Unsupported GPU message and...
tcphillips
Hardware configuration: [img]http://folding.extremeoverclocking.com/sigs/sigimage.php?u=296154[/img]
Post by tcphillips »
...after a restart or restart after an update, won't pick up GPU-based work units where it left off...
18:41:17:I1: Version: 8.4.9
18:41:17:I1: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:41:17:I1: Org: foldingathome.org
18:41:17:I1: Copyright: 2023-2024, foldingathome.org
18:41:17:I1: Homepage: https://foldingathome.org/
18:41:17:I1: License: GPL-3.0-or-later
18:41:17:I1: URL: https://v8-4.foldingathome.org/
18:41:17:I1: Date: Nov 20 2024
18:41:17:I1: Time: 14:47:19
18:41:17:I1: Revision: 360fe71b1bd05bb89814bfb97b73a5bda84802d6
18:41:17:I1: Branch: master
18:41:17:I1: Compiler: GNU 8.3.0
18:41:17:I1: Options: -Wsuggest-override -faligned-new -std=c++17 -fsigned-char
18:41:17:I1: -ffunction-sections -fdata-sections -O3 -funroll-loops -fno-pie
18:41:17:I1: Platform: linux 4.19.0-27-cloud-amd64
18:41:17:I1: Bits: 64
18:41:17:I1: Mode: Release
18:41:17:I1: Args: --config=/etc/fah-client/config.xml
18:41:17:I1: --log=/var/log/fah-client/log.txt
18:41:17:I1: --log-rotate-dir=/var/log/fah-client/
18:41:17:I1: Config: /etc/fah-client/config.xml
18:41:17:I1:****************************** CBang ******************************
18:41:17:I1: Version: 1.7.2
18:41:17:I1: Org: Cauldron Development
18:41:17:I1: Copyright: Cauldron Development, 2003-2024
18:41:17:I1: Homepage: https://cauldrondevelopment.com/
18:41:17:I1: License: LGPL-2.1-or-later
18:41:17:I1: Date: Nov 19 2024
18:41:17:I1: Time: 21:54:38
18:41:17:I1: Revision: 443c54e909eb8d8994405a18fb328b5b05a623a5
18:41:17:I1: -fPIC
18:41:17:I1:***************************** System ******************************
18:41:17:I1: CPU: Intel(R) Xeon(R) CPU E5530 @ 2.40GHz
18:41:17:I1: CPU ID: GenuineIntel Family 6 Model 26 Stepping 5
18:41:17:I1: CPUs: 4
18:41:17:I1: Memory: 5.77GiB
18:41:17:I1:Free Memory: 5.01GiB
18:41:17:I1: OS Version: 6.11
18:41:17:I1:Has Battery: false
18:41:17:I1: On Battery: false
18:41:17:I1: Hostname: Annie
18:41:17:I1: UTC Offset: -5
18:41:17:I1: PID: 1037
18:41:17:I1: CWD: /var/lib/fah-client
18:41:17:I1: Exec: /usr/bin/fah-client
18:41:17:I1:*******************************************************************
18:41:17:I2:<config/>
18:41:17:I1:Opening Database
18:41:17:I1:F@H ID = bCxJneDeyst7fLTB9j1hv9Xd4C8YPtGEyLp_GfncYxk
18:41:17:I3:Loading default resource group
18:41:17:I1:Listening for HTTP on 127.0.0.1:7396
18:41:17:I3:WU1:Loading work unit 1 with ID fT9tUi0QAMMcZBGmCnv8yyqbZp1abxjtszdhRN9aV54
18:41:17:I3:WU2:Loading work unit 2 with ID Bdtto_xhBL9l_cQRzYkLX-bcgA5lxv7ggY7IBiDK1iE
18:41:17:I3:WU3:Loading work unit 3 with ID ygCRghuqi72fuQ8T23d2vaHlgjbfQbHVq8P7qQAR6eY
18:41:17:I3:Loaded 3 wus.
18:41:17:I3:gpus = {
[b]18:41:17:I3: "gpu:15:00:00": {"vendor": 4318, "device": 5122, "type": "nvidia", "supported": false, "description": "GM206 [GeForce GTX 950] 1572"},
18:41:17:I3: "gpu:40:00:00": {"vendor": 4318, "device": 4992, "type": "nvidia", "supported": false, "description": "GM107 [GeForce GTX 750 Ti] 1389"}[/b]
18:41:17:I3:}
18:41:18:I1:Loaded cores/fahcore-a8-lin-64bit-sse2-0.0.12/FahCore_a8
18:41:18:I3:Running FahCore: /var/lib/fah-client/cores/fahcore-a8-lin-64bit-sse2-0.0.12/FahCore_a8 -dir fT9tUi0QAMMcZBGmCnv8yyqbZp1abxjtszdhRN9aV54 -suffix 01 -version 8.4.9 -lifeline 1037 -np 2
18:41:18:I3:WU1:Started FahCore on PID 1436
18:41:18:I1:WU1:*********************** Log Started 2025-03-03T18:41:18Z ***********************
18:41:18:I1:WU1:************************** Gromacs Folding@home Core ***************************
18:41:18:I1:WU1: Core: Gromacs
18:41:18:I1:WU1: Type: 0xa8
18:41:18:I1:WU1: Version: 0.0.12
18:41:18:I1:WU1: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:41:18:I1:WU1: Copyright: 2020 foldingathome.org
18:41:18:I1:WU1: Homepage: https://foldingathome.org/
18:41:18:I1:WU1: Date: Jan 16 2021
18:41:18:I1:WU1: Time: 19:22:05
18:41:18:I1:WU1: Compiler: GNU 8.3.0
18:41:18:I1:WU1: Options: -faligned-new -std=c++14 -fsigned-char -ffunction-sections
18:41:18:I1:WU1: -fdata-sections -O3 -funroll-loops -fno-pie
18:41:18:I1:WU1: Platform: linux2 4.15.0-128-generic
18:41:18:I1:WU1: Bits: 64
18:41:18:I1:WU1: Mode: Release
18:41:18:I1:WU1: SIMD: sse2
18:41:18:I1:WU1: OpenMP: ON
18:41:18:I1:WU1: CUDA: OFF
18:41:18:I1:WU1: Args: -dir fT9tUi0QAMMcZBGmCnv8yyqbZp1abxjtszdhRN9aV54 -suffix 01
18:41:18:I1:WU1: -version 8.4.9 -lifeline 1037 -np 2
18:41:18:I1:WU1:************************************ libFAH ************************************
18:41:18:I1:WU1: Time: 19:21:38
18:41:18:I1:WU1:************************************ CBang *************************************
18:41:18:I1:WU1: Time: 19:21:24
18:41:18:I1:WU1: -fdata-sections -O3 -funroll-loops -fno-pie -fPIC
18:41:18:I1:WU1:************************************ System ************************************
18:41:18:I1:WU1: CPU: Intel(R) Xeon(R) CPU E5530 @ 2.40GHz
18:41:18:I1:WU1: CPU ID: GenuineIntel Family 6 Model 26 Stepping 5
18:41:18:I1:WU1: CPUs: 4
18:41:18:I1:WU1: Memory: 5.77GiB
18:41:18:I1:WU1:Free Memory: 4.68GiB
18:41:18:I1:WU1: Threads: POSIX_THREADS
18:41:18:I1:WU1: OS Version: 6.11
18:41:18:I1:WU1:Has Battery: false
18:41:18:I1:WU1: On Battery: false
18:41:18:I1:WU1: UTC Offset: -5
18:41:18:I1:WU1: PID: 1436
18:41:18:I1:WU1: CWD: /var/lib/fah-client/work
18:41:18:I1:WU1:********************************************************************************
18:41:18:I1:WU1:Project: 12467 (Run 9, Clone 18, Gen 58)
18:41:18:I1:WU1:Unit: 0x00000000000000000000000000000000
18:41:18:I1:WU1:Digital signatures verified
18:41:18:I1:WU1:Calling: mdrun -c frame58.gro -s frame58.tpr -x frame58.xtc -cpi state.cpt -cpt 5 -nt 2 -ntmpi 1
18:41:18:I1:WU1:Steps: first=290000000 total=295000000
18:41:18:W :CON1:DNS lookup failed for api.foldingathome.org
18:41:18:E :OUT1:Failed response: CONNECT
18:41:19:I1:WU1:Completed 22043 out of 5000000 steps (0%)
18:41:33:I1:OUT2:> GET https://api.foldingathome.org/machine/bCxJneDeyst7fLTB9j1hv9Xd4C8YPtGEyLp_GfncYxk HTTP/1.1
18:41:34:I1:OUT2:< HTTP/1.1 200 HTTP_OK
18:41:34:I1:OUT3:> GET wss://node1.foldingathome.org/ws/client HTTP/1.1
18:41:35:I1:OUT3:< HTTP/1.1 101 HTTP_SWITCHING_PROTOCOLS
18:41:35:I1:Logging into node account
...and hangs at this point....
Reason: added Code tags to log
...cogito ergo complicare
Re: Unsupported GPU message and...
Post by muziqaz »
Install nvidia drivers for your GPUs
FAH Omega tester
Kernel updates tend to break nVidia drivers depending on how you installed them. So it usually requires a driver reinstallation.
PaulTV
Post by PaulTV »
toTOW wrote: Thu Mar 06, 2025 11:22 pm Kernel updates tend to break nVidia drivers depending on how you installed them. So it usually requires a driver reinstallation.
To prevent this, first install dkms, then install nvidia drivers and have it register with dkms. Then whenever a kernel update is installed, the nvidia drivers are automatically recompiled. Caveat: if a new kernel is not compatible with the installed driver, recompilation will fail, and new drivers will have to be installed.
