systemd free distro *Devuan
FAH provides a V7 client installer for Debian / Mint / Ubuntu / RedHat / CentOS / Fedora. Installation on other distros may or may not be easy but if you can offer help to others, they would appreciate it.
nada391
Post by nada391 »
Hello ,
are there building instructions for systemd-free distro like Devuan 5.0 (based on Debian 12)
tried to install via amd64.deb, but it would not function due to missing systemctl.
thanks.
Re: systemd free distro *Devuan
Post by calxalot »
You need to build yourself on a system that does not have systemd.
https://github.com/FoldingAtHome/fah-cl ... ING-RPM.md
Post by calxalot »
You probably can’t use the built rpm package, which I think assumes systemd.
Just use the built executable in a directory of your choosing.
The client always uses the current working directory as the data directory when launched.
nada391
Post by nada391 »
hello
these building instructions indeed for opensuse or readhat-software.
now can i just adapt those for systemd-less devuan based on debian?
