I2:<config>
07:41:36:I2: <!-- Project Settings -->
07:41:36:I2: <cause v='HIGH_PRIORITY'/>
07:41:36:I2:
07:41:36:I2: <!-- Resource Settings -->
07:41:36:I2: <cpus v='30'/>
07:41:36:I2:</config>
07:41:36:I1:Opening Database
07:41:36:I1:F@H ID = ******
07:41:36:I3:Loading default resource group
07:41:36:I1:Listening for HTTP on 127.0.0.1:7396
07:41:36:I3:Loaded 0 wus.
07:41:36:W :CON1:DNS lookup failed for api.foldingathome.org
07:41:36:E :OUT1:Failed response: CONNECT
07:41:36:W :CON2:DNS lookup failed for api.foldingathome.org
07:41:36:W :Failed to update GPUs
07:41:36:I1:Started Windows systray control
07:41:41:W :CON4:DNS lookup failed for api.foldingathome.org
07:41:41:W :Failed to update GPUs
07:41:51:W :CON5:DNS lookup failed for api.foldingathome.org
07:41:51:E :OUT5:Failed response: CONNECT
07:41:51:W :CON6:DNS lookup failed for api.foldingathome.org
07:41:51:W :Failed to update GPUs
07:42:11:W :CON7:DNS lookup failed for api.foldingathome.org
07:42:11:W :Failed to update GPUs
07:42:13:W :CON8:DNS lookup failed for api.foldingathome.org
07:42:13:E :OUT8:Failed response: CONNECT
07:42:46:W :CON9:DNS lookup failed for api.foldingathome.org
07:42:46:E :OUT9:Failed response: CONNECT
07:42:51:W :CON10:DNS lookup failed for api.foldingathome.org
And this is all I get so far:
I've done all kinds of troubleshooting. It seems like FAH itself is having the problem resolving DNS.
I've checked all firewall permissions, both on the Firewall and the local.
I also tried a downgrade to 8.3.17 and it still had the same issue.
I didn't see any solution in the forums except people being told to get on the beta and this version 8.4.9 was the beta and most current build I could find..
Re: FAH is not finding DNS?
Post by muziqaz »
Change your DNS to anything but cloudflare
FAH Omega tester
TheDevil
Post by TheDevil »
Not using Cloudflare I am using the default FIOS one.
It resolves in cmd.
Is there a command for the config to give it a specific DNS? I am willing to use the google one at this point
Also other machines on the same network, are working and able to get data.
Post by muziqaz »
Google one should work, and there is no commands to assign specific DNS for client
FAH Omega tester
TheDevil
Post by TheDevil »
From that computer:
PS C:\Users\FAH> wget api.foldingathome.org
StatusCode        : 200
StatusDescription : HTTP_OK
Content           : <!DOCTYPE html>
                    <html lang="en">
                      <head>
                        <meta charset="utf-8"/>
                        <link rel="icon" href="/favicon.ico"/>
                        <link rel="stylesheet" href="/css/swagger-ui.css">
                        <meta name="viewport" conten...
RawContent        : HTTP/1.1 200 HTTP_OK
                    Transfer-Encoding: chunked
                    Connection: keep-alive
                    Vary: Origin
                    Access-Control-Allow-Methods: POST,PUT,GET,OPTIONS,DELETE
                    Access-Control-Allow-Headers: DNT,User-Agent,X-Reques...
Forms             : {}
Headers           : {[Transfer-Encoding, chunked], [Connection, keep-alive], [Vary, Origin],
                    [Access-Control-Allow-Methods, POST,PUT,GET,OPTIONS,DELETE]...}
Images            : {}
InputFields       : {}
Links             : {}
ParsedHtml        : System.__ComObject
RawContentLength  : 488
But still FAH can not connect?
It seems to be something specific to FAH?
Post by muziqaz »
It probably is. Go to GitHub and search for fahclient-bastet. Search the issue list for DNS related topics (open and closed), and mention your experience in one of the issues related to DNS, please. Dev will have a look into it
FAH Omega tester
You are storing your client data to a drive called S:\ ... what is it ?
A friend found a strange workaround on Linux for this, so you might want to try it on Windows too. Find the gpus.json file in s:\ProgramData\FAHClient and delete it. Then restart the client (or reboot the whole system).
