Linux install without NVidia bloatware
Schrödinger's cat
Hardware configuration: NVIDIA RTX 4080 Super
20 x Raspberry Pi 5 Model B 2GB RAM
Post by Schrödinger's cat »
The recommended package(s) of fah-client is
nvidia-opencl-icd
which includes 27 other packages, and is 363.2MB in total.
To install just fah-client, use the following command:
sudo apt install --no-install-recommends /<path>/fah-client_8.4.9_arm64.deb -y
Re: Linux install without NVidia bloatware
Post by muziqaz »
That no recommend command might avoid installing another package which deals with Keep Awake option ;)
FAH Omega tester
Schrödinger's cat
muziqaz wrote: Fri Feb 28, 2025 9:19 pm That no recommend command might avoid installing another package which deals with Keep Awake option ;)
Not for
nvidia-opencl-icd
is the only recommended package
You can check all the package install options (Pre-Depends, Depends, Recommends, Suggests, Conflicts, Replaces & more) using:
apt show /<path>/fah-client_8.4.9_arm64.deb
Post by muziqaz »
Keep awake package is distro dependant :)
FAH Omega tester
