Please add the Radeon RX 9070 and RX 9070 XT
Trakoma
Post by Trakoma »
Hello everyone,
would be great if the new AMD GPUs could be whitelisted.
Thank you very much.
Re: Please add ne Radeon RX 9070 and RX 9070 XT
If you could read this post - viewtopic.php?p=262894#p262894 - from the stickied topic for this subforum, and supply the PCI ID information for your RX 9070 XT. That can speed up the addition of this new card.
Post by muziqaz »
They are already whitelisted from last week Thursday, just server is shi**ing the bed and is not syncing.
Patience
FAH Omega tester
Trakoma
Post by Trakoma »
Thank you both for your response. Sorry that I did not check the mentioned stickied Topic.
Ok, I will try it again later :) thanks again
Vico311
Re: Whitelist/Blacklist Change-Log (Greylist)
Post by Vico311 »
Merged with existing topic for RX 9070s, see above for status of getting GPU added - j
Checked the GPU whitelist and my new AMD 9070 XT is not listed.
Here is the name and Device ID:
AMD Radeon RX 9070 XT
1002 7550-148c 2435
Log section:
03:38:04:I1:Started Windows systray control
03:38:05:I3:gpus = {
03:38:05:I3: "gpu:03:00:00": {
03:38:05:I3: "vendor": 4098,
03:38:05:I3: "type": "amd",
03:38:05:I3: "description": "gfx1201",
03:38:05:I3: "opencl": {"platform": 0, "device": 0, "compute": "2.0", "driver": "3640.0"},
03:38:05:I3: "device": 30032,
03:38:05:I3: "supported": false
03:38:05:I3: }
03:38:05:I3:}
03:38:05:I1:Default:Added new work unit: cpus:11 gpus:
Thank you,
Post by muziqaz »
OK, GPU finally is recognised. Please restart your computers and try start folding. Initial run shows 5m PPD on non xt 9070
FAH Omega tester
Trakoma
Post by Trakoma »
Thank you! I rebooted and started Folding but unfortunately it still states "unsupported".
I checked GPU-Z and here are the information:
1002 7550 - 1DA2 E490
Log section:
08:57:38:I1:Started Windows systray control
08:57:38:I3:gpus = {
08:57:38:I3: "gpu:10:00:00": {
08:57:38:I3: "vendor": 4098,
08:57:38:I3: "type": "amd",
08:57:38:I3: "description": "gfx1201",
08:57:38:I3: "opencl": {"platform": 0, "device": 0, "compute": "2.0", "driver": "3640.0"},
08:57:38:I3: "device": 30032,
08:57:38:I3: "supported": false
Maybe this is due to the differen Device ID?
Thanks for your help!
Re: Please add the Radeon RX 9070 and RX 9070 XT
Post by muziqaz »
ID is the same.
Go to C:\ProgramData\FAHClient
Delete GPUs.json file. Restart the pc
FAH Omega tester
Trakoma
Post by Trakoma »
Thank you! That worked.
4.289.804 PPD at the moment.
Post by muziqaz »
It varies from 3m to 6m
FAH Omega tester
