Pause on start
JVallois
Pause on start
Post by JVallois »
Hello there!
Does someone know if it is possible to use “pause-on-start” with the V8 client?
Thanks a lot.
Image Image
Re: Pause on start
Post by calxalot »
Not supported on v8.
If you really want it, you might create a github issue.
https://github.com/FoldingAtHome/fah-cl ... tet/issues
define
Re: Pause on start
Post by define »
If you use "finish" and than poweroff your pc, fah-client starts on pause.
I have to start folding manually.
Re: Pause on start
Post by calxalot »
If it doesn’t finish, it should still be finish when relaunched.
On Windows, client currently may dump or abandon work if you don’t pause before logout/restart.
JVallois
Re: Pause on start
Post by JVallois »
Thanks for yours answers.
Finally, as the V8 clients don't start automatically on startup, we can say that the pause-on-start option is included.
I run it with Linux, and it seems it needn't be paused before logout/restart.
Image Image
