Search returns only 15 results
Frogging101
If you search for any term on the board, e.g. search.php?keywords=testing, it will return only one page of results. At the top right, it says "Search found 1 match", but it returns 15 results. There are no more pages, even though there should be.
Re: Search returns only 15 results
I noticed this too. And sometimes if you search the same keywords again, it returns one result or even none. I suspect the forum admin will need to rebuild the phpBB search index. There should be an option to do that in the administration panel.
