AMD RX 580
tvdsluis
AMD RX 580
Post by tvdsluis »
I have an old AMD RX 580 8 gb.
It always got enough work, and did this work quickly enough.
The last weeks, work for this card is very sparse maybe 1 or 2 WU's per day.
Would a newer card like a 6600 or 7600 get any work at all, or are all WU's converting to CUDA and thus Nvidia exclusive?
Just as all AI work runs on Nvidia?
Re: AMD RX 580
Post by muziqaz »
I'm in a limbo at the moment with AMD because of all the fahcore issues we are having. There hasn't been many new projects which would fit the performance tier of 580. So just hang on with this. Once HIP FAHCore hits the streets if your GPU is supported by it, you might get more out of this GPU, if not, 6600 or 7600 would technically get much more work.
FAH Omega tester
ViTe
Re: AMD RX 580
Post by ViTe »
For sure we need more work units for RX 570/580/590. The only server that provides units for this cars is 140.163.4.210. Thats it!
It generates 1-2 units per minute, mostly core26. We need more! Better core 22 (no problems with this core)
