Core 23 doesn't detect a valid OpenCL while Core 24 works fine.
borketh
Hardware configuration: 9800X3D + 7800XT
Post by borketh »
Projects 12294 and 16525 both failed before starting with "BAD_WORK_UNIT" and got passed on to someone else. This has happened before and I thought it was due to instability but it doesn't seem like that anymore. I've ran quite a few Core 24 jobs where the OpenCL platform detects just fine. It doesn't seem to matter what I use. The rocm driver on its own works, running it through rusticl works, and even running it through clover works, although the compute level goes to 1.2 instead of 2.0.
I have a 7800XT (gfx1101) and I'm using the `rocm-opencl-sdk` package from the "extra" repo in CachyOS (Arch Linux). I also have ocl-icd, and clinfo gives me the information I expect
borketh
Re: Core 23 doesn't detect a valid OpenCL while Core 24 works fine.
Post by borketh »
*********************** Log Started 2025-02-12T06:03:08Z ***********************
06:03:08:I1:*********************** Folding@home Client ***********************
06:03:08:I1:    Version: 8.4.9
06:03:08:I1:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
06:03:08:I1:        Org: foldingathome.org
06:03:08:I1:  Copyright: 2023-2024, foldingathome.org
06:03:08:I1:   Homepage: https://foldingathome.org/
06:03:08:I1:    License: GPL-3.0-or-later
06:03:08:I1:        URL: https://v8-4.foldingathome.org/
06:03:08:I1:       Date: Feb 2 2025
06:03:08:I1:       Time: 19:33:10
06:03:08:I1:   Revision: 360fe71b1bd05bb89814bfb97b73a5bda84802d6
06:03:08:I1:     Branch: makepkg
06:03:08:I1:   Compiler: GNU 14.2.1 20240910
06:03:08:I1:    Options: -Wsuggest-override -faligned-new -std=c++14 -fsigned-char
06:03:08:I1:             -ffunction-sections -fdata-sections -O3 -funroll-loops -fno-pie
06:03:08:I1:   Platform: linux 6.13.0-3-cachyos
06:03:08:I1:       Bits: 64
06:03:08:I1:       Mode: Release
06:03:08:I1:****************************** CBang ******************************
06:03:08:I1:    Version: 1.7.2
06:03:08:I1:        Org: Cauldron Development
06:03:08:I1:  Copyright: Cauldron Development, 2003-2024
06:03:08:I1:   Homepage: https://cauldrondevelopment.com/
06:03:08:I1:    License: LGPL-2.1-or-later
06:03:08:I1:   Revision: 443c54e909eb8d8994405a18fb328b5b05a623a5
06:03:08:I1:             -fPIC
06:03:08:I1:***************************** System ******************************
06:03:08:I1:        CPU: AMD Ryzen 7 9800X3D 8-Core Processor
06:03:08:I1:     CPU ID: AuthenticAMD Family 26 Model 68 Stepping 0
06:03:08:I1:       CPUs: 16
06:03:08:I1:     Memory: 30.43GiB
06:03:08:I1:Free Memory: 13.27GiB
06:03:08:I1: OS Version: 6.13
06:03:08:I1:Has Battery: false
06:03:08:I1: On Battery: false
06:03:08:I1:   Hostname: vitesse
06:03:08:I1: UTC Offset: -5
06:03:08:I1:        PID: 143938
06:03:08:I1:        CWD: /home/two/fah
06:03:08:I1:       Exec: /usr/bin/fah-client
06:03:08:I1:*******************************************************************
06:03:08:I2:<config/>
06:03:08:I1:Opening Database
06:03:08:I1:F@H ID = YpIduVytGgoudKomNPNt578GNHCT0PIKE1osD2MoT2c
06:03:08:I3:Loading default resource group
06:03:08:I1:Listening for HTTP on 127.0.0.1:7396
06:03:08:I3:Loaded 0 wus.
06:03:08:I3:gpus = {
06:03:08:I3:  "gpu:03:00:00": {
06:03:08:I3:    "vendor": 4098,
06:03:08:I3:    "type": "amd",
06:03:08:I3:    "description": "gfx1101",
06:03:08:I3:    "opencl": {"platform": 1, "device": 0, "compute": "2.0", "driver": "3625.0"},
06:03:08:I3:    "device": 29822,
06:03:08:I3:    "supported": true
06:03:08:I3:  },
06:03:08:I3:  "gpu:14:00:00": {
06:03:08:I3:    "description": "gfx1036",
06:03:08:I3:    "opencl": {"platform": 1, "device": 1, "compute": "2.0", "driver": "3625.0"},
06:03:08:I3:    "device": 5056,
06:03:08:I3:    "supported": false
06:03:08:I3:  }
06:03:08:I3:}
06:03:08:I1:OUT1:> GET https://api.foldingathome.org/machine/YpIduVytGgoudKomNPNt578GNHCT0PIKE1osD2MoT2c HTTP/1.1
06:03:09:I1:OUT1:< HTTP/1.1 200 HTTP_OK
06:03:09:I1:OUT2:> GET wss://node1.foldingathome.org/ws/client HTTP/1.1
06:03:10:I1:OUT2:< HTTP/1.1 101 HTTP_SWITCHING_PROTOCOLS
06:03:10:I1:Logging into node account
06:03:12:I1:Machine state fold
06:03:12:I1:Default:Added new work unit: cpus:13 gpus:gpu:03:00:00
06:03:12:I1:WU3:Requesting WU assignment for user borketh team 60
06:03:13:I1:OUT4:> POST https://assign1.foldingathome.org/api/assign HTTP/1.1
06:03:13:I1:OUT4:< HTTP/1.1 200 HTTP_OK
06:03:13:I1:WU3:Received WU assignment AmOCDAwWEcZRn3BfILcHWaFSzOmdkUa1uoDD3ViT6Eg
06:03:13:I1:WU3:Downloading WU
06:03:13:I1:OUT5:> POST https://huangfolding1.chem.wisc.edu/api/assign HTTP/1.1
06:03:31:I1:WU3:DOWNLOAD 9% 8.56MiB of 95.67MiB
06:03:32:I1:WU3:DOWNLOAD 21% 20.31MiB of 95.67MiB
06:03:33:I1:WU3:DOWNLOAD 33% 31.66MiB of 95.67MiB
06:03:34:I1:WU3:DOWNLOAD 45% 43.44MiB of 95.67MiB
06:03:35:I1:WU3:DOWNLOAD 58% 55.24MiB of 95.67MiB
06:03:36:I1:WU3:DOWNLOAD 70% 67.03MiB of 95.67MiB
06:03:37:I1:WU3:DOWNLOAD 82% 78.84MiB of 95.67MiB
06:03:38:I1:WU3:DOWNLOAD 95% 90.63MiB of 95.67MiB
06:03:38:I1:WU3:DOWNLOAD 100% 95.67MiB of 95.67MiB
06:03:38:I1:OUT5:< HTTP/1.1 200 HTTP_OK
06:03:39:I1:WU3:Received WU P16525 R111 C2 G216
06:03:39:I1:Downloading https://cores2.foldingathome.org/openmm-core-23/centos-7.9.2009-64bit/release/fahcore-23-centos-7.9.2009-64bit-release-8.0.3.tar.bz2.crt
06:03:39:I1:OUT6:> GET https://cores2.foldingathome.org/openmm-core-23/centos-7.9.2009-64bit/release/fahcore-23-centos-7.9.2009-64bit-release-8.0.3.tar.bz2.crt HTTP/1.1
06:03:40:I1:OUT6:< HTTP/1.1 200 OK
06:03:40:I1:Downloading https://cores2.foldingathome.org/openmm-core-23/centos-7.9.2009-64bit/release/fahcore-23-centos-7.9.2009-64bit-release-8.0.3.tar.bz2.sig
06:03:40:I1:OUT7:> GET https://cores2.foldingathome.org/openmm-core-23/centos-7.9.2009-64bit/release/fahcore-23-centos-7.9.2009-64bit-release-8.0.3.tar.bz2.sig HTTP/1.1
06:03:41:I1:OUT7:< HTTP/1.1 200 OK
06:03:41:I1:Downloading https://cores2.foldingathome.org/openmm-core-23/centos-7.9.2009-64bit/release/fahcore-23-centos-7.9.2009-64bit-release-8.0.3.tar.bz2
06:03:41:I1:OUT8:> GET https://cores2.foldingathome.org/openmm-core-23/centos-7.9.2009-64bit/release/fahcore-23-centos-7.9.2009-64bit-release-8.0.3.tar.bz2 HTTP/1.1
06:03:44:I1:WU3:CORE 2% 3.86MiB of 159.89MiB
06:03:45:I1:WU3:CORE 5% 7.50MiB of 159.89MiB
06:03:46:I1:WU3:CORE 7% 10.81MiB of 159.89MiB
06:03:47:I1:WU3:CORE 9% 14.26MiB of 159.89MiB
06:03:48:I1:WU3:CORE 11% 17.87MiB of 159.89MiB
06:03:49:I1:WU3:CORE 13% 21.42MiB of 159.89MiB
06:03:50:I1:WU3:CORE 16% 24.98MiB of 159.89MiB
06:03:51:I1:WU3:CORE 18% 28.28MiB of 159.89MiB
06:03:52:I1:WU3:CORE 20% 31.51MiB of 159.89MiB
06:03:53:I1:WU3:CORE 21% 34.01MiB of 159.89MiB
06:03:54:I1:WU3:CORE 24% 37.59MiB of 159.89MiB
06:03:55:I1:WU3:CORE 26% 41.61MiB of 159.89MiB
06:03:56:I1:WU3:CORE 29% 46.04MiB of 159.89MiB
06:03:57:I1:WU3:CORE 33% 52.57MiB of 159.89MiB
06:03:58:I1:WU3:CORE 39% 62.29MiB of 159.89MiB
06:03:59:I1:WU3:CORE 46% 74.11MiB of 159.89MiB
06:04:00:I1:WU3:CORE 54% 85.92MiB of 159.89MiB
06:04:01:I1:WU3:CORE 61% 96.96MiB of 159.89MiB
06:04:02:I1:WU3:CORE 68% 108.70MiB of 159.89MiB
06:04:03:I1:WU3:CORE 75% 120.53MiB of 159.89MiB
06:04:04:I1:WU3:CORE 83% 132.32MiB of 159.89MiB
06:04:05:I1:WU3:CORE 90% 144.14MiB of 159.89MiB
06:04:06:I1:WU3:CORE 97% 154.93MiB of 159.89MiB
06:04:06:I1:OUT8:< HTTP/1.1 200 OK
06:04:06:I1:Core signature valid
06:04:06:I1:Extracting cores/openmm-core-23/centos-7.9.2009-64bit/release/fahcore-23-centos-7.9.2009-64bit-release-8.0.3/FahCore_23
06:04:06:I1:Extracting cores/openmm-core-23/centos-7.9.2009-64bit/release/fahcore-23-centos-7.9.2009-64bit-release-8.0.3/core-meta.json
06:04:06:I1:Extracting cores/openmm-core-23/centos-7.9.2009-64bit/release/fahcore-23-centos-7.9.2009-64bit-release-8.0.3/libOpenCL.so.1
06:04:06:I1:Extracting cores/openmm-core-23/centos-7.9.2009-64bit/release/fahcore-23-centos-7.9.2009-64bit-release-8.0.3/libOpenMM.so.8.0
06:04:07:I1:Extracting cores/openmm-core-23/centos-7.9.2009-64bit/release/fahcore-23-centos-7.9.2009-64bit-release-8.0.3/libOpenMMAmoeba.so
06:04:07:I1:Extracting cores/openmm-core-23/centos-7.9.2009-64bit/release/fahcore-23-centos-7.9.2009-64bit-release-8.0.3/libOpenMMAmoebaCUDA.so
06:04:07:I1:Extracting cores/openmm-core-23/centos-7.9.2009-64bit/release/fahcore-23-centos-7.9.2009-64bit-release-8.0.3/libOpenMMAmoebaOpenCL.so
06:04:07:I1:Extracting cores/openmm-core-23/centos-7.9.2009-64bit/release/fahcore-23-centos-7.9.2009-64bit-release-8.0.3/libOpenMMAmoebaReference.so
06:04:07:I1:Extracting cores/openmm-core-23/centos-7.9.2009-64bit/release/fahcore-23-centos-7.9.2009-64bit-release-8.0.3/libOpenMMCPU.so
06:04:07:I1:Extracting cores/openmm-core-23/centos-7.9.2009-64bit/release/fahcore-23-centos-7.9.2009-64bit-release-8.0.3/libOpenMMCUDA.so
06:04:07:I1:Extracting cores/openmm-core-23/centos-7.9.2009-64bit/release/fahcore-23-centos-7.9.2009-64bit-release-8.0.3/libOpenMMCudaCompiler.so
06:04:07:I1:Extracting cores/openmm-core-23/centos-7.9.2009-64bit/release/fahcore-23-centos-7.9.2009-64bit-release-8.0.3/libOpenMMDrude.so
06:04:07:I1:Extracting cores/openmm-core-23/centos-7.9.2009-64bit/release/fahcore-23-centos-7.9.2009-64bit-release-8.0.3/libOpenMMDrudeCUDA.so
06:04:07:I1:Extracting cores/openmm-core-23/centos-7.9.2009-64bit/release/fahcore-23-centos-7.9.2009-64bit-release-8.0.3/libOpenMMDrudeOpenCL.so
06:04:07:I1:Extracting cores/openmm-core-23/centos-7.9.2009-64bit/release/fahcore-23-centos-7.9.2009-64bit-release-8.0.3/libOpenMMDrudeReference.so
06:04:07:I1:Extracting cores/openmm-core-23/centos-7.9.2009-64bit/release/fahcore-23-centos-7.9.2009-64bit-release-8.0.3/libOpenMMOpenCL.so
06:04:07:I1:Extracting cores/openmm-core-23/centos-7.9.2009-64bit/release/fahcore-23-centos-7.9.2009-64bit-release-8.0.3/libOpenMMPME.so
06:04:07:I1:Extracting cores/openmm-core-23/centos-7.9.2009-64bit/release/fahcore-23-centos-7.9.2009-64bit-release-8.0.3/libOpenMMRPMD.so
06:04:07:I1:Extracting cores/openmm-core-23/centos-7.9.2009-64bit/release/fahcore-23-centos-7.9.2009-64bit-release-8.0.3/libOpenMMRPMDCUDA.so
06:04:07:I1:Extracting cores/openmm-core-23/centos-7.9.2009-64bit/release/fahcore-23-centos-7.9.2009-64bit-release-8.0.3/libOpenMMRPMDOpenCL.so
06:04:07:I1:Extracting cores/openmm-core-23/centos-7.9.2009-64bit/release/fahcore-23-centos-7.9.2009-64bit-release-8.0.3/libOpenMMRPMDReference.so
06:04:07:I1:Extracting cores/openmm-core-23/centos-7.9.2009-64bit/release/fahcore-23-centos-7.9.2009-64bit-release-8.0.3/libbz2.so.1.0
06:04:07:I1:Extracting cores/openmm-core-23/centos-7.9.2009-64bit/release/fahcore-23-centos-7.9.2009-64bit-release-8.0.3/libcrypto.so.1.1
06:04:07:I1:Extracting cores/openmm-core-23/centos-7.9.2009-64bit/release/fahcore-23-centos-7.9.2009-64bit-release-8.0.3/libcufft.so.10
06:04:13:I1:Extracting cores/openmm-core-23/centos-7.9.2009-64bit/release/fahcore-23-centos-7.9.2009-64bit-release-8.0.3/libfftw3f.so.3
06:04:13:I1:Extracting cores/openmm-core-23/centos-7.9.2009-64bit/release/fahcore-23-centos-7.9.2009-64bit-release-8.0.3/libfftw3f_threads.so.3
06:04:13:I1:Extracting cores/openmm-core-23/centos-7.9.2009-64bit/release/fahcore-23-centos-7.9.2009-64bit-release-8.0.3/libnvrtc-builtins.so.11.2
06:04:13:I1:Extracting cores/openmm-core-23/centos-7.9.2009-64bit/release/fahcore-23-centos-7.9.2009-64bit-release-8.0.3/libnvrtc.so.11.2
06:04:14:I1:Extracting cores/openmm-core-23/centos-7.9.2009-64bit/release/fahcore-23-centos-7.9.2009-64bit-release-8.0.3/libssl.so.1.1
06:04:14:I1:Extracting cores/openmm-core-23/centos-7.9.2009-64bit/release/fahcore-23-centos-7.9.2009-64bit-release-8.0.3/libstdc++.so.6
06:04:14:I1:Default:Added new work unit: cpus:12 gpus:
06:04:14:I3:Running FahCore: /home/two/fah/cores/openmm-core-23/centos-7.9.2009-64bit/release/fahcore-23-centos-7.9.2009-64bit-release-8.0.3/FahCore_23 -dir AmOCDAwWEcZRn3BfILcHWaFSzOmdkUa1uoDD3ViT6Eg -suffix 01 -version 8.4.9 -lifeline 143938 -gpu-platform cuda -gpu-vendor amd -opencl-platform 1 -opencl-device 0 -gpu 0
06:04:14:I3:WU3:Started FahCore on PID 144220
06:04:14:I1:WU4:Requesting WU assignment for user borketh team 60
06:04:14:I1:OUT9:> POST https://assign2.foldingathome.org/api/assign HTTP/1.1
06:04:15:I1:WU3:*********************** Log Started 2025-02-12T06:04:14Z ***********************
06:04:15:I1:WU3:*************************** Core23 Folding@home Core ***************************
06:04:15:I1:WU3:       Core: Core23
06:04:15:I1:WU3:       Type: 0x23
06:04:15:I1:WU3:    Version: 8.0.3
06:04:15:I1:WU3:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
06:04:15:I1:WU3:  Copyright: 2022 foldingathome.org
06:04:15:I1:WU3:   Homepage: https://foldingathome.org/
06:04:15:I1:WU3:       Date: Aug 3 2023
06:04:15:I1:WU3:       Time: 08:28:22
06:04:15:I1:WU3:   Revision: 199cb870317d05441d0a301287d9ef61254fa32b
06:04:15:I1:WU3:     Branch: HEAD
06:04:15:I1:WU3:   Compiler: GNU 7.5.0
06:04:15:I1:WU3:    Options: -faligned-new -std=c++11 -fsigned-char -ffunction-sections
06:04:15:I1:WU3:             -fdata-sections -O3 -funroll-loops -fno-pie
06:04:15:I1:WU3:             -DOPENMM_VERSION="\"8.0.0\""
06:04:15:I1:WU3:   Platform: linux 5.15.0-1041-azure
06:04:15:I1:WU3:       Bits: 64
06:04:15:I1:WU3:       Mode: Release
06:04:15:I1:WU3:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
06:04:15:I1:WU3:             <peastman@stanford.edu>
06:04:15:I1:WU3:       Args: -dir AmOCDAwWEcZRn3BfILcHWaFSzOmdkUa1uoDD3ViT6Eg -suffix 01
06:04:15:I1:WU3:             -version 8.4.9 -lifeline 143938 -gpu-platform cuda -gpu-vendor amd
06:04:15:I1:WU3:             -opencl-platform 1 -opencl-device 0 -gpu 0
06:04:15:I1:WU3:************************************ libFAH ************************************
06:04:15:I1:WU3:       Time: 08:27:48
06:04:15:I1:WU3:   Revision: 112c2234abe20611a05652defc3c7f854cbf927f
06:04:15:I1:WU3:************************************ CBang *************************************
06:04:15:I1:WU3:    Version: 1.7.2
06:04:15:I1:WU3:        Org: Cauldron Development LLC
06:04:15:I1:WU3:  Copyright: Cauldron Development LLC, 2003-2023
06:04:15:I1:WU3:   Homepage: https://cauldrondevelopment.com/
06:04:15:I1:WU3:    License: GPL 2+
06:04:15:I1:WU3:       Time: 08:27:30
06:04:15:I1:WU3:   Revision: eae4b58965bdd4d54ea9eb77972674352b37a547
06:04:15:I1:WU3:             -fdata-sections -O3 -funroll-loops -fno-pie -fPIC
06:04:15:I1:WU3:************************************ System ************************************
06:04:15:I1:WU3:        CPU: AMD Ryzen 7 9800X3D 8-Core Processor
06:04:15:I1:WU3:     CPU ID: AuthenticAMD Family 26 Model 68 Stepping 0
06:04:15:I1:WU3:       CPUs: 16
06:04:15:I1:WU3:     Memory: 30.43GiB
06:04:15:I1:WU3:Free Memory: 16.15GiB
06:04:15:I1:WU3:    Threads: POSIX_THREADS
06:04:15:I1:WU3: OS Version: 6.13
06:04:15:I1:WU3:Has Battery: false
06:04:15:I1:WU3: On Battery: false
06:04:15:I1:WU3: UTC Offset: -5
06:04:15:I1:WU3:        PID: 144220
06:04:15:I1:WU3:        CWD: /home/two/fah/work
06:04:15:I1:WU3:       Exec: /home/two/fah/cores/openmm-core-23/centos-7.9.2009-64bit/release/fahcore-23-centos-7.9.2009-64bit-release-8.0.3/FahCore_23
06:04:15:I1:WU3:************************************ OpenMM ************************************
06:04:15:I1:WU3:    Version: 8.0.0
06:04:15:I1:WU3:********************************************************************************
06:04:15:I1:WU3:Project: 16525 (Run 111, Clone 2, Gen 216)
06:04:15:I1:WU3:Reading tar file core.xml
06:04:15:I1:WU3:Reading tar file integrator.xml
06:04:15:I1:WU3:Reading tar file state.xml
06:04:15:I1:OUT9:< HTTP/1.1 200 HTTP_OK
06:04:15:I1:WU4:Received WU assignment 09QyFOzcf23MgDqIt2WLlidI2TYWUg5trfm5achlG9Q
06:04:15:I1:WU4:Downloading WU
06:04:15:I1:OUT10:> POST https://vav21.fah.temple.edu/api/assign HTTP/1.1
06:04:15:I1:WU3:Reading tar file system.xml
06:04:16:I1:WU3:Digital signatures verified
06:04:16:I1:WU3:Folding@home GPU Core23 Folding@home Core
06:04:16:I1:WU3:Version 8.0.3
06:04:16:I1:WU3:  Checkpoint write interval: 50000 steps (2%) [50 total]
06:04:16:I1:WU3:  JSON viewer frame write interval: 25000 steps (1%) [100 total]
06:04:16:I1:WU3:  XTC frame write interval: 25000 steps (1%) [100 total]
06:04:16:I1:WU3:  Global context and integrator variables write interval: disabled
06:04:16:I1:WU3:There are 2 platforms available.
06:04:16:I1:WU3:Platform 0: Reference
06:04:16:I1:WU3:Platform 1: CPU
06:04:16:I1:WU3:opencl-device was set but OpenCL platform could not be found.
06:04:16:I1:WU3:ERROR:126: Neither CUDA nor OpenCL is available.
06:04:16:I1:WU3:Saving result file ../logfile_01.txt
06:04:16:I1:WU3:Saving result file science.log
06:04:16:I1:WU3:Folding@home Core Shutdown: BAD_WORK_UNIT
[91m06:04:16:E :WU3:Core returned BAD_WORK_UNIT (114)[0m
06:04:16:I1:WU4:DOWNLOAD 100% 643.19KiB of 643.19KiB
06:04:16:I1:OUT10:< HTTP/1.1 200 HTTP_OK
06:04:16:I1:WU4:Received WU P18497 R66 C65 G42
06:04:16:I1:Loaded cores/fahcore-a8-lin-64bit-avx2_256-0.0.12/FahCore_a8
06:04:16:I1:Default:Added new work unit: cpus:0 gpus:gpu:03:00:00
06:04:16:I1:WU3:Uploading WU results
06:04:16:I3:Running FahCore: /home/two/fah/cores/fahcore-a8-lin-64bit-avx2_256-0.0.12/FahCore_a8 -dir 09QyFOzcf23MgDqIt2WLlidI2TYWUg5trfm5achlG9Q -suffix 01 -version 8.4.9 -lifeline 143938 -np 13
06:04:16:I3:WU4:Started FahCore on PID 144226
06:04:16:I1:WU5:Requesting WU assignment for user borketh team 60
06:04:16:I1:OUT11:> POST https://huangfolding1.chem.wisc.edu/api/results HTTP/1.1
06:04:16:I1:OUT12:> POST https://assign3.foldingathome.org/api/assign HTTP/1.1
06:04:16:I1:WU4:*********************** Log Started 2025-02-12T06:04:16Z ***********************
06:04:16:I1:WU4:************************** Gromacs Folding@home Core ***************************
06:04:16:I1:WU4:       Core: Gromacs
06:04:16:I1:WU4:       Type: 0xa8
06:04:16:I1:WU4:    Version: 0.0.12
06:04:16:I1:WU4:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
06:04:16:I1:WU4:  Copyright: 2020 foldingathome.org
06:04:16:I1:WU4:   Homepage: https://foldingathome.org/
06:04:16:I1:WU4:       Date: Jan 16 2021
06:04:16:I1:WU4:       Time: 19:24:44
06:04:16:I1:WU4:   Compiler: GNU 8.3.0
06:04:16:I1:WU4:    Options: -faligned-new -std=c++14 -fsigned-char -ffunction-sections
06:04:16:I1:WU4:             -fdata-sections -O3 -funroll-loops -fno-pie
06:04:16:I1:WU4:   Platform: linux2 4.15.0-128-generic
06:04:16:I1:WU4:       Bits: 64
06:04:16:I1:WU4:       Mode: Release
06:04:16:I1:WU4:       SIMD: avx2_256
06:04:16:I1:WU4:     OpenMP: ON
06:04:16:I1:WU4:       CUDA: OFF
06:04:16:I1:WU4:       Args: -dir 09QyFOzcf23MgDqIt2WLlidI2TYWUg5trfm5achlG9Q -suffix 01
06:04:16:I1:WU4:             -version 8.4.9 -lifeline 143938 -np 13
06:04:16:I1:WU4:************************************ libFAH ************************************
06:04:16:I1:WU4:       Time: 19:21:38
06:04:16:I1:WU4:************************************ CBang *************************************
06:04:16:I1:WU4:       Time: 19:21:24
06:04:16:I1:WU4:             -fdata-sections -O3 -funroll-loops -fno-pie -fPIC
06:04:16:I1:WU4:************************************ System ************************************
06:04:16:I1:WU4:        CPU: AMD Ryzen 7 9800X3D 8-Core Processor
06:04:16:I1:WU4:     CPU ID: AuthenticAMD Family 26 Model 68 Stepping 0
06:04:16:I1:WU4:       CPUs: 16
06:04:16:I1:WU4:     Memory: 30.43GiB
06:04:16:I1:WU4:Free Memory: 16.09GiB
06:04:16:I1:WU4:    Threads: POSIX_THREADS
06:04:16:I1:WU4: OS Version: 6.13
06:04:16:I1:WU4:Has Battery: false
06:04:16:I1:WU4: On Battery: false
06:04:16:I1:WU4: UTC Offset: -5
06:04:16:I1:WU4:        PID: 144226
06:04:16:I1:WU4:        CWD: /home/two/fah/work
06:04:16:I1:WU4:********************************************************************************
06:04:16:I1:WU4:Project: 18497 (Run 66, Clone 65, Gen 42)
06:04:16:I1:WU4:Unit: 0x00000000000000000000000000000000
06:04:16:I1:WU4:Reading tar file core.xml
06:04:16:I1:WU4:Reading tar file frame42.tpr
06:04:16:I1:WU4:Digital signatures verified
06:04:16:I1:WU4:Calling: mdrun -c frame42.gro -s frame42.tpr -x frame42.xtc -cpt 5 -nt 13 -ntmpi 1
06:04:16:I1:WU4:Steps: first=210000000 total=215000000
06:04:16:I1:OUT11:< HTTP/1.1 200 HTTP_OK
06:04:16:I1:WU3:Credited
06:04:16:I1:OUT12:< HTTP/1.1 200 HTTP_OK
06:04:16:I1:WU5:Received WU assignment EfrO-E_0o_cPiDPkfvHPIS_dxjpsgWL3dI1nyNrL9xA
06:04:16:I1:WU5:Downloading WU
06:04:16:I1:OUT13:> POST https://fah1.innovatr.ca/api/assign HTTP/1.1
06:04:17:I1:WU4:Completed 1 out of 5000000 steps (0%)
06:04:18:I1:WU4:Caught signal SIGINT(2) on PID 144226
06:04:18:I1:WU4:Exiting, please wait. . .
06:04:18:I1:WU4:Folding@home Core Shutdown: INTERRUPTED
06:04:19:I1:WU5:DOWNLOAD 14% 4.02MiB of 28.68MiB
06:04:19:I1:WU4:Core returned INTERRUPTED (102)
06:04:19:I3:Running FahCore: /home/two/fah/cores/fahcore-a8-lin-64bit-avx2_256-0.0.12/FahCore_a8 -dir 09QyFOzcf23MgDqIt2WLlidI2TYWUg5trfm5achlG9Q -suffix 01 -version 8.4.9 -lifeline 143938 -np 12
06:04:19:I3:WU4:Started FahCore on PID 144255
06:04:19:I1:WU4:*********************** Log Started 2025-02-12T06:04:19Z ***********************
06:04:19:I1:WU4:************************** Gromacs Folding@home Core ***************************
06:04:19:I1:WU4:       Core: Gromacs
06:04:19:I1:WU4:       Type: 0xa8
06:04:19:I1:WU4:    Version: 0.0.12
06:04:19:I1:WU4:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
06:04:19:I1:WU4:  Copyright: 2020 foldingathome.org
06:04:19:I1:WU4:   Homepage: https://foldingathome.org/
06:04:19:I1:WU4:       Date: Jan 16 2021
06:04:19:I1:WU4:       Time: 19:24:44
06:04:19:I1:WU4:   Compiler: GNU 8.3.0
06:04:19:I1:WU4:    Options: -faligned-new -std=c++14 -fsigned-char -ffunction-sections
06:04:19:I1:WU4:             -fdata-sections -O3 -funroll-loops -fno-pie
06:04:19:I1:WU4:   Platform: linux2 4.15.0-128-generic
06:04:19:I1:WU4:       Bits: 64
06:04:19:I1:WU4:       Mode: Release
06:04:19:I1:WU4:       SIMD: avx2_256
06:04:19:I1:WU4:     OpenMP: ON
06:04:19:I1:WU4:       CUDA: OFF
06:04:19:I1:WU4:       Args: -dir 09QyFOzcf23MgDqIt2WLlidI2TYWUg5trfm5achlG9Q -suffix 01
06:04:19:I1:WU4:             -version 8.4.9 -lifeline 143938 -np 12
06:04:19:I1:WU4:************************************ libFAH ************************************
06:04:19:I1:WU4:       Time: 19:21:38
06:04:19:I1:WU4:************************************ CBang *************************************
06:04:19:I1:WU4:       Time: 19:21:24
06:04:19:I1:WU4:             -fdata-sections -O3 -funroll-loops -fno-pie -fPIC
06:04:19:I1:WU4:************************************ System ************************************
06:04:19:I1:WU4:        CPU: AMD Ryzen 7 9800X3D 8-Core Processor
06:04:19:I1:WU4:     CPU ID: AuthenticAMD Family 26 Model 68 Stepping 0
06:04:19:I1:WU4:       CPUs: 16
06:04:19:I1:WU4:     Memory: 30.43GiB
06:04:19:I1:WU4:Free Memory: 16.16GiB
06:04:19:I1:WU4:    Threads: POSIX_THREADS
06:04:19:I1:WU4: OS Version: 6.13
06:04:19:I1:WU4:Has Battery: false
06:04:19:I1:WU4: On Battery: false
06:04:19:I1:WU4: UTC Offset: -5
06:04:19:I1:WU4:        PID: 144255
06:04:19:I1:WU4:        CWD: /home/two/fah/work
06:04:19:I1:WU4:********************************************************************************
06:04:19:I1:WU4:Project: 18497 (Run 66, Clone 65, Gen 42)
06:04:19:I1:WU4:Unit: 0x00000000000000000000000000000000
06:04:19:I1:WU4:Digital signatures verified
06:04:19:I1:WU4:Calling: mdrun -c frame42.gro -s frame42.tpr -x frame42.xtc -cpi state.cpt -cpt 5 -nt 12 -ntmpi 1
06:04:19:I1:WU4:Steps: first=210000000 total=215000000
06:04:20:I1:WU4:Completed 585 out of 5000000 steps (0%)
06:04:20:I1:WU5:DOWNLOAD 52% 15.00MiB of 28.68MiB
06:04:21:I1:WU5:DOWNLOAD 90% 25.72MiB of 28.68MiB
06:04:21:I1:WU5:DOWNLOAD 100% 28.68MiB of 28.68MiB
06:04:21:I1:OUT13:< HTTP/1.1 200 HTTP_OK
06:04:22:I1:WU5:Received WU P12294 R46 C37 G14
06:04:22:I3:Running FahCore: /home/two/fah/cores/openmm-core-23/centos-7.9.2009-64bit/release/fahcore-23-centos-7.9.2009-64bit-release-8.0.3/FahCore_23 -dir EfrO-E_0o_cPiDPkfvHPIS_dxjpsgWL3dI1nyNrL9xA -suffix 01 -version 8.4.9 -lifeline 143938 -gpu-platform cuda -gpu-vendor amd -opencl-platform 1 -opencl-device 0 -gpu 0
06:04:22:I3:WU5:Started FahCore on PID 144270
06:04:22:I1:WU5:*********************** Log Started 2025-02-12T06:04:22Z ***********************
06:04:22:I1:WU5:*************************** Core23 Folding@home Core ***************************
06:04:22:I1:WU5:       Core: Core23
06:04:22:I1:WU5:       Type: 0x23
06:04:22:I1:WU5:    Version: 8.0.3
06:04:22:I1:WU5:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
06:04:22:I1:WU5:  Copyright: 2022 foldingathome.org
06:04:22:I1:WU5:   Homepage: https://foldingathome.org/
06:04:22:I1:WU5:       Date: Aug 3 2023
06:04:22:I1:WU5:       Time: 08:28:22
06:04:22:I1:WU5:   Revision: 199cb870317d05441d0a301287d9ef61254fa32b
06:04:22:I1:WU5:     Branch: HEAD
06:04:22:I1:WU5:   Compiler: GNU 7.5.0
06:04:22:I1:WU5:    Options: -faligned-new -std=c++11 -fsigned-char -ffunction-sections
06:04:22:I1:WU5:             -fdata-sections -O3 -funroll-loops -fno-pie
06:04:22:I1:WU5:             -DOPENMM_VERSION="\"8.0.0\""
06:04:22:I1:WU5:   Platform: linux 5.15.0-1041-azure
06:04:22:I1:WU5:       Bits: 64
06:04:22:I1:WU5:       Mode: Release
06:04:22:I1:WU5:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
06:04:22:I1:WU5:             <peastman@stanford.edu>
06:04:22:I1:WU5:       Args: -dir EfrO-E_0o_cPiDPkfvHPIS_dxjpsgWL3dI1nyNrL9xA -suffix 01
06:04:22:I1:WU5:             -version 8.4.9 -lifeline 143938 -gpu-platform cuda -gpu-vendor amd
06:04:22:I1:WU5:             -opencl-platform 1 -opencl-device 0 -gpu 0
06:04:22:I1:WU5:************************************ libFAH ************************************
06:04:22:I1:WU5:       Time: 08:27:48
06:04:22:I1:WU5:   Revision: 112c2234abe20611a05652defc3c7f854cbf927f
06:04:22:I1:WU5:************************************ CBang *************************************
06:04:22:I1:WU5:    Version: 1.7.2
06:04:22:I1:WU5:        Org: Cauldron Development LLC
06:04:22:I1:WU5:  Copyright: Cauldron Development LLC, 2003-2023
06:04:22:I1:WU5:   Homepage: https://cauldrondevelopment.com/
06:04:22:I1:WU5:    License: GPL 2+
06:04:22:I1:WU5:       Time: 08:27:30
06:04:22:I1:WU5:   Revision: eae4b58965bdd4d54ea9eb77972674352b37a547
06:04:22:I1:WU5:             -fdata-sections -O3 -funroll-loops -fno-pie -fPIC
06:04:22:I1:WU5:************************************ System ************************************
06:04:22:I1:WU5:        CPU: AMD Ryzen 7 9800X3D 8-Core Processor
06:04:22:I1:WU5:     CPU ID: AuthenticAMD Family 26 Model 68 Stepping 0
06:04:22:I1:WU5:       CPUs: 16
06:04:22:I1:WU5:     Memory: 30.43GiB
06:04:22:I1:WU5:Free Memory: 16.07GiB
06:04:22:I1:WU5:    Threads: POSIX_THREADS
06:04:22:I1:WU5: OS Version: 6.13
06:04:22:I1:WU5:Has Battery: false
06:04:22:I1:WU5: On Battery: false
06:04:22:I1:WU5: UTC Offset: -5
06:04:22:I1:WU5:        PID: 144270
06:04:22:I1:WU5:        CWD: /home/two/fah/work
06:04:22:I1:WU5:       Exec: /home/two/fah/cores/openmm-core-23/centos-7.9.2009-64bit/release/fahcore-23-centos-7.9.2009-64bit-release-8.0.3/FahCore_23
06:04:22:I1:WU5:************************************ OpenMM ************************************
06:04:22:I1:WU5:    Version: 8.0.0
06:04:22:I1:WU5:********************************************************************************
06:04:22:I1:WU5:Project: 12294 (Run 46, Clone 37, Gen 14)
06:04:22:I1:WU5:Reading tar file core.xml
06:04:22:I1:WU5:Reading tar file integrator.xml
06:04:22:I1:WU5:Reading tar file state.xml.bz2
06:04:22:I1:WU5:Reading tar file system.xml.bz2
06:04:22:I1:WU5:Digital signatures verified
06:04:22:I1:WU5:Folding@home GPU Core23 Folding@home Core
06:04:22:I1:WU5:Version 8.0.3
06:04:22:I1:WU5:  Checkpoint write interval: 50000 steps (2%) [50 total]
06:04:22:I1:WU5:  JSON viewer frame write interval: 25000 steps (1%) [100 total]
06:04:22:I1:WU5:  XTC frame write interval: 25000 steps (1%) [100 total]
06:04:22:I1:WU5:  Global context and integrator variables write interval: disabled
06:04:22:I1:WU5:There are 2 platforms available.
06:04:22:I1:WU5:Platform 0: Reference
06:04:22:I1:WU5:Platform 1: CPU
06:04:22:I1:WU5:opencl-device was set but OpenCL platform could not be found.
06:04:22:I1:WU5:ERROR:126: Neither CUDA nor OpenCL is available.
06:04:22:I1:WU5:Saving result file ../logfile_01.txt
06:04:22:I1:WU5:Saving result file science.log
06:04:22:I1:WU5:Folding@home Core Shutdown: BAD_WORK_UNIT
[91m06:04:23:E :WU5:Core returned BAD_WORK_UNIT (114)[0m
06:04:23:I1:Default:Added new work unit: cpus:0 gpus:gpu:03:00:00
06:04:23:I1:WU5:Uploading WU results
06:04:23:I1:WU6:Requesting WU assignment for user borketh team 60
06:04:23:I1:OUT14:> POST https://fah1.innovatr.ca/api/results HTTP/1.1
06:04:23:I1:OUT15:> POST https://assign4.foldingathome.org/api/assign HTTP/1.1
06:04:23:I1:WU4:Caught signal SIGINT(2) on PID 144255
06:04:23:I1:WU4:Exiting, please wait. . .
06:04:23:I1:WU4:Folding@home Core Shutdown: INTERRUPTED
06:04:23:I1:OUT14:< HTTP/1.1 200 HTTP_OK
06:04:23:I1:WU5:Credited
06:04:23:I1:WU4:Core returned INTERRUPTED (102)
06:04:23:I3:Running FahCore: /home/two/fah/cores/fahcore-a8-lin-64bit-avx2_256-0.0.12/FahCore_a8 -dir 09QyFOzcf23MgDqIt2WLlidI2TYWUg5trfm5achlG9Q -suffix 01 -version 8.4.9 -lifeline 143938 -np 13
06:04:23:I3:WU4:Started FahCore on PID 144274
06:04:23:I1:OUT15:< HTTP/1.1 200 HTTP_OK
06:04:23:I1:WU6:Received WU assignment flN60VuxcmPUu1cfbAMPJbEuzpYs70ZfwYRIbTPDMCk
06:04:23:I1:WU6:Downloading WU
06:04:23:I1:WU4:*********************** Log Started 2025-02-12T06:04:23Z ***********************
06:04:23:I1:WU4:************************** Gromacs Folding@home Core ***************************
06:04:23:I1:WU4:       Core: Gromacs
06:04:23:I1:WU4:       Type: 0xa8
06:04:23:I1:WU4:    Version: 0.0.12
06:04:23:I1:WU4:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
06:04:23:I1:WU4:  Copyright: 2020 foldingathome.org
06:04:23:I1:WU4:   Homepage: https://foldingathome.org/
06:04:23:I1:WU4:       Date: Jan 16 2021
06:04:23:I1:WU4:       Time: 19:24:44
06:04:23:I1:WU4:   Compiler: GNU 8.3.0
06:04:23:I1:WU4:    Options: -faligned-new -std=c++14 -fsigned-char -ffunction-sections
06:04:23:I1:WU4:             -fdata-sections -O3 -funroll-loops -fno-pie
06:04:23:I1:WU4:   Platform: linux2 4.15.0-128-generic
06:04:23:I1:WU4:       Bits: 64
06:04:23:I1:WU4:       Mode: Release
06:04:23:I1:WU4:       SIMD: avx2_256
06:04:23:I1:WU4:     OpenMP: ON
06:04:23:I1:WU4:       CUDA: OFF
06:04:23:I1:WU4:       Args: -dir 09QyFOzcf23MgDqIt2WLlidI2TYWUg5trfm5achlG9Q -suffix 01
06:04:23:I1:WU4:             -version 8.4.9 -lifeline 143938 -np 13
06:04:23:I1:WU4:************************************ libFAH ************************************
06:04:23:I1:WU4:       Time: 19:21:38
06:04:23:I1:WU4:************************************ CBang *************************************
06:04:23:I1:WU4:       Time: 19:21:24
06:04:23:I1:WU4:             -fdata-sections -O3 -funroll-loops -fno-pie -fPIC
06:04:23:I1:WU4:************************************ System ************************************
06:04:23:I1:WU4:        CPU: AMD Ryzen 7 9800X3D 8-Core Processor
06:04:23:I1:WU4:     CPU ID: AuthenticAMD Family 26 Model 68 Stepping 0
06:04:23:I1:WU4:       CPUs: 16
06:04:23:I1:WU4:     Memory: 30.43GiB
06:04:23:I1:WU4:Free Memory: 16.16GiB
06:04:23:I1:WU4:    Threads: POSIX_THREADS
06:04:23:I1:WU4: OS Version: 6.13
06:04:23:I1:WU4:Has Battery: false
06:04:23:I1:WU4: On Battery: false
06:04:23:I1:WU4: UTC Offset: -5
06:04:23:I1:WU4:        PID: 144274
06:04:23:I1:WU4:        CWD: /home/two/fah/work
06:04:23:I1:WU4:********************************************************************************
06:04:23:I1:WU4:Project: 18497 (Run 66, Clone 65, Gen 42)
06:04:23:I1:WU4:Unit: 0x00000000000000000000000000000000
06:04:23:I1:WU4:Digital signatures verified
06:04:23:I1:WU4:Calling: mdrun -c frame42.gro -s frame42.tpr -x frame42.xtc -cpi state.cpt -cpt 5 -nt 13 -ntmpi 1
06:04:23:I1:WU4:Steps: first=210000000 total=215000000
06:04:24:I1:OUT16:> POST https://highland3.seas.upenn.edu/api/assign HTTP/1.1
06:04:24:I1:WU4:Completed 1642 out of 5000000 steps (0%)
06:04:27:I1:WU4:Caught signal SIGINT(2) on PID 144274
06:04:27:I1:WU4:Exiting, please wait. . .
06:04:27:I1:WU4:Folding@home Core Shutdown: INTERRUPTED
06:04:28:I1:WU4:Core returned INTERRUPTED (102)
06:04:28:I3:Running FahCore: /home/two/fah/cores/fahcore-a8-lin-64bit-avx2_256-0.0.12/FahCore_a8 -dir 09QyFOzcf23MgDqIt2WLlidI2TYWUg5trfm5achlG9Q -suffix 01 -version 8.4.9 -lifeline 143938 -np 12
06:04:28:I3:WU4:Started FahCore on PID 144291
06:04:28:I1:WU4:*********************** Log Started 2025-02-12T06:04:28Z ***********************
06:04:28:I1:WU4:************************** Gromacs Folding@home Core ***************************
06:04:28:I1:WU4:       Core: Gromacs
06:04:28:I1:WU4:       Type: 0xa8
06:04:28:I1:WU4:    Version: 0.0.12
06:04:28:I1:WU4:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
06:04:28:I1:WU4:  Copyright: 2020 foldingathome.org
06:04:28:I1:WU4:   Homepage: https://foldingathome.org/
06:04:28:I1:WU4:       Date: Jan 16 2021
06:04:28:I1:WU4:       Time: 19:24:44
06:04:28:I1:WU4:   Compiler: GNU 8.3.0
06:04:28:I1:WU4:    Options: -faligned-new -std=c++14 -fsigned-char -ffunction-sections
06:04:28:I1:WU4:             -fdata-sections -O3 -funroll-loops -fno-pie
06:04:28:I1:WU4:   Platform: linux2 4.15.0-128-generic
06:04:28:I1:WU4:       Bits: 64
06:04:28:I1:WU4:       Mode: Release
06:04:28:I1:WU4:       SIMD: avx2_256
06:04:28:I1:WU4:     OpenMP: ON
06:04:28:I1:WU4:       CUDA: OFF
06:04:28:I1:WU4:       Args: -dir 09QyFOzcf23MgDqIt2WLlidI2TYWUg5trfm5achlG9Q -suffix 01
06:04:28:I1:WU4:             -version 8.4.9 -lifeline 143938 -np 12
06:04:28:I1:WU4:************************************ libFAH ************************************
06:04:28:I1:WU4:       Time: 19:21:38
06:04:28:I1:WU4:************************************ CBang *************************************
06:04:28:I1:WU4:       Time: 19:21:24
06:04:28:I1:WU4:             -fdata-sections -O3 -funroll-loops -fno-pie -fPIC
06:04:28:I1:WU4:************************************ System ************************************
06:04:28:I1:WU4:        CPU: AMD Ryzen 7 9800X3D 8-Core Processor
06:04:28:I1:WU4:     CPU ID: AuthenticAMD Family 26 Model 68 Stepping 0
06:04:28:I1:WU4:       CPUs: 16
06:04:28:I1:WU4:     Memory: 30.43GiB
06:04:28:I1:WU4:Free Memory: 16.20GiB
06:04:28:I1:WU4:    Threads: POSIX_THREADS
06:04:28:I1:WU4: OS Version: 6.13
06:04:28:I1:WU4:Has Battery: false
06:04:28:I1:WU4: On Battery: false
06:04:28:I1:WU4: UTC Offset: -5
06:04:28:I1:WU4:        PID: 144291
06:04:28:I1:WU4:        CWD: /home/two/fah/work
06:04:28:I1:WU4:********************************************************************************
06:04:28:I1:WU4:Project: 18497 (Run 66, Clone 65, Gen 42)
06:04:28:I1:WU4:Unit: 0x00000000000000000000000000000000
06:04:28:I1:WU4:Digital signatures verified
06:04:28:I1:WU4:Calling: mdrun -c frame42.gro -s frame42.tpr -x frame42.xtc -cpi state.cpt -cpt 5 -nt 12 -ntmpi 1
06:04:28:I1:WU4:Steps: first=210000000 total=215000000
06:04:29:I1:WU4:Completed 2807 out of 5000000 steps (0%)
06:04:29:I1:WU6:DOWNLOAD 6% 8.02MiB of 130.07MiB
06:04:30:I1:WU6:DOWNLOAD 15% 19.33MiB of 130.07MiB
06:04:31:I1:WU6:DOWNLOAD 24% 31.12MiB of 130.07MiB
06:04:32:I1:WU6:DOWNLOAD 33% 42.90MiB of 130.07MiB
06:04:33:I1:WU6:DOWNLOAD 41% 53.67MiB of 130.07MiB
06:04:34:I1:WU6:DOWNLOAD 50% 65.37MiB of 130.07MiB
06:04:35:I1:WU6:DOWNLOAD 59% 77.14MiB of 130.07MiB
06:04:36:I1:WU6:DOWNLOAD 68% 88.95MiB of 130.07MiB
06:04:37:I1:WU6:DOWNLOAD 77% 100.72MiB of 130.07MiB
06:04:38:I1:WU6:DOWNLOAD 86% 112.52MiB of 130.07MiB
06:04:39:I1:WU6:DOWNLOAD 96% 124.31MiB of 130.07MiB
06:04:40:I1:WU6:DOWNLOAD 100% 130.07MiB of 130.07MiB
06:04:40:I1:OUT16:< HTTP/1.1 200 HTTP_OK
06:04:41:I1:WU6:Received WU P18251 R212 C2 G136
06:04:42:I1:Loaded cores/openmm-core-24/centos-7.9.2009-64bit/release/fahcore-24-centos-7.9.2009-64bit-release-8.1.4/FahCore_24
06:04:42:I3:Running FahCore: /home/two/fah/cores/openmm-core-24/centos-7.9.2009-64bit/release/fahcore-24-centos-7.9.2009-64bit-release-8.1.4/FahCore_24 -dir flN60VuxcmPUu1cfbAMPJbEuzpYs70ZfwYRIbTPDMCk -suffix 01 -version 8.4.9 -lifeline 143938 -gpu-platform cuda -gpu-vendor amd -opencl-platform 1 -opencl-device 0 -gpu 0
06:04:42:I3:WU6:Started FahCore on PID 144308
06:04:42:I1:WU6:*********************** Log Started 2025-02-12T06:04:42Z ***********************
06:04:42:I1:WU6:*************************** Core24 Folding@home Core ***************************
06:04:42:I1:WU6:       Core: Core24
06:04:42:I1:WU6:       Type: 0x24
06:04:42:I1:WU6:    Version: 8.1.4
06:04:42:I1:WU6:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
06:04:42:I1:WU6:  Copyright: 2022 foldingathome.org
06:04:42:I1:WU6:   Homepage: https://foldingathome.org/
06:04:42:I1:WU6:       Date: Jul 25 2024
06:04:42:I1:WU6:       Time: 05:19:51
06:04:42:I1:WU6:   Revision: cf9f0139862b8945a2091772770e4631aac37792
06:04:42:I1:WU6:     Branch: HEAD
06:04:42:I1:WU6:   Compiler: GNU 7.5.0
06:04:42:I1:WU6:    Options: -faligned-new -std=c++14 -fsigned-char -ffunction-sections
06:04:42:I1:WU6:             -fdata-sections -O3 -funroll-loops -fno-pie
06:04:42:I1:WU6:             -DOPENMM_VERSION="\"8.1.1\""
06:04:42:I1:WU6:   Platform: linux 6.5.0-1024-azure
06:04:42:I1:WU6:       Bits: 64
06:04:42:I1:WU6:       Mode: Release
06:04:42:I1:WU6:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
06:04:42:I1:WU6:             <peastman@stanford.edu>
06:04:42:I1:WU6:       Args: -dir flN60VuxcmPUu1cfbAMPJbEuzpYs70ZfwYRIbTPDMCk -suffix 01
06:04:42:I1:WU6:             -version 8.4.9 -lifeline 143938 -gpu-platform cuda -gpu-vendor amd
06:04:42:I1:WU6:             -opencl-platform 1 -opencl-device 0 -gpu 0
06:04:42:I1:WU6:************************************ libFAH ************************************
06:04:42:I1:WU6:       Time: 05:13:14
06:04:42:I1:WU6:   Revision: c7d2824a47eb025fa8cda8968c7a5e971585d90c
06:04:42:I1:WU6:    Options: -faligned-new -std=c++11 -fsigned-char -ffunction-sections
06:04:42:I1:WU6:************************************ CBang *************************************
06:04:42:I1:WU6:    Version: 1.7.2
06:04:42:I1:WU6:        Org: Cauldron Development LLC
06:04:42:I1:WU6:  Copyright: Cauldron Development LLC, 2003-2024
06:04:42:I1:WU6:   Homepage: https://cauldrondevelopment.com/
06:04:42:I1:WU6:    License: LGPL-2.1-or-later
06:04:42:I1:WU6:       Time: 05:12:47
06:04:42:I1:WU6:   Revision: f1cd4c791e8c40a35dcfeab3ab85d910949cc0cb
06:04:42:I1:WU6:             -fdata-sections -O3 -funroll-loops -fno-pie -fPIC
06:04:42:I1:WU6:************************************ System ************************************
06:04:42:I1:WU6:        CPU: AMD Ryzen 7 9800X3D 8-Core Processor
06:04:42:I1:WU6:     CPU ID: AuthenticAMD Family 26 Model 68 Stepping 0
06:04:42:I1:WU6:       CPUs: 16
06:04:42:I1:WU6:     Memory: 30.43GiB
06:04:42:I1:WU6:Free Memory: 16.03GiB
06:04:42:I1:WU6: OS Version: 6.13
06:04:42:I1:WU6:Has Battery: false
06:04:42:I1:WU6: On Battery: false
06:04:42:I1:WU6:   Hostname: vitesse
06:04:42:I1:WU6: UTC Offset: -5
06:04:42:I1:WU6:        PID: 144308
06:04:42:I1:WU6:        CWD: /home/two/fah/work
06:04:42:I1:WU6:       Exec: /home/two/fah/cores/openmm-core-24/centos-7.9.2009-64bit/release/fahcore-24-centos-7.9.2009-64bit-release-8.1.4/FahCore_24
06:04:42:I1:WU6:************************************ OpenMM ************************************
06:04:42:I1:WU6:    Version: 8.1.1
06:04:42:I1:WU6:********************************************************************************
06:04:42:I1:WU6:Project: 18251 (Run 212, Clone 2, Gen 136)
06:04:42:I1:WU6:Reading tar file core.xml
06:04:42:I1:WU6:Reading tar file integrator.xml
06:04:42:I1:WU6:Reading tar file state.xml.bz2
06:04:42:I1:WU6:Reading tar file system.xml.bz2
06:04:42:I1:WU6:Digital signatures verified
06:04:42:I1:WU6:Folding@home GPU Core24 Folding@home Core
06:04:42:I1:WU6:Version 8.1.4
06:04:42:I1:WU6:  Checkpoint write interval: 12500 steps (5%) [20 total]
06:04:42:I1:WU6:  JSON viewer frame write interval: 2500 steps (1%) [100 total]
06:04:42:I1:WU6:  XTC frame write interval: 5000 steps (2%) [50 total]
06:04:42:I1:WU6:  TRR frame write interval: disabled
06:04:42:I1:WU6:  Global context and integrator variables write interval: disabled
06:04:42:I1:WU6:There are 3 platforms available.
06:04:42:I1:WU6:Platform 0: Reference
06:04:42:I1:WU6:Platform 1: CPU
06:04:42:I1:WU6:Platform 2: OpenCL
06:04:42:I1:WU6:  opencl-device 0 specified
06:05:24:I1:WU6:Attempting to create OpenCL context:
06:05:24:I1:WU6:  Configuring platform OpenCL
06:05:40:I1:WU6:  Using OpenCL on OpenCL platformId 1 and gpu 0
06:05:40:I1:WU6:  GPU info: Platform: OpenCL: rusticl
06:05:40:I1:WU6:  GPU info: PlatformIndex: 0
06:05:40:I1:WU6:  GPU info: Device: AMD Radeon RX 7800 XT (radeonsi, navi32, LLVM 19.1.7, DRM 3.59, 6.13.2-2-cachyos)
06:05:40:I1:WU6:  GPU info: DeviceIndex: 0
06:05:40:I1:WU6:  GPU info: Vendor: 0x1002
06:05:40:I1:WU6:  GPU info: PCI: ??:??:??
06:05:40:I1:WU6:  GPU info: Compute: 3.0
06:05:40:I1:WU6:  GPU info: Driver: 24.3
06:05:40:I1:WU6:  GPU info: GPU: true
06:05:40:I1:WU6:Completed 0 out of 250000 steps (0%)
06:05:43:I1:WU6:Checkpoint completed at step 0
06:05:50:I1:WU4:Caught signal SIGINT(2) on PID 144291
06:05:50:I1:WU4:Exiting, please wait. . .
06:05:50:I1:WU4:Folding@home Core Shutdown: INTERRUPTED
06:05:50:I1:WU6:Caught signal SIGINT(2)
06:05:50:I1:WU6:Exiting, please wait. . .
06:05:50:I1:WU6:Folding@home Core Shutdown: INTERRUPTED
06:05:50:I1:WU4:Core returned INTERRUPTED (102)
06:05:50:I1:WU6:Core returned INTERRUPTED (102)
06:05:51:I1:Clean exit
Post by muziqaz »
GLIBC issue with bleeding edge distros.
FAH Omega tester
borketh
Post by borketh »
... could you elaborate? I would like to fix this
Post by muziqaz »
borketh wrote: Wed Feb 12, 2025 4:51 pm ... could you elaborate? I would like to fix this
No way to fix it. This is fahcore issue more than anything else.
Basically each fahcore demands specific GLIBC version. Bleeding edge distro, like yours, has too new GLIBC version in your OS which does not match that of fahcore23. Fahcore23 requires newer GLIBC, which matches the one on your system.
FAH Omega tester
Frogging101
Post by Frogging101 »
Same issue.
tictoc
Hardware configuration: AMD Threadripper 7960X
1x AMD Radeon 7900XTX
1x AMD Radeon 6900XT
1x AMD Radeon VII
AMD Threadripper 3960X
2x AMD Radeon VII
AMD Threadripper 2970WX
2x AMD Radeon VII
AMD Ryzen 7 5800X
2x NVIDIA RTX 3090
Post by tictoc »
Little late, but if you are still having issues, it is very unlikely that glibc is the issue. You currently have multiple OpenCL platform drivers. Any reason why you are trying to using rusticl while also running ROCm? No idea how CachyOS deals with that, but on Arch you could just uninstall opencl-rusticl-mesa. That's the first variable I would remove from the equation, unless you have some specific reason for using rusticl. rusticl still has some issues running all OpenCL apps.
It's been a few weeks since I've seen a 16525, but the last one I ran folded without issue on a 6900xt. I wish I was still getting those WUs and their 6.5M ppd. :)
FWIW, I am always running the latest ROCm, along with an always up-to-date Arch Linux, and usually whatever rc kernel is in Linus' tree. Back in February I was running ROCm 6.3.2 and kernel 6.14-rc1-3.
Specs below for what I currently have folding.
Threadripper 3960X
Radeon 6900XT 2780core|2150mem
Arch Linux | Kernel: 6.14 | ROCm: 6.3.3
borketh
Post by borketh »
It was a glibc issue. I solved it by replacing the glibc file with a link to my system glibc. I've been given the occasional Core23 job since and successfully completed them.
tictoc
1x AMD Radeon VII
2x AMD Radeon VII
2x AMD Radeon VII
AMD Ryzen 7 5800X
2x NVIDIA RTX 3090
Post by tictoc »
Excellent. I vaguely remember having to do something similar, but haven't encountered that in a while.
**Edit** Just checked my core23 directory, and I symlinked the shipped libstdc++.so.6 to my system lib back in January when I started running FAH again.
rachelplusplus
Post by rachelplusplus »
I ran into the same issue today on Debian 13, so it's not just rolling-release distros affected.
Kernel version 6.12.41, glibc version 2.41-12, and using an AMD 9060 XT with ROCm version 6.2.3 installed following the instructions in the original post of viewtopic.php?t=42491
Post by muziqaz »
I think I had a guide somewhere here and on discord for full glibc solution for cores22/23/24. Core 27 does not need that, yet
FAH Omega tester
Post by muziqaz »
Ah here it is: viewtopic.php?t=42789
FAH Omega tester
rachelplusplus
Thank you, I will give that a try!
