Core 0x22 is unable to detect OpenCL device (bad work unit)
arisu
Post by arisu »
All the 0x26 cores work fine and successfully detect OpenCL. They detect three platforms available (reference, CPU, OpenCL). All the 0x22 cores fail immediately and are unable to detect OpenCL even though it is functional. The system has an AMD Radeon 780M GPU.
01:56:30:I1:WU141:Received WU assignment IN0o-HWTeJTiL68djWmepJV8dDDrtfFFhf6MKHkpf_4
01:56:30:I1:WU141:Downloading WU
01:56:30:I1:OUT4:> CONNECT pllwskifah2.mskcc.org:443 HTTP/1.1
01:56:31:I1:OUT4:> POST https://pllwskifah2.mskcc.org/api/assign HTTP/1.1
01:56:33:I1:WU141:DOWNLOAD 2% 238.59KiB of 9.95MiB
01:56:34:I1:WU141:DOWNLOAD 9% 962.33KiB of 9.95MiB
01:56:35:I1:WU141:DOWNLOAD 18% 1.79MiB of 9.95MiB
01:56:36:I1:WU141:DOWNLOAD 26% 2.55MiB of 9.95MiB
01:56:37:I1:WU141:DOWNLOAD 34% 3.36MiB of 9.95MiB
01:56:38:I1:WU141:DOWNLOAD 46% 4.58MiB of 9.95MiB
01:56:39:I1:WU141:DOWNLOAD 57% 5.66MiB of 9.95MiB
01:56:40:I1:WU141:DOWNLOAD 67% 6.64MiB of 9.95MiB
01:56:41:I1:WU141:DOWNLOAD 79% 7.83MiB of 9.95MiB
01:56:42:I1:WU141:DOWNLOAD 90% 8.91MiB of 9.95MiB
01:56:43:I1:OUT4:< HTTP/1.1 200 HTTP_OK
01:56:43:I1:WU141:Received WU P17636 R7 C29 G324
01:56:43:I1:Loaded cores/openmm-core-22/fahcore-22-linux-64bit-release-0.0.20/FahCore_22
01:56:43:I3:Running FahCore: /var/lib/fah-client/cores/openmm-core-22/fahcore-22-linux-64bit-release-0.0.20/FahCore_22 -dir IN0o-HWTeJTiL68djWmepJV8dDDrtfFFhf6MKHkpf_4 -suffix 01 -version 8.4.9 -lifeline 223819 -gpu-platform cuda -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
01:56:43:I3:WU141:Started FahCore on PID 223837
01:56:44:I1:WU141:*********************** Log Started 2025-02-26T01:56:43Z ***********************
01:56:44:I1:WU141:*************************** Core22 Folding@home Core ***************************
01:56:44:I1:WU141:       Core: Core22
01:56:44:I1:WU141:       Type: 0x22
01:56:44:I1:WU141:    Version: 0.0.20
01:56:44:I1:WU141:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
01:56:44:I1:WU141:  Copyright: 2020 foldingathome.org
01:56:44:I1:WU141:   Homepage: https://foldingathome.org/
01:56:44:I1:WU141:       Date: Jan 20 2022
01:56:44:I1:WU141:       Time: 00:57:52
01:56:44:I1:WU141:   Revision: 3f211b8a4346514edbff34e3cb1c0e0ec951373c
01:56:44:I1:WU141:     Branch: HEAD
01:56:44:I1:WU141:   Compiler: GNU 9.4.0
01:56:44:I1:WU141:    Options: -faligned-new -std=c++11 -fsigned-char -ffunction-sections
01:56:44:I1:WU141:             -fdata-sections -O3 -funroll-loops -fno-pie
01:56:44:I1:WU141:             -DOPENMM_VERSION="\"7.7.0\""
01:56:44:I1:WU141:   Platform: linux 5.11.0-1025-azure
01:56:44:I1:WU141:       Bits: 64
01:56:44:I1:WU141:       Mode: Release
01:56:44:I1:WU141:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
01:56:44:I1:WU141:             <peastman@stanford.edu>
01:56:44:I1:WU141:       Args: -dir IN0o-HWTeJTiL68djWmepJV8dDDrtfFFhf6MKHkpf_4 -suffix 01
01:56:44:I1:WU141:             -version 8.4.9 -lifeline 223819 -gpu-platform cuda -gpu-vendor amd
01:56:44:I1:WU141:             -opencl-platform 0 -opencl-device 0 -gpu 0
01:56:44:I1:WU141:************************************ libFAH ************************************
01:56:44:I1:WU141:       Time: 00:57:22
01:56:44:I1:WU141:   Revision: 9f4ad694e75c2350d4bb6b8b5b769ba27e483a2f
01:56:44:I1:WU141:************************************ CBang *************************************
01:56:44:I1:WU141:       Time: 00:57:00
01:56:44:I1:WU141:   Revision: ab023d155b446906d55b0f6c9a1eedeea04f7a1a
01:56:44:I1:WU141:             -fdata-sections -O3 -funroll-loops -fno-pie -fPIC
01:56:44:I1:WU141:************************************ System ************************************
01:56:44:I1:WU141:        CPU: AMD Ryzen 7 7840U w/ Radeon 780M Graphics
01:56:44:I1:WU141:     CPU ID: AuthenticAMD Family 25 Model 116 Stepping 1
01:56:44:I1:WU141:       CPUs: 8
01:56:44:I1:WU141:     Memory: 30.58GiB
01:56:44:I1:WU141:Free Memory: 22.37GiB
01:56:44:I1:WU141:    Threads: POSIX_THREADS
01:56:44:I1:WU141: OS Version: 6.1
01:56:44:I1:WU141:Has Battery: true
01:56:44:I1:WU141: On Battery: false
01:56:44:I1:WU141: UTC Offset: 0
01:56:44:I1:WU141:        PID: 223837
01:56:44:I1:WU141:        CWD: /var/lib/fah-client/work
01:56:44:I1:WU141:************************************ OpenMM ************************************
01:56:44:I1:WU141:    Version: 7.7.0
01:56:44:I1:WU141:********************************************************************************
01:56:44:I1:WU141:Project: 17636 (Run 7, Clone 29, Gen 324)
01:56:44:I1:WU141:Reading tar file core.xml
01:56:44:I1:WU141:Reading tar file integrator.xml.bz2
01:56:44:I1:WU141:Reading tar file state.xml.bz2
01:56:44:I1:WU141:Reading tar file system.xml.bz2
01:56:44:I1:WU141:Digital signatures verified
01:56:44:I1:WU141:Folding@home GPU Core22 Folding@home Core
01:56:44:I1:WU141:Version 0.0.20
01:56:44:I1:WU141:  Checkpoint write interval: 125000 steps (5%) [20 total]
01:56:44:I1:WU141:  JSON viewer frame write interval: 25000 steps (1%) [100 total]
01:56:44:I1:WU141:  XTC frame write interval: 250000 steps (10%) [10 total]
01:56:44:I1:WU141:  Global context and integrator variables write interval: disabled
01:56:44:I1:WU141:There are 2 platforms available.
01:56:44:I1:WU141:Platform 0: Reference
01:56:44:I1:WU141:Platform 1: CPU
01:56:44:I1:WU141:opencl-device was set but OpenCL platform could not be found.
01:56:44:I1:WU141:ERROR:126: Neither CUDA nor OpenCL is available.
01:56:44:I1:WU141:Saving result file ../logfile_01.txt
01:56:44:I1:WU141:Saving result file science.log
01:56:44:I1:WU141:Folding@home Core Shutdown: BAD_WORK_UNIT
01:56:45:E :WU141:Core returned BAD_WORK_UNIT (114)
Core 0x22 uses OpenMM 7.7.0 and core 0x26 uses 8.2.0 which might be relevant? See the relevant parts of the log from above:
Compare it with the same part of the log from a 0x26 core:
02:50:30:I1:WU150:There are 3 platforms available.
02:50:30:I1:WU150:Platform 0: Reference
02:50:30:I1:WU150:Platform 1: CPU
02:50:30:I1:WU150:Platform 2: OpenCL
02:50:30:I1:WU150:  opencl-device 0 specified
arisu
Re: Core 0x22 is unable to detect OpenCL device (bad work unit)
Post by arisu »
It looks like this might be related to https://github.com/FoldingAtHome/fah-cl ... issues/245 which concludes that it is not a v8 issue but a core 0x22 issue. The last followup on that issue says:
Just the follow up. core22 is folding on v7 and v8 on kubuntu. So it is safe to say Mint Linux might be the culprit
However I am not using Mint. I am using Debian.
Post by muziqaz »
Core22 will fail on latest diatro versions with newer kernels and newer GLIBC
FAH Omega tester
arisu
Post by arisu »
This is Debian stable (bookworm) with glibc 2.36 (2.36-9+deb12u9) and kernel linux-image-6.1.0-29-amd64 (6.1.123-1). Far from the latest.
What versions are incompatible? If Debian stable is too recent, that would make most Linux distros too recent as well.
Post by muziqaz »
Ubuntu 24.04 and 22.04 equivalents.
And yes we are aware that core22 is old
FAH Omega tester
arisu
Post by arisu »
I would like to test this to find some workarounds (maybe it's as simple as putting glibc version 2.17 as libc.so.6 in the core directory so LD_LIBRARY_PATH picks it up). Then I don't have to keep failing WUs unnecessarily.
Where can I get an expired core22 WU to play with? I'll run the core manually so that fah-client does not try to talk to the servers pointlessly.
Post by muziqaz »
Let me get back home this evening from work in about 15 hours. I'll try to get you wudata_01.dat, and a little guide on how to run the core from command line.
Though nothing is that easy, I'm afraid 😟
Ping me in 15 hours, if you can, I'm known to have memory like a fish 🐟😂
FAH Omega tester
arisu
Post by arisu »
Ok! Running the core from command line is as simple as having the right current working directory with the right permissions and flags, with LD_LIBRARY_PATH set appropriately, and with a dummy process for its lifeline PID right? I know how to extract the wudata_01.dat if the core doesn't extract it on its own.
Just make sure the WU is something that can run (at least for a few seconds) on an AMD 780M iGPU. It's not the fastest thing but it gives more than 200k PPD so it's not incapable either.
If it is purely a userspace issue then I can probably fix it but if it's a driver issue then I'm SOL.
Post by muziqaz »
When run from command line any GPU runs any WU, since you are not tied to fahclient and the server constraints.
I really don't think it is a driver issue ;)
FAH Omega tester
arisu
Post by arisu »
Any WU, even CPU WUs?
I just assumed that a WU typically run on a 4090 might require more VRAM than the 480M has available to it (though I hear FAH uses very little VRAM).
Post by muziqaz »
Not CPU WU
Any GPU project will run on any supported GPU, don't worry ;)
FAH Omega tester
Post by muziqaz »
Home now.
https://send.vis.ee/download/22c5a0d4cc ... 9hR-tE1E3w
Download this zip (run it through antivirus things or totalvirus website, if you want).
Extract that zip into your core22 directory so that among all the .so libraries you have directory called 00, which contains wudata_01.dat. This is a work unit itself. You might need to change permission for that directory for your linux user to be able to write into it.
So in console cd to core22 directory and run following:
export LD_LIBRARY_PATH="$PWD"
and
./FahCore_22 -dir 00 -suffix 01 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0 --log-time=true
You should see something like this:
20:54:12:Free Memory: 22.48GiB
20:54:12: Threads: WINDOWS_THREADS
20:54:12: OS Version: 6.2
20:54:12:Has Battery: false
20:54:12: On Battery: false
20:54:12: UTC Offset: 0
20:54:12: PID: 14936
20:54:12: CWD: C:\ProgramData\FAHClient\cores\openmm-core-22\fahcore-22-windows-64bit-release-0.0.20
20:54:12:******************************* OpenMM ********************************
20:54:12: Version: 7.7.0
20:54:12:***********************************************************************
20:54:12:Project: 14951 (Run 1, Clone 3, Gen 11)
20:54:12:Reading tar file core.xml
20:54:12:Reading tar file integrator.xml
20:54:12:Reading tar file state.xml
20:54:12:Reading tar file system.xml
20:54:12:Digital signatures verified
Except where mine says Windows, your will say Linux, obviously.
So once you launch the WU with above command it either gonna stay at the state I pasted above, which means it is probably running, or it will drop out of it, which means it crashed.
To observe your progress or what happened (error message), you can open the log file which will be generated in 00 directory. Remember, that to see progress you would need to close and open log file again, but if you know linux, you probably can figure out the way for fah to print out progress in console live.
To stop folding, CTRL-C. To start over from scratch, delete everything in 00 directory except wudata_01.dat and run the command again.
Once you finish the experiments, delete 00 directory completely.
If you have any questions let me know. I am sure I forgot something :D
Note: export command is per console window. If you close console window export effect goes away and you have to run that PATH command again.
Note2: WU download link is valid for 10 downloads and 3 days. After that it will delete itself
FAH Omega tester
arisu
Post by arisu »
Thank you for the WU!
I can reproduce the issue with a chroot into a Centos 7.9 image (CentOS-7-x86_64-Minimal-2009.iso which uses glibc 2.17). I copied the files to the chroot as well as the needed libraries (like ROCm libraries) and regenerated the ld.so.cache. I ran core22 under strace and checked every single filesystem call and there were no unexplained errors. It doesn't even try to access the /dev/dri/render or /dev/kfd devices so I think the kernel is not the problem.
Unfortunately I can't find the code that checks for platforms in any of the open source components of the core, so it must be in the closed source portion of the core. I'm not sure how deep I can dig before I violate the EULA prohibitions against reverse engineering.
Post by calxalot »
I believe the core wrapper uses the open source cbang, same as client.
OpenMM probably does a few things more.
arisu
Post by arisu »
Oops, I didn't check out cbang, just OpenMM (and only briefly). I assumed it might have been in libFAH, whatever that is.
