Project 16525 dumped buy itself when I turned on my PC
https://ibb.co/HfJdGvKc
https://ibb.co/FLJjPfZZ
I can provide logs as wel, but don't know where log is located.
				cgistlaker
Re: Project 16525 dumped buy itself when I turned on my PC
On my v8 windows 11 the logs are at:
"C:\ProgramData\FAHClient\logs"
Once there you can right-click and select open in terminal if you need to see the latest logs type "dir" (no quotes)
Basically, you need to find the log that has that WU in it and look for errors .... if the client errors 3 times it will dump the WU and move on to another
I see no record of 59,2,202 at https://apps.foldingathome.org/wu#proje ... =2&gen=202
				cgistlaker
*********************** Log Started 2025-02-02T23:59:59Z ***********************
00:02:54:E :WU230:Core returned UNKNOWN_ENUM (1073807364)
00:02:54:E :WU230:Core exited with an unknown error code 1073807364 which probably indicates that it crashed. Dumping WU
00:02:54:I1:WU230:Sending dump report
00:02:55:I1:OUT14:> POST https://huangfolding1.chem.wisc.edu/api/results HTTP/1.1
But it was just correct shut down of PC. Looks like 8.4.9 contains bug
Always pause folding at home before rebooting or shutting down .... on windows especially.  A shutdown during the time it's writing to disc can and usually will cause a problem resulting in a corrupt WU.
A cat turned off my PC right before a 16525 was about to hit 100%. Errors, all dumped.
No more computer cases with power buttons on the top.
