Losing WUs on restart?
Breach
Post by Breach »
Hey there, using the latest client, Windows 11 and noticed the following:
a) If I restart system while folding, when the PC starts again the old WU is dumped and a new one is picked up (expected: pause and resume).
b) If I pause folding and restart immediately, the WU remains 'paused' but then FAH picks up a new WU (expected: resume the previous WU).
Am I missing something here...?
Re: Losing WUs on restart?
Post by muziqaz »
Make sure you are on the latest Fahclient version, which is 8.4.9.
And then before rebooting pause all the work, and don't rush rebooting immediately, do it in normal speed. Windows reboot kills fahclient too quickly for it to save current state
FAH Omega tester
Breach
Post by Breach »
Yes, I'm using 8.4.9. Thanks for confirming current behavior, but then it seems the new client didn't implement something important, which the old, desktop one was handling fine.
And it's really a couple of lines of code to block a restart in Win32 through the API (ShutdownBlockReasonCreate) until the state is saved.
Hope it will be added.
Post by muziqaz »
The issue is not by choice, and we have been trying to fix it, and it is not that simple ;)
FAH Omega tester
Breach
Post by Breach »
OK, I understand it is a known issue on the radar and that apparently it may not be straightforward to address (and indeed, I haven't obviously seen your codebase). Hope you find a solution - it would avoid wasting valuable compute time in such situations.
Cheers
Post by muziqaz »
Code is open source at github :)
FAH Omega tester
Breach wrote: Sun Feb 16, 2025 3:55 pm Yes, I'm using 8.4.9. Thanks for confirming current behavior, but then it seems the new client didn't implement something important, which the old, desktop one was handling fine.
Actually there were complaints with the prior v7 client under Windows doing the same thing, not exiting fully before the Windows reboot killed the process before the code had exited. So you may not have run into the issue on your Windows systems, but others did.
Post by calxalot »
EdgeArcher
Post by EdgeArcher »
If the problem cannot be solved, It may also good to add a function for WUs of upload all the frames finished already. This might also reduce the waste of computation time and resource
Breach
Post by Breach »
Post by muziqaz »
Breach wrote: Sun Oct 12, 2025 8:44 am I filed https://github.com/FoldingAtHome/fah-cl ... issues/391 for the maintainers.
v8.5.2 alpha (can be downloaded from foldingathome.org/alpha) seem to have fixed the issue. People are welcome to test it on their own windows machines, with GPU units as well. Findings can be reported either on #290 or #391
FAH Omega tester
Breach
Post by Breach »
Yes, issue should be now fixed in 8.5.2. Plus, with the latest commit of jcoffland in 8.5.3, return codes from OS interrupted cores are now ignored when quitting. I guess the only remaining risk is for a restart somehow coinciding with the core writing the checkpoint, which will likely corrupt the WU, but for most cases it should not dump WUs as before. I built from source and all seems fine now.
Kudos.
