F@H v8.4.9 for RPi contains NVidia bloatware (SOLVED)
Schrödinger's cat
Hardware configuration: NVIDIA RTX 4080 Super
20 x Raspberry Pi 5 Model B 2GB RAM
Post by Schrödinger's cat »
Why does the folding software for Raspbery Pis contain NVidia bloatware (GPU drivers or something)?
No Raspberry Pi could run a GPU, could it?
Last edited by Schrödinger's cat on Mon Feb 17, 2025 7:43 am, edited 2 times in total.
Re: F@H v8.4.9 for RPi contains NVidia bloatware.
Post by muziqaz »
Ask our distinguished developer at GitHub :)
I asked the same question for AMD systems, but I cannot repeat the answer to that :D
FAH Omega tester
Schrödinger's cat
It turns out linux installed nvidia-opencl-icd during the fah-client install. That was a whooping 28 packages using 363.2MB in total.
Only do this if you DON'T have a NVidia GPU
Run
sudo apt remove nvidia-opencl-icd --purge -y && sudo apt autoremove -y
to remove nvidia-opencl-icd and the other 27 packages that were automatically installed with it.
That will remove all the packages and the kernel customisations that they created.
