[tuto]8.4.x beta,Tumbleweed,installation
promeneur
Hardware configuration: openSUSE Tumbleweed, x86_64,Asrock B760M-HDV/M.2 D4, Intel Core i3-12100, 16 GB, Intel UHD Graphics 730, NVIDIA GeForce GT 1030, Edup-Love EP-9651GS Wi-Fi Bluetooth, multicard reader USB 3.0 startech.com 35fcreadbu3, Epson XP 7100, Headset Bluetooth 3.0 Philips SHQ7300
Post by promeneur »
Thanks to @Marco FRM
I assume this works for openSUSE Leap.
If someone knows how to select in github the version 8.4.9 according to install the stable 8.4.9, thanks to him
1. Tools installation
sudo zypper -n in git scons gcc-c++ libopenssl-devel zlib-devel libbz2-devel systemd-devel rpm-build systemd-rpm-macros
Maybe you need to choose to remove busybox-patch to install rpm-build. I choose to remove it.
It's not a problem if some packages are already installed for zypper command.
2. Building
create a folder for your building for storing your work.
go to this folder and execute
git clone https://github.com/cauldrondevelopmentllc/cbang
git clone https://github.com/foldingathome/fah-client-bastet
export CBANG_HOME=$PWD/cbang
scons -C cbang
scons -C fah-client-bastet
scons -C fah-client-bastet package
Do not take care of the warnings, only the errors. I did not receive any error.
3. Installing
Pause the folding run by 8.3.17.
Uninstall the previous version 8.3.17.
sudo zypper in ./fah-client-bastet/fah_client-<version>.x86_64.rpm
for example in my case
sudo zypper in ./fah-client-bastet/fah_client-8.4.10-1.x86_64.rpm
If the installer ask for you if you want to install a non-signed package answer "ignore".
fah-client is launched by installing the package fah_client-<version>.x86_64.rpm by a post script.
In the kde menu "sciences and mathematics" search "folding@home client" and click.
In the web page https://v8-4.foldingathome.org/machines
click on "fold all"
that's all
enjoy :)
